Re: SDFtool Flasher
#631 Post by MartyMcNuts » Thu Dec 22, 2022 12:24 am
SDFtool Flasher has been updated to v1.3.5. This update fixes the string error on Buffalo drives.
Download link has been updated in the first post.
Re: SDFtool Flasher
#632 Post by MartyMcNuts » Thu Dec 22, 2022 12:28 am
ShootTheCore wrote: Wed Dec 21, 2022 5:04 am I have a newly-purchased Buffalo BRUHD-PU3-BK external Blu-Ray drive that I'm trying to flash new firmware on so I can rip UHD's. MakeMKV is installed in the default location, but when I select the drive in SDFtool Flasher, I get a "Input String was not in a correct format" error. Any suggestions on how I should proceed? I don't want to do something wrong and brick my drive.
Screenshot of the error message and the current drive info from MakeMKV here:
https://drive.google.com/file/d/13pnC6R ... sp=sharing
https://drive.google.com/file/d/13th3EN ... sp=sharing
Thank you!
SDFtool Flasher has been updated to v1.3.5. This update fixes the string error with Buffalo drvies. Please download from first post and give it a try.
Your Buffalo comes with encrypted BU14 firmware. You can flash your drive with BU40N 1.03-MK and either leave it on this firmware or then flash to another, such as BU10 etc...
ShootTheCore
Re: SDFtool Flasher
#633 Post by ShootTheCore » Thu Dec 22, 2022 2:10 am
Version 1.3.5 worked perfectly and now my drive is flashed with BU40N 1.03-MK and MakeMKV is ripping UHDs properly. Thanks for turning around the fixed version so quickly.
Is there a benefit to flashing the drive from 1.03-MK to BU10 or another firmware? I searched around the forum but couldn't find any information on benefits that other firmware versions would bring to this drive other than compatibility with movie playback software programs. I'm not planning on doing anything else with this drive except for ripping discs with MakeMKV.
Re: SDFtool Flasher
#634 Post by MartyMcNuts » Thu Dec 22, 2022 8:02 pm
ShootTheCore wrote: Thu Dec 22, 2022 2:10 am Version 1.3.5 worked perfectly and now my drive is flashed with BU40N 1.03-MK and MakeMKV is ripping UHDs properly. Thanks for turning around the fixed version so quickly.
If you are only ripping with MakeMKV there is no benefit in flashing another firmware. Stick with 1.03-MK.
semi_56
Re: SDFtool Flasher
#635 Post by semi_56 » Sat Dec 24, 2022 4:19 pm
Nevermind below, apparently I'm unable to read and I had to use RECOVERY option with SDFtool :)
I successfully cross flashed my BP55EB40 to BP60NB10 using HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin from latest custom firmware pack.
I have another question: should I still reflash drive with BP60NB10 1.00 MK hybrid firmware as I've seen it is widely recommended or should I stay on BP60NB10-1.02-NM00800-212005070935.bin which I already flashed. I don't have any UHD discs yet to test.
I'm trying to cross flash my BP55EB40 to BP60NB10 for UHD support, but I'm not sure where I go wrong.
I successfully flashed my drive with HL-DT-ST-BD-RE_BP55EB40-NB50-1.03-N000800-212005070924.bin, but I cannot flash BP60NB10 firmware as it was mentioned here.
viewtopic.php?f=16&t=22896&p=125362&hil ... 40#p125362
SDFtool confirms successful flash, but drive still reports itself as BP55EB40 and nothing seems to be changed.
Drive full model is BP55EB40 with SVC code EB52
mnoah66
Re: SDFtool Flasher
#636 Post by mnoah66 » Sat Dec 24, 2022 9:49 pm
For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
Is this relevant or did this only apply to the update listed right above it? Just bought an LG BP50NB40 with SVC NB52 so digging through lots of documentation before I start.
Re: SDFtool Flasher
#637 Post by MartyMcNuts » Sun Dec 25, 2022 4:34 am
mnoah66 wrote: Sat Dec 24, 2022 9:49 pm
Yes, my instructions are still relevant for the BP50NB40 SVC:NB52.
semi_56
Re: SDFtool Flasher
#638 Post by semi_56 » Mon Dec 26, 2022 10:33 am
I wonder if anyone has advice to my question below.
Just want to make sure I get it right, thanks :)
semi_56 wrote: Sat Dec 24, 2022 4:19 pm ...
jayper
Re: SDFtool Flasher
#639 Post by jayper » Mon Dec 26, 2022 3:29 pm
MartyMcNuts wrote: Thu Dec 22, 2022 8:02 pm
Cheers, thanks so much for the reply.
Re: SDFtool Flasher
#640 Post by MartyMcNuts » Mon Dec 26, 2022 8:14 pm
semi_56 wrote: Sat Dec 24, 2022 4:19 pm Nevermind below, apparently I'm unable to read and I had to use RECOVERY option with SDFtool :)
Stay on 1.02-MK.
semi_56
Re: SDFtool Flasher
#641 Post by semi_56 » Mon Dec 26, 2022 8:18 pm
MartyMcNuts wrote: Mon Dec 26, 2022 8:14 pm Stay on 1.02-MK.
thanks!
MeyroNW
Re: SDFtool Flasher
#642 Post by MeyroNW » Thu Jan 05, 2023 2:59 pm
This looks like the right tool for me, however, I can't flash my drive. The error message is that I don't have the right platform (MT1959). When I check the platform with MakeMKV, it tells me that the platform is MT1959. Any idea what the mistake could be?
Bildschirm­foto 2023-01-05 um 15.55.23.png (93.01 KiB) Viewed 17938 times
Re: SDFtool Flasher
#643 Post by MartyMcNuts » Thu Jan 05, 2023 7:25 pm
MeyroNW wrote: Thu Jan 05, 2023 2:59 pm This looks like the right tool for me, however, I can't flash my drive. The error message is that I don't have the right platform (MT1959). When I check the platform with MakeMKV, it tells me that the platform is MT1959. Any idea what the mistake could be?
Your drive is already libredrive enabled, so no need to flash it.
MeyroNW
Re: SDFtool Flasher
#644 Post by MeyroNW » Thu Jan 05, 2023 7:36 pm
Thanks for your fast reply Marty, but why then do I get the following error message in Anydvd HD?
Bildschirm­foto 2023-01-05 um 20.33.39.png (79.33 KiB) Viewed 17927 times
Re: SDFtool Flasher
#645 Post by Coopervid » Thu Jan 05, 2023 9:31 pm
Your version of Makemkv is outdated. Please update.
And if you tried SDFTool flasher - the same reason applies.
