Friends Blu Ray Collection
jeremybrice
Re: Friends Blu Ray Collection
Post by jeremybrice »
H0lyH4ndGr3nade wrote: Tue May 30, 2017 2:59 pm I took the work from a lot of the previous posters and created a python script to automate the renaming process. I created two files: one that contains a dictionary for the renaming, and one that is the python script itself. The script renames the episodes according to the Plex file naming syntax, but it could be easily adapted for other formats as well.
it looks like each disk episodes are 0071-0082 corresponding to to how many episodes are on the disk
I found that to be true, except for a few disks when I needed to grab 0083 as well. I think it was from the seasons that have 25 episodes instead of 24.
just in case someone still finds this thread - that's what I came up with:
S01E01-Friends_Season_1_Disc_1_t04.mkv 2.879.720.178
S01E02-Friends_Season_1_Disc_1_t03.mkv 2.878.105.524
S01E03-Friends_Season_1_Disc_1_t02.mkv 2.876.395.858
This was a huge help in creating my script!! Thanks! I had a few small differences from this, all from one disk (I believe it was in season 2 disc 2).
Anyways... here are the two files: dictionary.txt and rename.py. Just drop these two files in the same folder as all the episodes and it will rename them. If you see any errors/mistakes let me know and I will make sure to update!
Thank you so much. You and wurlz saved me a ton of time!
kingfeanor
Post by kingfeanor »
I bought the blueray set recently and had a different ordering of the files. I've updated the dictionary.txt and I also updated the rename.py script to perform validation (to make sure the files you have are the same as the dictionary expects).
yanksno1
Post by yanksno1 »
wurzl wrote: Tue Mar 03, 2015 6:09 am just in case someone still finds this thread - that's what I came up with:
I found this thread too! Thank you sir for your hard work, you saved me weeks of trying to figure out which episode was which (I usually match it up to playing on the disc on my iMac). Unfortunately I’m an idiot and couldn’t figure out how to get H0lyH4ndGr3nade’s script working on my Unraid server, so I went one by one and think I got them all. I’m still running them through Handbreak, but at least the hard part is over and it only took a 2.5 days to rip and name them.
Stryker412
Post by Stryker412 »
I'm a python newbie here but I couldn't get it to work. I don't get any errors but after I enter the command to run (and it does) nothing is changed. I did match exactly the filenames I have in the dictionary.txt
Edit: Looks like the dictionary.txt might be for a different BD set. My Season 2 Disc 2 for instance, stops at t21 but the list shows:
S02e19|Friends Season 2 Disc 2_t24.mkv
S02e20|Friends Season 2 Disc 2_t23.mkv
S02e21|Friends Season 2 Disc 2_t22.mkv
jhenry6
Post by jhenry6 »
I know this is an old thread, but I wanted to provide my update. I found that the "Complete Series Friends" bluray doesn't match the information I read here. I went through the first season and some of the Txx track numbers are not large enough to be correct.
What I did was to use the MPLS numbers in MakeMKV by looking at each track on the disk. They seem to be correct. I added the MPLS number to the file name for each one. Then they came out in the right sequence. I've only got Season one done so far, but to seems to be correct. I'm not sure how to set it up yet to automatically ass the MPLS number to the file name, but I'll look at that next. It seems to work for other series also.
Post by d00zah »
Common knowledge... always look to MPLS numbers, as title numbers are variable, dependent on what a user sets 'Minimum title length (seconds)' to on the Preferences > Video tab. However, even MPLS sequences can vary depending on retail/rental/regional versions of a release.
philb1701
Post by philb1701 »
From the "for what it's worth" department...
The Friends blu-ray collection is the SYNDICATED versions of the episodes. Which means they were reframed and upscaled for better quality. It also means they were edited for time to allow stations to run more commercials. Plus not all episodes are in current syndication rotation, so you might be missing some watching them on TBS or Nick at Night.
The Friends standard DVD collection is the ORIGINAL broadcast versions. No widescreen, a bit fuzzy at times.
However, that being said....
There are significant differences in a lot of episodes. The episode "The One with the Embryos", (season 4, episode 12) is a perfect example. The broadcast version runs 24 minutes, the syndicated version runs 23. The DVD versions are not reframed for widescreen and haven't been upscaled for better quality, but you get to see a lot of "framing errors" like mics in the shots, as well as original versions of specific scenes in them. If you are a Friends fan, you will notice what was taken out for syndication when you watch the original versions. I personally have both the DVD and the blu-rays.
If you include a few random commentary episodes, Friends takes up about 423Gigs of space on my server. Let this guide you as to what to choose.
cwalkatron
Post by cwalkatron »
I MADE AN ACCOUNT just to say thanks to wurzl. Thanks so much!
vseven
Post by vseven »
Stumbled on this after buying my wife this set for Christmas. Didn't want to install Python so made a short PowerShell script to do the same thing. Do a search for PowerShell on your Win 10/11 machine then run the "Windows PowerShell ISE" as a administrator. Copy/paste the following in:
$BaseDir = "C:\Friends"
$DictionaryFile = "C:\Friends\dictionary.txt"
CLS
$Renames = Import-CSV $DictionaryFile –Delimiter "|" -Header "SeasonNumber","OriginalFileName"
foreach($File in $Renames) {
    $OldName = $BaseDir + "\" + $File.OriginalFileName
    $NewName = "Friends - " + $File.SeasonNumber + ".mkv"
    Try {
        Rename-Item $OldName $NewName -ErrorAction 'Stop'
        Write-Host "Renamed $OldName to $NewName"
    } Catch {
        Write-Host "Either couldn't find or rename $OldName"
I put all the files into C:\Friends and also put the dictionary file in there. If you use anything else change the first two lines. Then click the Play button. If you are like me and the tracks don't have a underscore just do a find/replace on the dictionary file for "_" and replace with " " then do another and find " t" and replace with "_t". I was going to add a part to look at the s?? and auto move the files to sub directories but this should be good enough.
I used this dictionary file from @paddyo as my season 2 disc 2 tracks were a little different. And it has the episode titles:
paddyo wrote: Wed Jun 19, 2019 4:43 am Just remove the _r1 before use. dictionary_r1.txt
FYI re Season 2 Disc 2: wurzl's was the correct listing for me, so those changes are also reflected in the file.
And the original list it's based on from @wurzl
Thanks to both of them for doing the hard parts.
vseven
Post by vseven »
Stryker412 wrote: Tue Oct 20, 2020 8:25 pm I'm a python newbie here but I couldn't get it to work. I don't get any errors but after I enter the command to run (and it does) nothing is changed. I did match exactly the filenames I have in the dictionary.txt
Same issue here. Some on the newer sets don't match up. Use the list from this post:
The "_tNN" is filled in by counting the file names based on the minimum size. Setting the minimum file size to, say, 1000 seconds will get you different "_tNN" numbers than 120 seconds for most disks.
lancealtar
Post by lancealtar »
8 years later and your post is still serving the community. Thank you, thank you, thank you! You have saved me so many hours.
