Chuck complete series
brewder
Post by brewder »
LONG time MakeMKV user (movies)....Brand new to ripping TV Series. I received Chuck Seasons 1-5 on BD.. In a nutshell, can I just rip the largest file on each disc, then use MKVToolNix to split it up into the individual episodes somehow?
//Brew
thetoad
Re: Chuck complete series
Post by thetoad »
I believe Chuck has individual playlists for each each episode, so you would rip each episode individually (in general, the only releases I've ever seen consistently not behave this way are some Anime releases where there isn't a per episode playlist, just a single one and the menus jump you via chapters to the right spot.
tangent
Post by tangent »
The season 2 disc in the complete series box set I bought has all of its episodes run together into a single title. Here are the commands to break them up into individual episodes:
 mkvmerge -o s2d1-part.mkv --split chapters:08,15,22,29,36 s2d1.mkv
 mkvmerge -o s2d2-part.mkv --split chapters:09,17,24,31,38 s2d2.mkv
 mkvmerge -o s2d3-part.mkv --split chapters:08,15,22,30,37 s2d3.mkv
 mkvmerge -o s2d4-part.mkv --split chapters:09,17,25       s2d4.mkv
ethanisherenow
Post by ethanisherenow »
Hi, Where are you entering this code to make this happen? Just started this process with Chuck
mkvmerge is a command line tool.
RoyWest
Post by RoyWest »
Thanks a lot for the reply! I'm looking for it too
