Empire of Light screener, will not even load
bobtiki
Post by bobtiki » Tue Dec 20, 2022 5:57 pm
Disc: Empire of Light ("for your consideration" screener) DVD
Make MKV 1.17.2
I have tried this both on Windows and macOS, on three different optical drives (2 on PC, 1 on Mac), and none of them will load this disc. As in, I start MakeMKV up, and insert the disc, and it just sorta hangs on the initial check/load of the disc. If I put the disc in before starting MakeMKV, it stalls as soon as I launch the app.
I have tried a few other DVD ripping programs and disc image makers on both PC and Mac, and all of them failed as well. HOWEVER, if I just load up the DVD player app on macOS, it plays just fine (using the same optical drive that I tried ripping it from).
Here's the debug log from the macOS version, where I started the app first and then inserted the disc, and captured the log about 5 minutes after inserting the disc. Is there any other information that would be useful, or anything else I should try?
Debug log started at Tue Dec 20 17:48:48 2022 , written by MakeMKV v1.17.2 darwin(x64-release)
001005:0000 MakeMKV v1.17.2 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/me/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.84.0/(SecureTransport) LibreSSL/3.3.6/1.47.0 (x86_64-apple-darwin22.0) , proxy server not set.
002010:0000 Optical drive "BD-RE TSSTcorp BDDVDW SE-506BB TS00 R90K6YMF10020Gd" opened in OS access mode.
SDF  v095: TSSTcorp_BDDVDW_SE-506BB_TS00_R90K6YMF10020G
DEBUG: Code 2317353435 at ga$34e8!"rz![kS?G:29396736
DEBUG: Code 0 at ga$34e8!"rz![kS?G:213133089
DEBUG: Code 1 at ga$34e8!"rz![kS?G:213133089
DEBUG: Code 2 at ga$34e8!"rz![kS?G:213133089
DEBUG: Code 3 at ga$34e8!"rz![kS?G:213133089
DEBUG: Code 4 at ga$34e8!"rz![kS?G:213133089
DEBUG: Code 5 at ga$34e8!"rz![kS?G:213133089
DEBUG: Code 2317353435 at ga$34e8!"rz![kS?G:29397104
DEBUG: Code 0 at >s/]lI+mpwgsZ!@V:121269777
bobtiki
Re: Empire of Light screener, will not even load
Post by bobtiki » Tue Dec 20, 2022 6:15 pm
This is from the Windows PC with a different Blu-ray drive, captured about 20 minutes after disc insertion, in case this is useful info:
Debug log started at Tue Dec 20 17:59:10 2022 , written by MakeMKV v1.17.2 win(x64-release)
001005:0000 MakeMKV v1.17.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\me/MakeMKV_log.txt
DEBUG: Code 3 at `6CF;l<+`$x9]D6No(y!wmrg:29395310
SDF  v095: HL-DT-ST_BD-RE__BH16NS40_1.04_211901041338_KLHK4BB2957
bobtiki
Post by bobtiki » Tue Dec 20, 2022 7:09 pm
Fair enough. Out of the 14 screeners I've gotten so far this year, though, it was the only one that had any issues. That said, it was the only screener from Searchlight Pictures, so maybe there's just something weird with their mastering.
Post by d00zah » Tue Dec 20, 2022 7:13 pm
Quite a few of something considered dead in 2020... more "zombie" tech. :D
bobtiki
Post by bobtiki » Tue Dec 20, 2022 7:21 pm
Hey if the studios want to send me free movies, I'm not going to complain :D