S01E04-Friends_Season_1_Disc_1_t01.mkv	2.873.704.282
S01E05-Friends_Season_1_Disc_1_t00.mkv	2.870.030.536
S01E06-Friends_Season_1_Disc_1_t26.mkv	2.625.938.527
S01E07-Friends_Season_1_Disc_1_t25.mkv	2.835.701.350
S01E08-Friends_Season_1_Disc_1_t24.mkv	2.861.551.153
S01E09-Friends_Season_1_Disc_1_t23.mkv	2.870.442.514
S01E10-Friends_Season_1_Disc_1_t22.mkv	2.874.122.115
S01E11-Friends_Season_1_Disc_1_t11.mkv	2.870.647.883
S01E12-Friends_Season_1_Disc_1_t19.mkv	2.864.266.102
S01E13-Friends_Season_1_Disc_2_t04.mkv	2.872.334.039
S01E14-Friends_Season_1_Disc_2_t03.mkv	2.865.747.420
S01E15-Friends_Season_1_Disc_2_t02.mkv	2.869.770.656
S01E16-Friends_Season_1_Disc_2_t01.mkv	2.873.933.357
S01E17-Friends_Season_1_Disc_2_t00.mkv	2.865.779.801
S01E18-Friends_Season_1_Disc_2_t26.mkv 	2.865.811.406
S01E19-Friends_Season_1_Disc_2_t25.mkv	2.868.492.818
S01E20-Friends_Season_1_Disc_2_t24.mkv	2.869.261.536
S01E21-Friends_Season_1_Disc_2_t23.mkv	2.863.950.780
S01E22-Friends_Season_1_Disc_2_t20.mkv	2.862.630.042
S01E23-Friends_Season_1_Disc_2_t06.mkv	2.867.218.530
S01E24-Friends_Season_1_Disc_2_t07.mkv	2.864.990.630
S02E01-Friends_Season_2_Disc_1_t07.mkv	2.761.966.223
S02E02-Friends_Season_2_Disc_1_t14.mkv	2.826.561.183
S02E03-Friends_Season_2_Disc_1_t13.mkv	2.847.964.094
S02E04-Friends_Season_2_Disc_1_t12.mkv	2.839.499.019
S02E05-Friends_Season_2_Disc_1_t11.mkv	2.845.779.533
S02E06-Friends_Season_2_Disc_1_t10.mkv	2.844.331.160
S02E07-Friends_Season_2_Disc_1_t09.mkv	2.859.748.894
S02E08-Friends_Season_2_Disc_1_t08.mkv	2.845.006.671
S02E09-Friends_Season_2_Disc_1_t03.mkv	2.839.402.856
S02E10-Friends_Season_2_Disc_1_t01.mkv	2.849.477.069
S02E11-Friends_Season_2_Disc_1_t00.mkv	2.847.269.212
S02E12-Friends_Season_2_Disc_1_t02.mkv	2.834.311.809
S02E13-Friends_Season_2_Disc_1_t06.mkv	2.800.367.609
S02E14-Friends_Season_2_Disc_2_t15.mkv	2.834.460.947
S02E15-Friends_Season_2_Disc_2_t12.mkv	2.827.084.038
S02E16-Friends_Season_2_Disc_2_t06.mkv	2.819.440.834
S02E17-Friends_Season_2_Disc_2_t01.mkv	2.830.428.247
S02E18-Friends_Season_2_Disc_2_t00.mkv	2.831.303.788
S02E19-Friends_Season_2_Disc_2_t28.mkv	2.841.209.361
S02E20-Friends_Season_2_Disc_2_t27.mkv	2.823.454.139
S02E21-Friends_Season_2_Disc_2_t26.mkv	2.866.957.126
S02E22-Friends_Season_2_Disc_2_t25.mkv	2.838.697.169
S02E23-Friends_Season_2_Disc_2_t24.mkv	2.832.878.913
S02E24-Friends_Season_2_Disc_2_t17.mkv	2.829.538.316
S03E01-Friends_Season_3_Disc_1_t22.mkv	2.864.027.902
S03E02-Friends_Season_3_Disc_1_t20.mkv	2.881.287.799
S03E03-Friends_Season_3_Disc_1_t23.mkv	2.875.984.870
S03E04-Friends_Season_3_Disc_1_t17.mkv	2.882.967.583
S03E05-Friends_Season_3_Disc_1_t07.mkv	2.875.296.616
S03E06-Friends_Season_3_Disc_1_t03.mkv	2.865.912.064
S03E07-Friends_Season_3_Disc_1_t21.mkv	2.877.173.256
S03E08-Friends_Season_3_Disc_1_t02.mkv	2.873.736.961
S03E09-Friends_Season_3_Disc_1_t01.mkv	2.874.918.060
S03E10-Friends_Season_3_Disc_1_t00.mkv	2.880.536.943
S03E11-Friends_Season_3_Disc_1_t25.mkv	2.882.040.472
S03E12-Friends_Season_3_Disc_1_t05.mkv	2.872.821.198
S03E13-Friends_Season_3_Disc_2_t04.mkv	2.873.260.150
S03E14-Friends_Season_3_Disc_2_t03.mkv	2.873.401.539
S03E15-Friends_Season_3_Disc_2_t02.mkv	2.859.194.022
S03E16-Friends_Season_3_Disc_2_t01.mkv	2.911.921.109
S03E17-Friends_Season_3_Disc_2_t00.mkv	2.880.547.337
S03E18-Friends_Season_3_Disc_2_t32.mkv	2.874.050.977
S03E19-Friends_Season_3_Disc_2_t31.mkv	2.866.858.631
S03E20-Friends_Season_3_Disc_2_t30.mkv	2.877.955.483
S03E21-Friends_Season_3_Disc_2_t27.mkv	2.877.233.603
S03E22-Friends_Season_3_Disc_2_t26.mkv	2.863.488.369
S03E23-Friends_Season_3_Disc_2_t06.mkv	2.877.139.356
S03E24-Friends_Season_3_Disc_2_t08.mkv	2.869.496.931
S03E25-Friends_Season_3_Disc_2_t07.mkv	2.866.427.543
S04E01-Friends_Season_4_Disc_1_t05.mkv	2.826.908.681
S04E02-Friends_Season_4_Disc_1_t03.mkv	2.779.549.631
S04E03-Friends_Season_4_Disc_1_t02.mkv	2.771.931.782
S04E04-Friends_Season_4_Disc_1_t01.mkv	2.765.915.313
S04E05-Friends_Season_4_Disc_1_t00.mkv	2.766.321.355
S04E06-Friends_Season_4_Disc_1_t28.mkv	2.800.451.908
S04E07-Friends_Season_4_Disc_1_t16.mkv	2.764.250.379
S04E08-Friends_Season_4_Disc_1_t15.mkv	2.835.077.739
S04E09-Friends_Season_4_Disc_1_t14.mkv	2.782.802.358
