LibreDrive for Pioneer drives
cryptowarrior
#361 Post by cryptowarrior » Sat Dec 10, 2022 4:41 pm
the pioneer BDR-209 is working ootb aswell and can be added to the list:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.52
Serial number: NEDL009126WL
Firmware date: 2019-01-11
Drive platform: RS8600
Firmware version: 1.52/ID43
B-LXA
#362 Post by B-LXA » Tue Dec 13, 2022 1:14 am
Hello, I am looking to purchase BDR-XD08MB-S from Amazon JP. May I know if this drive is now LibreDrive supported and able to rip UHD disc?
Thanks in advance.
#363 Post by MartyMcNuts » Tue Dec 13, 2022 4:12 am
B-LXA wrote: Tue Dec 13, 2022 1:14 am Hello, I am looking to purchase BDR-XD08MB-S from Amazon JP. May I know if this drive is now LibreDrive supported and able to rip UHD disc?
Thanks in advance.
It should be. If not currently, it would be easy for Mike to add support.
mravocado
#364 Post by mravocado » Thu Dec 15, 2022 9:29 pm
ormandj wrote: Fri Dec 02, 2022 9:42 pm Has anybody tried a BDR-X13U-S (or any of their more recent drives) with firmware 1.02? There's an update available here: https://pioneer.jp/device_e/product-e/i ... #firmware1 but I don't want to upgrade my 1.01 drive and find out it's a problem, since you apparently cannot downgrade afterwards.
I just did and it did NOT work! :?
Product: BD-RW BDR-X13U
Revision: 1.02
Firmware date: 2022-07-26
Highest AACS version: 76
Drive platform: RS9401
Firmware name: PIONEER BDR-213T
Firmware version: 1.02/ID29
cryptowarrior
#365 Post by cryptowarrior » Thu Dec 15, 2022 10:44 pm
What do you mean it did not work? It says libredrive enabled
mravocado
#366 Post by mravocado » Thu Dec 15, 2022 11:21 pm
It does. But it failed to rip a UHD disc with some errors (same disc I was able to rip with the previous firmware). That said, non-UHD discs worked just fine.
mravocado
#367 Post by mravocado » Fri Dec 16, 2022 12:00 am
mravocado wrote: Thu Dec 15, 2022 11:21 pm It does. But it failed to rip a UHD disc with some errors (same disc I was able to rip with the previous firmware). That said, non-UHD discs worked just fine.
I take that back. UHD discs worked after restarting MakeMKV. So weird... Maybe it needed to download the latest SDF again? I will keep testing but every type of disc seems to be working now with the new firmware.
#368 Post by Coopervid » Fri Dec 16, 2022 10:36 am
After flashing you need to power-cycle your drive. Meaning turn your PC off and then on again. Most likely that hadn't happened in between trying.
liamtoh1
#369 Post by liamtoh1 » Fri Dec 23, 2022 7:20 pm
I am trying to decide to purchase BDR-XD08UMB-S directly from Pioneer USA to rip my 4K collections. But reading here on the forums, I am not sure if this drive is confirmed to work with MakeMKV with or without any firmware updates. Can someone on this forum confirm if they are able to rip 4K-UHD movies using this drive?
#370 Post by Coopervid » Fri Dec 23, 2022 8:18 pm
The XD08U 1.00 firmware is supported by Makemkv. If you drive comes with a newer firmware it will be couple of days after submitting the report Makemkv generates for your drive and submitting that.
liamtoh1
#371 Post by liamtoh1 » Fri Dec 23, 2022 11:16 pm
Coopervid wrote: Fri Dec 23, 2022 8:18 pm The XD08U 1.00 firmware is supported by Makemkv. If you drive comes with a newer firmware it will be couple of days after submitting the report Makemkv generates for your drive and submitting that.
Coopervid, Thanks.
TeddyRaspin
#372 Post by TeddyRaspin » Sat Dec 24, 2022 1:30 pm
1.03 Firmware on Pioneer site for BDR-S12UHT. :D
https://pioneer.jp/cgi-bin/device/downl ... W103EU.exe
#373 Post by Coopervid » Sat Dec 24, 2022 1:48 pm
Hi Teddy,
did you see Mike's post over there?
viewtopic.php?f=16&t=19634&start=1455
TeddyRaspin
#374 Post by TeddyRaspin » Mon Dec 26, 2022 8:46 am
@Coopervid
Didn't notice yet. My apologies :D
semi_56
#375 Post by semi_56 » Mon Dec 26, 2022 8:27 pm
I noticed some are selling Pioneer BDR-212EBK cross flashed to BDR-S12UHT to make it UHD friendly.
Is there guide availabe for to do it myself as I could not find one? I have such drive lying around and I would like to try.
