Gatorman
Post
by Gatorman » Sun Dec 18, 2022 9:18 pm
Draco1544 wrote: Sun Dec 18, 2022 1:17 am
Hi ! Is it possible to use the dovi_script tool of @RESET_9999 to create a Dolby vision profile 8 mkv and not a ts file ?
Certainly, you just need to modify the script by setting the "Choose a muxer" option for tsmuxer.popup to "NO" and mkvtoolnix.popup to "YES". You can set any other ts options to "NO" as well.
Hoosier205
Post
by Hoosier205 » Tue Dec 20, 2022 5:27 pm
thetoad wrote: Sat Dec 17, 2022 10:26 am
Has the firetv cube gen 3 now surpassed the Shield as the best player for DV MKVs as it now supports bitstreaming? It has better DV support, right? (does it use the EL? or also just the RPUs, but better color accuracy?) It doesn't have gigabit ethernet, but the wifi 6E could conceptually compensate for that. I'm wondering what others think.
There is nothing wrong with the Shield. It is still the best option.
Trees
Post
by Trees » Fri Dec 23, 2022 11:07 am
I'm trying to hybrid a HDR10 DCP Rip and a DV RPU. Problem is, they're of by a few frames. Is it true I don't need to calculate the frame difference anymore and align the two? That's not quite clear to me.
Edit: The HDR10 DCP Rip is 1 frame behind the DV RPU. Do I need to duplicate or remove 1 frame?
Trees on Tue Dec 27, 2022 10:53 pm, edited 1 time in total.
Gatorman
Post
by Gatorman » Sat Dec 24, 2022 7:39 pm
Trees wrote: Fri Dec 23, 2022 11:07 am
I don't believe it's automated, someone correct me if I'm wrong.
https://drive.google.com/file/d/1MntCbj ... p=drivesdk
duder
Post
by duder » Wed Dec 28, 2022 11:23 am
Guys, how can I mux more than two audio tracks in mp4 file with @RESET_9999 dovi_script tool?
I use 7-1-1 steps. But its limited only to two tracks
powdeau
Post
by powdeau » Wed Dec 28, 2022 1:19 pm
Hi, does anybody already have the new firmware (03.34.55) for C1 and if so, does it fix the L1 bug on x700?
MastaG
Post
by MastaG » Wed Dec 28, 2022 10:50 pm
Perhaps somebody knows.
But I've created a few movies with the dovi_scripts.
They are single track dual layer profile 8.
I have muxed them to m2ts for playback on the Shield.
The ones with DTS-MA play properly.
However the ones with Dolby TrueHD seem to only play audio, the picture is frozen.
Any ideas?
ArArdin
Post
by ArArdin » Thu Dec 29, 2022 10:46 am
MastaG wrote: Wed Dec 28, 2022 10:50 pmI've created a few movies with the dovi_scripts. They are single track dual layer profile 8.
How did you do that? I thought P8 was a single layer format.
Regarding the audio issue, it can be helpful if you post the connection chain. It's a bit of a guess now.
I don't know the Shield. But because DTS-MA does work I'd wonder if the tv is the culprit here. Should your Shield connect to the tv directly, it may be possible the tv is able to handle DTS-MA (probably because of the dts core) but it can't handle a TrueHD stream. Should you have muxed TrueHD with embedded AC3 (as opposed to TrueHD only) possibly audio will work if you'd select that AC3-track for playback on the Shield.
nekno
Post
by nekno » Fri Dec 30, 2022 7:29 am
ArArdin wrote: Thu Dec 29, 2022 10:46 am
Agree, TrueHD with AC3 core would be the best approach.
DV8 is by definition STSL, BL+RPU, so I don't think that was intended.
nekno
Post
by nekno » Fri Dec 30, 2022 7:37 am
Has anyone run into issues with the Sony X700 or X800M2 where 4K files that aren't exactly 2160p resolution get down-res'ed to 1080p? Any fix for this with DAR/SAR headers?
I have a file that's 3840x2080 instead of 2160 and the X800M2 is playing it back with DV but outputting 1080p.
realbabilu
Post
by realbabilu » Fri Dec 30, 2022 3:21 pm
Best for apple device since iphone4 is Subler. It has mp4 compatibility with dolby vision / atmos although i dont tested it now since departure to android.
ArArdin
Post
by ArArdin » Fri Dec 30, 2022 5:51 pm
nekno wrote: Fri Dec 30, 2022 7:37 am
Pitty your player doesn't just pad with black bars. Or even perform a minor stretch. Sony players have always had a reputation showing unforbidding behaviour towards non-compliant media. They clearly haven't changed. Without recoding, I very much doubt if a fix is possible for your video.
Where I assume it needs to be muxed in (m2)ts. Mkv does offer some tinkerings on container level, however there are very few players that honour certain headers.
Post
by RESET_9999 » Tue Jan 03, 2023 4:37 pm
lolipeid47 wrote: Tue Jan 03, 2023 1:27 pm
what's the commandline to use on my RPU.json to get the exact number of dynamic shots like he does ?
or
2-2 in my script (in my signature)...
strange, my x800m2/x700 doesnt downscale to 1080p with cropped 4k videos but it makes the letterbox grey and it's unwatchable.