S04E10-Friends_Season_4_Disc_1_t11.mkv	2.777.780.188
S04E11-Friends_Season_4_Disc_1_t06.mkv	2.775.329.765
S04E12-Friends_Season_4_Disc_1_t07.mkv	2.773.362.623
S04E13-Friends_Season_4_Disc_2_t11.mkv	2.773.274.952
S04E14-Friends_Season_4_Disc_2_t07.mkv	2.775.477.991
S04E15-Friends_Season_4_Disc_2_t06.mkv	2.772.837.024
S04E16-Friends_Season_4_Disc_2_t02.mkv	2.763.884.611
S04E17-Friends_Season_4_Disc_2_t00.mkv	2.767.449.146
S04E18-Friends_Season_4_Disc_2_t32.mkv	2.777.210.725
S04E19-Friends_Season_4_Disc_2_t29.mkv	2.764.221.172
S04E20-Friends_Season_4_Disc_2_t28.mkv	2.767.439.881
S04E21-Friends_Season_4_Disc_2_t27.mkv	2.772.187.214
S04E22-Friends_Season_4_Disc_2_t26.mkv	2.782.573.342
S04E23-Friends_Season_4_Disc_2_t21.mkv	2.780.873.063
S04E24-Friends_Season_4_Disc_2_t22.mkv	2.764.982.026
S05E01-Friends_Season_5_Disc_1_t25.mkv	2.762.006.768
S05E02-Friends_Season_5_Disc_1_t18.mkv	2.766.775.513
S05E03-Friends_Season_5_Disc_1_t16.mkv	2.763.136.181
S05E04-Friends_Season_5_Disc_1_t14.mkv	2.766.594.554
S05E05-Friends_Season_5_Disc_1_t13.mkv	2.765.380.630
S05E06-Friends_Season_5_Disc_1_t10.mkv	2.768.139.179
S05E07-Friends_Season_5_Disc_1_t09.mkv	2.761.897.912
S05E08-Friends_Season_5_Disc_1_t05.mkv	2.767.697.529
S05E09-Friends_Season_5_Disc_1_t03.mkv	2.771.448.225
S05E10-Friends_Season_5_Disc_1_t02.mkv	2.774.913.375
S05E11-Friends_Season_5_Disc_1_t12.mkv	2.765.453.754
S05E12-Friends_Season_5_Disc_1_t11.mkv	2.770.702.332
S05E13-Friends_Season_5_Disc_2_t05.mkv	2.767.258.208
S05E14-Friends_Season_5_Disc_2_t03.mkv	2.766.869.908
S05E15-Friends_Season_5_Disc_2_t02.mkv	2.767.152.583
S05E16-Friends_Season_5_Disc_2_t01.mkv	2.753.627.695
S05E17-Friends_Season_5_Disc_2_t00.mkv	2.768.465.782
S05E18-Friends_Season_5_Disc_2_t28.mkv	2.776.365.812
S05E19-Friends_Season_5_Disc_2_t27.mkv	2.773.407.557
S05E20-Friends_Season_5_Disc_2_t26.mkv	2.771.033.108
S05E21-Friends_Season_5_Disc_2_t25.mkv	2.774.641.975
S05E22-Friends_Season_5_Disc_2_t24.mkv	2.764.789.902
S05E23-Friends_Season_5_Disc_2_t20.mkv	2.763.328.408
S05E24-Friends_Season_5_Disc_2_t21.mkv	2.755.703.779
S06E01-Friends_Season_6_Disc_1_t21.mkv	2.758.562.458
S06E02-Friends_Season_6_Disc_1_t17.mkv	2.745.353.529
S06E03-Friends_Season_6_Disc_1_t15.mkv	2.749.416.034
S06E04-Friends_Season_6_Disc_1_t13.mkv	2.738.180.083
S06E05-Friends_Season_6_Disc_1_t12.mkv	2.744.241.887
S06E06-Friends_Season_6_Disc_1_t09.mkv	2.741.845.987
S06E07-Friends_Season_6_Disc_1_t20.mkv	2.738.441.599
S06E08-Friends_Season_6_Disc_1_t08.mkv	2.711.755.898
S06E09-Friends_Season_6_Disc_1_t01.mkv	2.830.414.875
S06E10-Friends_Season_6_Disc_1_t00.mkv	2.736.951.268
S06E11-Friends_Season_6_Disc_1_t11.mkv	2.740.348.445
S06E12-Friends_Season_6_Disc_1_t10.mkv	2.742.982.128
S06E13-Friends_Season_6_Disc_2_t07.mkv	2.716.783.301
S06E14-Friends_Season_6_Disc_2_t03.mkv	2.752.806.612
S06E15-Friends_Season_6_Disc_2_t02.mkv	2.734.551.358
S06E16-Friends_Season_6_Disc_2_t01.mkv	2.730.833.553
S06E17-Friends_Season_6_Disc_2_t00.mkv	2.730.946.892
S06E18-Friends_Season_6_Disc_2_t34.mkv	2.743.154.900
S06E19-Friends_Season_6_Disc_2_t33.mkv	2.717.471.743
S06E20-Friends_Season_6_Disc_2_t32.mkv	2.739.511.890
S06E21-Friends_Season_6_Disc_2_t31.mkv	2.774.120.683
S06E22-Friends_Season_6_Disc_2_t30.mkv	2.755.916.064
S06E23-Friends_Season_6_Disc_2_t11.mkv	2.765.876.436
S06E24-Friends_Season_6_Disc_2_t12.mkv	2.734.597.344
S06E25-Friends_Season_6_Disc_2_t10.mkv	2.733.301.799
S07E01-Friends_Season_7_Disc_1_t12.mkv	2.741.822.108
S07E02-Friends_Season_7_Disc_1_t11.mkv	2.739.024.637
S07E03-Friends_Season_7_Disc_1_t10.mkv	2.662.625.308
S07E04-Friends_Season_7_Disc_1_t09.mkv	2.741.176.530
S07E05-Friends_Season_7_Disc_1_t08.mkv	2.742.299.977
S07E06-Friends_Season_7_Disc_1_t07.mkv	2.738.021.807
S07E07-Friends_Season_7_Disc_1_t06.mkv	2.741.988.930
S07E08-Friends_Season_7_Disc_1_t05.mkv	2.741.461.987
S07E09-Friends_Season_7_Disc_1_t04.mkv	2.738.522.687
S07E10-Friends_Season_7_Disc_1_t03.mkv	2.738.138.317
S07E11-Friends_Season_7_Disc_1_t02.mkv	2.747.275.546
S07E12-Friends_Season_7_Disc_1_t01.mkv	2.724.005.271
S07E13-Friends_Season_7_Disc_2_t12.mkv	2.743.597.405
S07E14-Friends_Season_7_Disc_2_t11.mkv	2.732.947.554
S07E15-Friends_Season_7_Disc_2_t09.mkv	2.802.442.087
