Elvis Presley - Blue Hawaii 4k BluRay
alaskaguy
#1 Post by alaskaguy » Wed Dec 28, 2022 1:11 pm
This new released 4k UHD BluRay can not be opened. After several tries I tried a test version of DVDFab and it worked fine. So, it's not a drive-problem.
Debug log started at Wed Dec 28 13:03:10 2022 , written by MakeMKV v1.17.2 win(x64-release)
001005:0000 MakeMKV v1.17.2 win(x64-release) gestartet
001004:0000 Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als file://C:\Users\John-Barrows/MakeMKV_log.txt
DEBUG: Code 3 at `6CF;l<+`$x9]D6No(y!wmrg:29395310
SDF v090: HL-DT-ST_BD-RE__BH16NS55_1.02_211512111440_SIK94G1E8233
SDF v090: ASUS_BW-16D1HT_1.01_211302051930_K94F15J0201
No SDF v090: ELBY_CLONEDRIVE_1.4
SDF id v090: ELBY_CLONEDRIVE_1.4
001011:0000 Using LibreDrive mode (v06.3 id=067EFCA8EA7E)
003007:0000 Direkter Zugriffsmodus wird verwendet
005085:0000 Inhalte-Hashtabelle geladen, überprüfe Integrität der M2TS-Dateien.
DEBUG: Code 2147483648 at sAsRoYOC"v.1gCP{:213132882
001003:0020 DEBUG: Code 0 at sAsRoYOC"v.1gCP{:29398944
003332:0000 AACS Ausgabedatei als file://C:\Users\John-Barrows/.MakeMKV/MKB20_v77_Blue_Hawaii_(Remastered)_64EA.tgz gesichert
003303:0000 Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
001003:0020 DEBUG: Code 0 at Vea=4mKMwR{FY\\^:29396138
001003:0020 DEBUG: Code 0 at Vea=4mKMwR{FY\\^:121263153
005010:0000 Das Öffnen der Disk schlug fehl
Re: Elvis Presley - Blue Hawaii 4k BluRay
#2 Post by d00zah » Wed Dec 28, 2022 1:20 pm
alaskaguy wrote: Wed Dec 28, 2022 1:11 pm This new released 4k UHD BluRay can not be opened. After several tries I tried a test version of DVDFab and it worked fine. So, it's not a drive-problem.
Per the FAQ (a worthwhile read):
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
edit:
"SDF id v090: ELBY_CLONEDRIVE_1.4"
Are you mounting an .iso? Made by another app?
alaskaguy
#3 Post by alaskaguy » Wed Dec 28, 2022 1:44 pm
Thank you for that fast reply. I just send the dump-file.
And no. I do not use the virtual drive in that case. I have the original BluRay in my LG drive.
alaskaguy
#4 Post by alaskaguy » Sun Jan 15, 2023 2:23 pm
It's still not working with Makemkv.
#5 Post by d00zah » Sun Jan 15, 2023 2:32 pm
alaskaguy wrote: Sun Jan 15, 2023 2:23 pm It's still not working with Makemkv.
Make sure MakeMKV has internet access (Preferences > General tab > Enable internet access) & that your firewall is not blocking MakeMKV.
Resubmit dump.
Beyond that, your answer MAY be here:
Fixing Volume Key is Unknown
UHD FAQ
