Cuckoo Waltz series Region 2 dvd won't open (log included)
willavery
Post by willavery »
MakeMKV isn't opening DVDs from the The Cuckoo Waltz complete series set. Is there an option for this error besides swapping my (currently set to R1) DVD drive to region 2? Make MKV has been able to rip other Region 2 dvds without too much issue, including other discs from this production company (Network).
Log below took just over an hour to officially fail. It has also failed multiple times while trying to open manually.
Title #1 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 was added (5 cell(s), 0:24:08)
Title #3 was added (5 cell(s), 0:23:43)
Title #4 was added (5 cell(s), 0:23:50)
Title #5 was added (5 cell(s), 0:23:28)
Title #6 was added (5 cell(s), 0:25:14)
Title #7 was added (5 cell(s), 0:24:02)
Title #8 was added (5 cell(s), 0:25:20)
Region setting of drive Optiarc:DVD RW AD-7585H does not match the region of currently inserted disc, trying to work around...
DEBUG: Code 2 at Ny:E19O7S_z'1:121263682
DEBUG: Code 2 at =pXKGcQ9ULVXC|Wk%[:121272882
DEBUG: Code 0 at 4/o4"*.Z||[K!1J`:213142335
DEBUG: Code 0 at 4/o4"*.Z||[K!1J`:29397978
DEBUG: Code 0 at =pXKGcQ9ULVXC|Wk%[:121246110
DEBUG: Code 0 at QAH7VECSHA-uBX7X:121262578
DEBUG: Code 0 at =}iiJarGd*jf dm:213138494
DEBUG: Code 0 at sg+vC4:"mHe"u/:213134676
DEBUG: Code 3 at Ny:E19O7S_z'1:121263682
DEBUG: Code 3 at =pXKGcQ9ULVXC|Wk%[:121272882
DEBUG: Code 0 at 4/o4"*.Z||[K!1J`:213142036
DEBUG: Code 4 at Ny:E19O7S_z'1:121263682
DEBUG: Code 4 at =pXKGcQ9ULVXC|Wk%[:121272882
DEBUG: Code 5 at Ny:E19O7S_z'1:121263682
DEBUG: Code 5 at =pXKGcQ9ULVXC|Wk%[:121272882
DEBUG: Code 6 at Ny:E19O7S_z'1:121263682
DEBUG: Code 6 at =pXKGcQ9ULVXC|Wk%[:121272882
DEBUG: Code 7 at Ny:E19O7S_z'1:121263682
DEBUG: Code 7 at =pXKGcQ9ULVXC|Wk%[:121272882
DEBUG: Code 8 at Ny:E19O7S_z'1:121263682
DEBUG: Code 8 at =pXKGcQ9ULVXC|Wk%[:121272882
DEBUG: Code 233 at dDYJp8jCUHQ83SS/zA5/ELz0:0