S07E16-Friends_Season_7_Disc_2_t08.mkv	2.738.984.391
S07E17-Friends_Season_7_Disc_2_t07.mkv	2.738.938.259
S07E18-Friends_Season_7_Disc_2_t06.mkv	2.745.097.289
S07E19-Friends_Season_7_Disc_2_t05.mkv	2.742.785.606
S07E20-Friends_Season_7_Disc_2_t04.mkv	2.747.026.985
S07E21-Friends_Season_7_Disc_2_t03.mkv	2.725.761.455
S07E22-Friends_Season_7_Disc_2_t02.mkv	2.736.421.048
S07E23-Friends_Season_7_Disc_2_t01.mkv	2.741.734.388
S07E24-Friends_Season_7_Disc_2_t00.mkv	2.734.786.559
S08E01-Friends_Season_8_Disc_1_t16.mkv	2.803.703.336
S08E02-Friends_Season_8_Disc_1_t15.mkv	2.739.577.991
S08E03-Friends_Season_8_Disc_1_t14.mkv	2.744.409.235
S08E04-Friends_Season_8_Disc_1_t13.mkv	2.802.904.653
S08E05-Friends_Season_8_Disc_1_t01.mkv	2.748.211.525
S08E06-Friends_Season_8_Disc_1_t28.mkv	2.744.480.858
S08E07-Friends_Season_8_Disc_1_t24.mkv	2.743.212.141
S08E08-Friends_Season_8_Disc_1_t23.mkv	2.725.865.291
S08E09-Friends_Season_8_Disc_1_t22.mkv	2.748.151.812
S08E10-Friends_Season_8_Disc_1_t21.mkv	2.751.668.716
S08E11-Friends_Season_8_Disc_1_t20.mkv	2.746.654.384
S08E12-Friends_Season_8_Disc_1_t19.mkv	2.745.962.462
S08E13-Friends_Season_8_Disc_2_t24.mkv	2.701.357.555
S08E14-Friends_Season_8_Disc_2_t23.mkv	2.741.646.136
S08E15-Friends_Season_8_Disc_2_t22.mkv	2.742.400.668
S08E16-Friends_Season_8_Disc_2_t08.mkv	2.630.099.648
S08E17-Friends_Season_8_Disc_2_t21.mkv	2.736.717.445
S08E18-Friends_Season_8_Disc_2_t20.mkv	2.745.046.925
S08E19-Friends_Season_8_Disc_2_t19.mkv	2.741.694.440
S08E20-Friends_Season_8_Disc_2_t07.mkv	2.754.686.504
S08E21-Friends_Season_8_Disc_2_t18.mkv	2.746.070.127
S08E22-Friends_Season_8_Disc_2_t06.mkv	2.742.164.162
S08E23-Friends_Season_8_Disc_2_t05.mkv	2.743.621.299
S08E24-Friends_Season_8_Disc_2_t04.mkv	2.734.918.688
S09E01-Friends_Season_9_Disc_1_t23.mkv	2.901.576.923
S09E02-Friends_Season_9_Disc_1_t21.mkv	2.884.249.666
S09E03-Friends_Season_9_Disc_1_t24.mkv	2.906.452.152
S09E04-Friends_Season_9_Disc_1_t20.mkv	2.905.192.631
S09E05-Friends_Season_9_Disc_1_t10.mkv	2.909.692.632
S09E06-Friends_Season_9_Disc_1_t06.mkv	3.993.275.459
S09E07-Friends_Season_9_Disc_1_t22.mkv	2.913.629.377
S09E08-Friends_Season_9_Disc_1_t03.mkv	3.163.732.009
S09E09-Friends_Season_9_Disc_1_t02.mkv	2.895.307.026
S09E10-Friends_Season_9_Disc_1_t01.mkv	2.903.320.606
S09E11-Friends_Season_9_Disc_1_t26.mkv	2.911.338.990
S09E12-Friends_Season_9_Disc_1_t08.mkv	2.908.553.753
S09E13-Friends_Season_9_Disc_2_t21.mkv	3.853.500.840
S09E14-Friends_Season_9_Disc_2_t19.mkv	2.918.889.078
S09E15-Friends_Season_9_Disc_2_t17.mkv	2.850.012.684
S09E16-Friends_Season_9_Disc_2_t15.mkv	2.909.583.544
S09E17-Friends_Season_9_Disc_2_t06.mkv	2.994.209.315
S09E18-Friends_Season_9_Disc_2_t03.mkv	2.849.783.931
S09E19-Friends_Season_9_Disc_2_t20.mkv	3.038.005.673
S09E20-Friends_Season_9_Disc_2_t02.mkv	2.993.554.733
S09E21-Friends_Season_9_Disc_2_t01.mkv	3.373.355.194
S09E22-Friends_Season_9_Disc_2_t00.mkv	3.084.534.205
S09E23E24-Friends_Season_9_Disc_2_t23.mkv   6.264.631.173
S10E01-Friends_Season_10_Disc_1_t20.mkv	3.699.303.143
S10E02-Friends_Season_10_Disc_1_t17.mkv	3.028.004.847
S10E03-Friends_Season_10_Disc_1_t15.mkv	3.053.839.228
S10E04-Friends_Season_10_Disc_1_t12.mkv	2.904.254.643
S10E05-Friends_Season_10_Disc_1_t11.mkv	3.568.711.279
S10E06-Friends_Season_10_Disc_1_t08.mkv	3.094.055.099
S10E07-Friends_Season_10_Disc_1_t19.mkv	2.934.247.833
S10E08-Friends_Season_10_Disc_1_t07.mkv	2.925.324.432
S10E09-Friends_Season_10_Disc_1_t01.mkv	3.140.339.247
S10E10-Friends_Season_10_Disc_1_t00.mkv	2.902.188.141
S10E11-Friends_Season_10_Disc_1_t10.mkv	3.480.527.640
S10E12-Friends_Season_10_Disc_1_t09.mkv	3.739.371.002
S10E13-Friends_Season_10_Disc_2_t05.mkv	2.980.044.985
S10E14-Friends_Season_10_Disc_2_t04.mkv	2.933.097.969
S10E15-Friends_Season_10_Disc_2_t02.mkv	2.915.422.009
S10E16-Friends_Season_10_Disc_2_t01.mkv	2.875.505.238
S10E17E18-Friends_Season_10_Disc_2_t00.mkv   5.994.778.200
JUSTANOTHERARCHIVER
Post by JUSTANOTHERARCHIVER »
For those that get the files with only one _ near the need, and have the funky disc 2, this one is for you <3
I also updated the py script to make/update a log of what it did in case something goes wrong. Couldn't help myself haha!
