LibreDrive for Pioneer drives
cryptowarrior
Post by cryptowarrior » Sat Dec 10, 2022 4:41 pm
the pioneer BDR-209 is working ootb aswell and can be added to the list:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.52
Serial number: NEDL009126WL
Firmware date: 2019-01-11
Drive platform: RS8600
Firmware version: 1.52/ID43
B-LXA
Post by B-LXA » Tue Dec 13, 2022 1:14 am
Hello, I am looking to purchase BDR-XD08MB-S from Amazon JP. May I know if this drive is now LibreDrive supported and able to rip UHD disc?
Thanks in advance.
Post by MartyMcNuts » Tue Dec 13, 2022 4:12 am
Thanks in advance.
It should be. If not currently, it would be easy for Mike to add support.
mravocado
Post by mravocado » Thu Dec 15, 2022 9:29 pm
ormandj wrote:
Fri Dec 02, 2022 9:42 pm
Has anybody tried a BDR-X13U-S (or any of their more recent drives) with firmware 1.02? There's an update available here: https://pioneer.jp/device_e/product-e/i ... #firmware1 but I don't want to upgrade my 1.01 drive and find out it's a problem, since you apparently cannot downgrade afterwards.
I just did and it did NOT work! :?
Product: BD-RW BDR-X13U
Revision: 1.02
Firmware date: 2022-07-26
Highest AACS version: 76
Drive platform: RS9401
Firmware name: PIONEER BDR-213T
Firmware version: 1.02/ID29
cryptowarrior
Post by cryptowarrior » Thu Dec 15, 2022 10:44 pm
What do you mean it did not work? It says libredrive enabled
mravocado
Post by mravocado » Thu Dec 15, 2022 11:21 pm
It does. But it failed to rip a UHD disc with some errors (same disc I was able to rip with the previous firmware). That said, non-UHD discs worked just fine.
mravocado
Post by mravocado » Fri Dec 16, 2022 12:00 am
I take that back. UHD discs worked after restarting MakeMKV. So weird... Maybe it needed to download the latest SDF again? I will keep testing but every type of disc seems to be working now with the new firmware.
Post by Coopervid » Fri Dec 16, 2022 10:36 am
After flashing you need to power-cycle your drive. Meaning turn your PC off and then on again. Most likely that hadn't happened in between trying.
liamtoh1
Post by liamtoh1 » Fri Dec 23, 2022 7:20 pm
I am trying to decide to purchase BDR-XD08UMB-S directly from Pioneer USA to rip my 4K collections. But reading here on the forums, I am not sure if this drive is confirmed to work with MakeMKV with or without any firmware updates. Can someone on this forum confirm if they are able to rip 4K-UHD movies using this drive?
Post by Coopervid » Fri Dec 23, 2022 8:18 pm
The XD08U 1.00 firmware is supported by Makemkv. If you drive comes with a newer firmware it will be couple of days after submitting the report Makemkv generates for your drive and submitting that.
liamtoh1
Post by liamtoh1 » Fri Dec 23, 2022 11:16 pm
Coopervid, Thanks.
TeddyRaspin
Post by TeddyRaspin » Sat Dec 24, 2022 1:30 pm
1.03 Firmware on Pioneer site for BDR-S12UHT. :D
https://pioneer.jp/cgi-bin/device/downl ... W103EU.exe
Post by Coopervid » Sat Dec 24, 2022 1:48 pm
Hi Teddy,
did you see Mike's post over there?
viewtopic.php?f=16&t=19634&start=1455
TeddyRaspin
Post by TeddyRaspin » Mon Dec 26, 2022 8:46 am
@Coopervid
Didn't notice yet. My apologies :D
semi_56
Post by semi_56 » Mon Dec 26, 2022 8:27 pm
I noticed some are selling Pioneer BDR-212EBK cross flashed to BDR-S12UHT to make it UHD friendly.
Is there guide availabe for to do it myself as I could not find one? I have such drive lying around and I would like to try.