Big thanks to everyone else over the years that made this happen.
EDIT: to add bonus disc contents to dictionary.
import os
import logging
# Configure logging in 'append' mode
logging.basicConfig(filename='rename_log.txt', level=logging.INFO, format='%(asctime)s - %(levelname)s: %(message)s', filemode='a')
mydict = {}
# Load the dictionary from 'dictionary.txt'
with open('dictionary.txt', 'r') as dict_file:
    for line in dict_file:
        line = line.strip()
        split_line = line.split('|')
        mydict[split_line[1]] = split_line[0]
# List all files in the current directory
fnames = os.listdir('.')
for fname in fnames:
    if fname in mydict:
        new_filename = mydict[fname] + '.mkv'
        # Check if the new filename already exists
        if not os.path.exists(new_filename):
            try:
                os.rename(fname, new_filename)
                logging.info(f'Renamed: {fname} to {new_filename}')
                print(f'Renamed: {fname} to {new_filename}')
            except OSError as e:
                logging.error(f"Error renaming {fname}: {e}")
                print(f"Error renaming {fname}: {e}")
        else:
            logging.warning(f"File '{new_filename}' already exists, skipping.")
            print(f"File '{new_filename}' already exists, skipping.")
s01e01|Friends Season 1 Disc 1_t04.mkv
s01e02|Friends Season 1 Disc 1_t03.mkv
s01e03|Friends Season 1 Disc 1_t02.mkv
s01e04|Friends Season 1 Disc 1_t01.mkv
s01e05|Friends Season 1 Disc 1_t00.mkv
s01e06|Friends Season 1 Disc 1_t26.mkv
s01e07|Friends Season 1 Disc 1_t25.mkv
s01e08|Friends Season 1 Disc 1_t24.mkv
s01e09|Friends Season 1 Disc 1_t23.mkv
s01e10|Friends Season 1 Disc 1_t22.mkv
s01e11|Friends Season 1 Disc 1_t11.mkv
s01e12|Friends Season 1 Disc 1_t19.mkv
s01e13|Friends Season 1 Disc 2_t04.mkv
s01e14|Friends Season 1 Disc 2_t03.mkv
s01e15|Friends Season 1 Disc 2_t02.mkv
s01e16|Friends Season 1 Disc 2_t01.mkv
s01e17|Friends Season 1 Disc 2_t00.mkv
s01e18|Friends Season 1 Disc 2_t26.mkv
s01e19|Friends Season 1 Disc 2_t25.mkv
s01e20|Friends Season 1 Disc 2_t24.mkv
s01e21|Friends Season 1 Disc 2_t23.mkv
s01e22|Friends Season 1 Disc 2_t20.mkv
s01e23|Friends Season 1 Disc 2_t06.mkv
s01e24|Friends Season 1 Disc 2_t07.mkv
s02e01|Friends Season 2 Disc 1_t07.mkv
s02e02|Friends Season 2 Disc 1_t14.mkv
s02e03|Friends Season 2 Disc 1_t13.mkv
s02e04|Friends Season 2 Disc 1_t12.mkv
s02e05|Friends Season 2 Disc 1_t11.mkv
s02e06|Friends Season 2 Disc 1_t10.mkv
s02e07|Friends Season 2 Disc 1_t09.mkv
s02e08|Friends Season 2 Disc 1_t08.mkv
s02e09|Friends Season 2 Disc 1_t03.mkv
s02e10|Friends Season 2 Disc 1_t01.mkv
s02e11|Friends Season 2 Disc 1_t00.mkv
s02e12|Friends Season 2 Disc 1_t02.mkv
s02e13|Friends Season 2 Disc 1_t06.mkv
s02e14|Friends Season 2 Disc 2_t15.mkv
s02e15|Friends Season 2 Disc 2_t12.mkv
s02e16|Friends Season 2 Disc 2_t06.mkv
s02e17|Friends Season 2 Disc 2_t01.mkv
s02e18|Friends Season 2 Disc 2_t00.mkv
s02e19|Friends Season 2 Disc 2_t28.mkv
s02e20|Friends Season 2 Disc 2_t27.mkv
s02e21|Friends Season 2 Disc 2_t26.mkv
s02e22|Friends Season 2 Disc 2_t25.mkv
s02e23|Friends Season 2 Disc 2_t24.mkv
s02e24|Friends Season 2 Disc 2_t17.mkv
s03e01|Friends Season 3 Disc 1_t22.mkv
s03e02|Friends Season 3 Disc 1_t20.mkv
s03e03|Friends Season 3 Disc 1_t23.mkv
s03e04|Friends Season 3 Disc 1_t17.mkv
s03e05|Friends Season 3 Disc 1_t07.mkv
s03e06|Friends Season 3 Disc 1_t03.mkv
s03e07|Friends Season 3 Disc 1_t21.mkv
s03e08|Friends Season 3 Disc 1_t02.mkv
s03e09|Friends Season 3 Disc 1_t01.mkv
s03e10|Friends Season 3 Disc 1_t00.mkv
s03e11|Friends Season 3 Disc 1_t25.mkv
s03e12|Friends Season 3 Disc 1_t05.mkv
s03e13|Friends Season 3 Disc 2_t04.mkv
s03e14|Friends Season 3 Disc 2_t03.mkv
s03e15|Friends Season 3 Disc 2_t02.mkv
s03e16|Friends Season 3 Disc 2_t01.mkv
s03e17|Friends Season 3 Disc 2_t00.mkv
s03e18|Friends Season 3 Disc 2_t32.mkv
s03e19|Friends Season 3 Disc 2_t31.mkv
s03e20|Friends Season 3 Disc 2_t30.mkv
s03e21|Friends Season 3 Disc 2_t27.mkv
s03e22|Friends Season 3 Disc 2_t26.mkv
s03e23|Friends Season 3 Disc 2_t06.mkv
s03e24|Friends Season 3 Disc 2_t08.mkv
s03e25|Friends Season 3 Disc 2_t07.mkv
s04e01|Friends Season 4 Disc 1_t05.mkv
s04e02|Friends Season 4 Disc 1_t03.mkv
s04e03|Friends Season 4 Disc 1_t02.mkv
s04e04|Friends Season 4 Disc 1_t01.mkv
s04e05|Friends Season 4 Disc 1_t00.mkv
s04e06|Friends Season 4 Disc 1_t28.mkv
s04e07|Friends Season 4 Disc 1_t16.mkv
s04e08|Friends Season 4 Disc 1_t15.mkv
s04e09|Friends Season 4 Disc 1_t14.mkv
s04e10|Friends Season 4 Disc 1_t11.mkv
s04e11|Friends Season 4 Disc 1_t06.mkv
s04e12|Friends Season 4 Disc 1_t07.mkv
s04e13|Friends Season 4 Disc 2_t11.mkv
s04e14|Friends Season 4 Disc 2_t07.mkv
s04e15|Friends Season 4 Disc 2_t06.mkv
s04e16|Friends Season 4 Disc 2_t02.mkv
s04e17|Friends Season 4 Disc 2_t00.mkv
s04e18|Friends Season 4 Disc 2_t32.mkv
s04e19|Friends Season 4 Disc 2_t29.mkv
s04e20|Friends Season 4 Disc 2_t28.mkv
s04e21|Friends Season 4 Disc 2_t27.mkv
s04e22|Friends Season 4 Disc 2_t26.mkv
s04e23|Friends Season 4 Disc 2_t21.mkv
s04e24|Friends Season 4 Disc 2_t22.mkv
s05e01|Friends Season 5 Disc 1_t25.mkv
s05e02|Friends Season 5 Disc 1_t18.mkv
s05e03|Friends Season 5 Disc 1_t16.mkv
s05e04|Friends Season 5 Disc 1_t14.mkv
s05e05|Friends Season 5 Disc 1_t13.mkv
s05e06|Friends Season 5 Disc 1_t10.mkv
s05e07|Friends Season 5 Disc 1_t09.mkv
s05e08|Friends Season 5 Disc 1_t05.mkv
s05e09|Friends Season 5 Disc 1_t03.mkv
s05e10|Friends Season 5 Disc 1_t02.mkv
s05e11|Friends Season 5 Disc 1_t12.mkv
s05e12|Friends Season 5 Disc 1_t11.mkv
s05e13|Friends Season 5 Disc 2_t05.mkv
s05e14|Friends Season 5 Disc 2_t03.mkv
s05e15|Friends Season 5 Disc 2_t02.mkv
s05e16|Friends Season 5 Disc 2_t01.mkv
s05e17|Friends Season 5 Disc 2_t00.mkv
s05e18|Friends Season 5 Disc 2_t28.mkv
s05e19|Friends Season 5 Disc 2_t27.mkv
s05e20|Friends Season 5 Disc 2_t26.mkv
s05e21|Friends Season 5 Disc 2_t25.mkv
s05e22|Friends Season 5 Disc 2_t24.mkv
s05e23|Friends Season 5 Disc 2_t20.mkv
s05e24|Friends Season 5 Disc 2_t21.mkv
s06e01|Friends Season 6 Disc 1_t21.mkv
s06e02|Friends Season 6 Disc 1_t17.mkv
s06e03|Friends Season 6 Disc 1_t15.mkv
s06e04|Friends Season 6 Disc 1_t13.mkv
s06e05|Friends Season 6 Disc 1_t12.mkv
s06e06|Friends Season 6 Disc 1_t09.mkv
s06e07|Friends Season 6 Disc 1_t20.mkv
s06e08|Friends Season 6 Disc 1_t08.mkv
s06e09|Friends Season 6 Disc 1_t01.mkv
s06e10|Friends Season 6 Disc 1_t00.mkv
s06e11|Friends Season 6 Disc 1_t11.mkv
s06e12|Friends Season 6 Disc 1_t10.mkv
s06e13|Friends Season 6 Disc 2_t07.mkv
s06e14|Friends Season 6 Disc 2_t03.mkv
s06e15|Friends Season 6 Disc 2_t02.mkv
s06e16|Friends Season 6 Disc 2_t01.mkv
s06e17|Friends Season 6 Disc 2_t00.mkv
s06e18|Friends Season 6 Disc 2_t34.mkv
s06e19|Friends Season 6 Disc 2_t33.mkv
s06e20|Friends Season 6 Disc 2_t32.mkv
s06e21|Friends Season 6 Disc 2_t31.mkv
s06e22|Friends Season 6 Disc 2_t30.mkv
s06e23|Friends Season 6 Disc 2_t11.mkv
s06e24|Friends Season 6 Disc 2_t12.mkv
s06e25|Friends Season 6 Disc 2_t10.mkv
s07e01|Friends Season 7 Disc 1_t12.mkv
s07e02|Friends Season 7 Disc 1_t11.mkv
s07e03|Friends Season 7 Disc 1_t10.mkv
s07e04|Friends Season 7 Disc 1_t09.mkv
s07e05|Friends Season 7 Disc 1_t08.mkv
s07e06|Friends Season 7 Disc 1_t07.mkv
s07e07|Friends Season 7 Disc 1_t06.mkv
s07e08|Friends Season 7 Disc 1_t05.mkv
s07e09|Friends Season 7 Disc 1_t04.mkv
s07e10|Friends Season 7 Disc 1_t03.mkv
s07e11|Friends Season 7 Disc 1_t02.mkv
s07e12|Friends Season 7 Disc 1_t01.mkv
s07e13|Friends Season 7 Disc 2_t12.mkv
s07e14|Friends Season 7 Disc 2_t11.mkv
s07e15|Friends Season 7 Disc 2_t09.mkv
s07e16|Friends Season 7 Disc 2_t08.mkv
s07e17|Friends Season 7 Disc 2_t07.mkv
s07e18|Friends Season 7 Disc 2_t06.mkv
s07e19|Friends Season 7 Disc 2_t05.mkv
s07e20|Friends Season 7 Disc 2_t04.mkv
s07e21|Friends Season 7 Disc 2_t03.mkv
s07e22|Friends Season 7 Disc 2_t02.mkv
s07e23|Friends Season 7 Disc 2_t01.mkv
s07e24|Friends Season 7 Disc 2_t00.mkv
s08e01|Friends Season 8 Disc 1_t16.mkv
s08e02|Friends Season 8 Disc 1_t15.mkv
s08e03|Friends Season 8 Disc 1_t14.mkv
s08e04|Friends Season 8 Disc 1_t13.mkv
s08e05|Friends Season 8 Disc 1_t01.mkv
s08e06|Friends Season 8 Disc 1_t28.mkv
s08e07|Friends Season 8 Disc 1_t24.mkv
s08e08|Friends Season 8 Disc 1_t23.mkv
s08e09|Friends Season 8 Disc 1_t22.mkv
s08e10|Friends Season 8 Disc 1_t21.mkv
s08e11|Friends Season 8 Disc 1_t20.mkv
s08e12|Friends Season 8 Disc 1_t19.mkv
s08e13|Friends Season 8 Disc 2_t24.mkv
s08e14|Friends Season 8 Disc 2_t23.mkv
s08e15|Friends Season 8 Disc 2_t22.mkv
s08e16|Friends Season 8 Disc 2_t08.mkv
s08e17|Friends Season 8 Disc 2_t21.mkv
s08e18|Friends Season 8 Disc 2_t20.mkv
s08e19|Friends Season 8 Disc 2_t19.mkv
s08e20|Friends Season 8 Disc 2_t07.mkv
s08e21|Friends Season 8 Disc 2_t18.mkv
s08e22|Friends Season 8 Disc 2_t06.mkv
s08e23|Friends Season 8 Disc 2_t05.mkv
s08e24|Friends Season 8 Disc 2_t04.mkv
s09e01|Friends Season 9 Disc 1_t23.mkv
s09e02|Friends Season 9 Disc 1_t21.mkv
s09e03|Friends Season 9 Disc 1_t24.mkv
s09e04|Friends Season 9 Disc 1_t20.mkv
s09e05|Friends Season 9 Disc 1_t10.mkv
s09e06|Friends Season 9 Disc 1_t06.mkv
s09e07|Friends Season 9 Disc 1_t22.mkv
s09e08|Friends Season 9 Disc 1_t03.mkv
s09e09|Friends Season 9 Disc 1_t02.mkv
s09e10|Friends Season 9 Disc 1_t01.mkv
s09e11|Friends Season 9 Disc 1_t26.mkv
s09e12|Friends Season 9 Disc 1_t08.mkv
s09e13|Friends Season 9 Disc 2_t21.mkv
s09e14|Friends Season 9 Disc 2_t19.mkv
s09e15|Friends Season 9 Disc 2_t17.mkv
s09e16|Friends Season 9 Disc 2_t15.mkv
s09e17|Friends Season 9 Disc 2_t06.mkv
s09e18|Friends Season 9 Disc 2_t03.mkv
s09e19|Friends Season 9 Disc 2_t20.mkv
s09e20|Friends Season 9 Disc 2_t02.mkv
s09e21|Friends Season 9 Disc 2_t01.mkv
s09e22|Friends Season 9 Disc 2_t00.mkv
s09e23|Friends Season 9 Disc 2_t23.mkv
s10e01|Friends Season 10 Disc 1_t20.mkv
s10e02|Friends Season 10 Disc 1_t17.mkv
s10e03|Friends Season 10 Disc 1_t15.mkv
s10e04|Friends Season 10 Disc 1_t12.mkv
s10e05|Friends Season 10 Disc 1_t11.mkv
s10e06|Friends Season 10 Disc 1_t08.mkv
s10e07|Friends Season 10 Disc 1_t19.mkv
s10e08|Friends Season 10 Disc 1_t07.mkv
s10e09|Friends Season 10 Disc 1_t01.mkv
s10e10|Friends Season 10 Disc 1_t00.mkv
s10e11|Friends Season 10 Disc 1_t10.mkv
s10e12|Friends Season 10 Disc 1_t09.mkv
s10e13|Friends Season 10 Disc 2_t05.mkv
s10e14|Friends Season 10 Disc 2_t04.mkv
s10e15|Friends Season 10 Disc 2_t02.mkv
s10e16|Friends Season 10 Disc 2_t01.mkv
s10e17|Friends Season 10 Disc 2_t00.mkv
Original Script - The One Where Rachel Tells Ross|Friends- The Complete Series Bonus Disc_t00.mkv
Producers Cut (Original Script)- The One Where Rachel Tells Ross|Friends- The Complete Series Bonus Disc_t05.mkv
When Friends Became Family|Friends- The Complete Series Bonus Disc_t06.mkv
Friends from the Start|Friends- The Complete Series Bonus Disc_t04.mkv
Friends on The Tonight Show with Jay Leno|Friends- The Complete Series Bonus Disc_t08.mkv
The Rembrants - I'll Be There For You - Official Music Video Featuring the Cast of Friends|Friends- The Complete Series Bonus Disc_t09.mkv
The Legacy of Friends|Friends- The Complete Series Bonus Disc_t10.mkv
Friends Visit The Ellen DeGeneres Show|Friends- The Complete Series Bonus Disc_t11.mkv
The One with the Never-Before-Seen Gags|Friends- The Complete Series Bonus Disc_t12.mkv
Output log example:
2023-09-18 12:01:44,281 - INFO: Renamed: Friends Season 2 Disc 1_t00.mkv to s02e11.mkv
2023-09-18 12:01:44,322 - INFO: Renamed: Friends Season 2 Disc 1_t01.mkv to s02e10.mkv
2023-09-18 12:01:44,374 - INFO: Renamed: Friends Season 2 Disc 1_t02.mkv to s02e12.mkv
2023-09-18 12:01:44,430 - INFO: Renamed: Friends Season 2 Disc 1_t03.mkv to s02e09.mkv
2023-09-18 12:01:44,504 - INFO: Renamed: Friends Season 2 Disc 1_t06.mkv to s02e13.mkv
2023-09-18 12:01:44,552 - INFO: Renamed: Friends Season 2 Disc 1_t07.mkv to s02e01.mkv
2023-09-18 12:01:44,597 - INFO: Renamed: Friends Season 2 Disc 1_t08.mkv to s02e08.mkv
2023-09-18 12:01:44,668 - INFO: Renamed: Friends Season 2 Disc 1_t09.mkv to s02e07.mkv
2023-09-18 12:01:44,734 - INFO: Renamed: Friends Season 2 Disc 1_t10.mkv to s02e06.mkv
2023-09-18 12:01:44,797 - INFO: Renamed: Friends Season 2 Disc 1_t11.mkv to s02e05.mkv
2023-09-18 12:01:44,867 - INFO: Renamed: Friends Season 2 Disc 1_t12.mkv to s02e04.mkv
2023-09-18 12:01:44,909 - INFO: Renamed: Friends Season 2 Disc 1_t13.mkv to s02e03.mkv
2023-09-18 12:01:44,946 - INFO: Renamed: Friends Season 2 Disc 1_t14.mkv to s02e02.mkv
2023-09-18 12:48:00,709 - INFO: Renamed: Friends Season 2 Disc 2_t00.mkv to s02e18.mkv
2023-09-18 12:48:00,803 - INFO: Renamed: Friends Season 2 Disc 2_t01.mkv to s02e17.mkv
2023-09-18 12:48:00,872 - INFO: Renamed: Friends Season 2 Disc 2_t06.mkv to s02e16.mkv
2023-09-18 12:48:01,218 - INFO: Renamed: Friends Season 2 Disc 2_t12.mkv to s02e15.mkv
2023-09-18 12:48:01,271 - INFO: Renamed: Friends Season 2 Disc 2_t15.mkv to s02e14.mkv
2023-09-18 12:48:01,322 - INFO: Renamed: Friends Season 2 Disc 2_t17.mkv to s02e24.mkv
2023-09-18 12:48:01,456 - INFO: Renamed: Friends Season 2 Disc 2_t24.mkv to s02e23.mkv
2023-09-18 12:48:01,567 - INFO: Renamed: Friends Season 2 Disc 2_t25.mkv to s02e22.mkv
2023-09-18 12:48:01,687 - INFO: Renamed: Friends Season 2 Disc 2_t26.mkv to s02e21.mkv
2023-09-18 12:48:01,799 - INFO: Renamed: Friends Season 2 Disc 2_t27.mkv to s02e20.mkv
2023-09-18 12:48:01,929 - INFO: Renamed: Friends Season 2 Disc 2_t28.mkv to s02e19.mkv
2023-09-18 16:49:34,095 - ERROR: Error renaming Friends Season 5 Disc 1_t25.mkv: [WinError 32] The process cannot access the file because it is being used by another process: 'Friends Season 5 Disc 1_t25.mkv' -> 's05e01.mkv'
2023-09-18 16:49:47,354 - ERROR: Error renaming Friends Season 5 Disc 1_t25.mkv: [WinError 32] The process cannot access the file because it is being used by another process: 'Friends Season 5 Disc 1_t25.mkv' -> 's05e01.mkv'
2023-09-18 17:02:32,342 - INFO: Renamed: Friends Season 5 Disc 1_t25.mkv to s05e01.mkv
coldfire05
Post by coldfire05 »
I can't begin to thank you enough for all that leg work you put in, it greatly helped me. But there were a lot of variances that I had to figure out. They must have rearranged many of the episodes from different printings. I just very recently bought mine off Amazon/USA, and I kept a strict log of what you posted and which ones I had to alter from the set I received. So for those that are looking for something more close to what you got if you got your set as I did, I am posting that file here for further assistance.
S01E06-Friends_Season_1_Disc_1_t25.mkv 2.625.938.527
S01E07-Friends_Season_1_Disc_1_t24.mkv 2.835.701.350
S01E08-Friends_Season_1_Disc_1_t23.mkv 2.861.551.153
S01E09-Friends_Season_1_Disc_1_t22.mkv 2.870.442.514
S01E10-Friends_Season_1_Disc_1_t21.mkv 2.874.122.115
S01E18-Friends_Season_1_Disc_2_t23.mkv 2.865.811.406
S01E19-Friends_Season_1_Disc_2_t22.mkv 2.868.492.818
S01E20-Friends_Season_1_Disc_2_t21.mkv 2.869.261.536
S01E21-Friends_Season_1_Disc_2_t20.mkv 2.863.950.780
S01E22-Friends_Season_1_Disc_2_t17.mkv 2.862.630.042
S01E23-Friends_Season_1_Disc_2_t05.mkv 2.867.218.530
S01E24-Friends_Season_1_Disc_2_t06.mkv 2.864.990.630
S02E14-Friends_Season_2_Disc_2_t13.mkv 2.834.460.947
S02E15-Friends_Season_2_Disc_2_t10.mkv 2.827.084.038
S02E19-Friends_Season_2_Disc_2_t21.mkv 2.841.209.361
S02E20-Friends_Season_2_Disc_2_t20.mkv 2.823.454.139
S02E21-Friends_Season_2_Disc_2_t19.mkv 2.866.957.126
S02E22-Friends_Season_2_Disc_2_t18.mkv 2.838.697.169
S02E23-Friends_Season_2_Disc_2_t17.mkv 2.832.878.913
S02E24-Friends_Season_2_Disc_2_t15.mkv 2.829.538.316
S04E06-Friends_Season_4_Disc_1_t27.mkv 2.800.451.908
S04E07-Friends_Season_4_Disc_1_t15.mkv 2.764.250.379
S04E08-Friends_Season_4_Disc_1_t14.mkv 2.835.077.739
S04E09-Friends_Season_4_Disc_1_t13.mkv 2.782.802.358
S04E10-Friends_Season_4_Disc_1_t10.mkv 2.777.780.188
S04E12-Friends_Season_4_Disc_1_t16.mkv 2.773.362.623
S04E13-Friends_Season_4_Disc_2_t07.mkv 2.773.274.952
S04E14-Friends_Season_4_Disc_2_t05.mkv 2.775.477.991
S04E15-Friends_Season_4_Disc_2_t04.mkv 2.772.837.024
S04E16-Friends_Season_4_Disc_2_t01.mkv 2.763.884.611
S04E18-Friends_Season_4_Disc_2_t27.mkv 2.777.210.725
S04E19-Friends_Season_4_Disc_2_t26.mkv 2.764.221.172
S04E20-Friends_Season_4_Disc_2_t20.mkv 2.767.439.881
S04E21-Friends_Season_4_Disc_2_t25.mkv 2.772.187.214
S04E22-Friends_Season_4_Disc_2_t21.mkv 2.782.573.342
S04E23-Friends_Season_4_Disc_2_t09.mkv 2.780.873.063
S04E24-Friends_Season_4_Disc_2_t08.mkv 2.764.982.026
S05E18-Friends_Season_5_Disc_2_t27.mkv 2.776.365.812
S05E19-Friends_Season_5_Disc_2_t26.mkv 2.773.407.557
S05E20-Friends_Season_5_Disc_2_t25.mkv 2.771.033.108
S05E21-Friends_Season_5_Disc_2_t24.mkv 2.774.641.975
S05E22-Friends_Season_5_Disc_2_t23.mkv 2.764.789.902
S06E18-Friends_Season_6_Disc_2_t33.mkv 2.743.154.900
S06E19-Friends_Season_6_Disc_2_t32.mkv 2.717.471.743
S06E20-Friends_Season_6_Disc_2_t31.mkv 2.739.511.890
S06E21-Friends_Season_6_Disc_2_t30.mkv 2.774.120.683
S06E22-Friends_Season_6_Disc_2_t29.mkv 2.755.916.064
S08E06-Friends_Season_8_Disc_1_t27.mkv 2.744.480.858
S08E07-Friends_Season_8_Disc_1_t23.mkv 2.743.212.141
S08E08-Friends_Season_8_Disc_1_t22.mkv 2.725.865.291
S08E09-Friends_Season_8_Disc_1_t21.mkv 2.748.151.812
S08E10-Friends_Season_8_Disc_1_t20.mkv 2.751.668.716
S08E11-Friends_Season_8_Disc_1_t19.mkv 2.746.654.384
S08E12-Friends_Season_8_Disc_1_t18.mkv 2.745.962.462
S08E13-Friends_Season_8_Disc_2_t23.mkv 2.701.357.555
S08E14-Friends_Season_8_Disc_2_t22.mkv 2.741.646.136
S08E15-Friends_Season_8_Disc_2_t21.mkv 2.742.400.668
S08E17-Friends_Season_8_Disc_2_t20.mkv 2.736.717.445
S08E18-Friends_Season_8_Disc_2_t19.mkv 2.745.046.925
S08E19-Friends_Season_8_Disc_2_t18.mkv 2.741.694.440
S08E21-Friends_Season_8_Disc_2_t17.mkv 2.746.070.127
hayabusa
Post by hayabusa »
This is amazing. Thank you.
