The Music Of Silence - "broken timecode"
hjk321
Post by hjk321 » Mon Dec 19, 2022 10:11 pm
When I try to rip "The Music of Silence" (a dual-layered DVD), it initializes, scans the seamless segments of the title, then rips exactly 15.6MB of the movie. At this point the software hangs for several minutes before failing with no specific error. I am certain this is not due to a read error as I was able to take a full iso of the disc with no issues. The debug log seems to complain about some sort of "broken timecode" in the title but I do not know what this means.
Debug Log: https://pastebin.com/AZu13Mbu
A full, decrypted iso of the disc can be provided privately upon request.
Re: The Music Of Silence - "broken timecode"
Post by dcoke22 » Tue Dec 20, 2022 3:07 am
I think the broken timecode message is a result of the earlier error.
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
I didn't see any of the usual drive-can't-read-the-disc errors in your log. I couldn't say what's gone wrong in your case, but something clearly has.
What happens if you use MakeMKV to make a DVD backup instead of ripping a title directly from the disc?
hjk321
Post by hjk321 » Wed Dec 21, 2022 5:52 pm
dcoke22 wrote: Tue Dec 20, 2022 3:07 am What happens if you use MakeMKV to make a DVD backup instead of ripping a title directly from the disc?
Yes, as I explained, I was able to make a full iso backup with no issues.
Post by dcoke22 » Wed Dec 21, 2022 9:29 pm
hjk321 wrote: Wed Dec 21, 2022 5:52 pm Yes, as I explained, I was able to make a full iso backup with no issues.
It wasn't clear to me if you made the .iso with MakeMKV. Presumably you did?
If that's the case, then I think there's something weird with that DVD which seems to have uncovered a potential bug in MakeMKV.
hjk321
Post by hjk321 » Wed Dec 21, 2022 10:47 pm
dcoke22 wrote: Wed Dec 21, 2022 9:29 pm It wasn't clear to me if you made the .iso with MakeMKV. Presumably you did?
It was through MakeMKV. Sorry for not being clear.
hjk321
Post by hjk321 » Tue Jan 03, 2023 4:42 pm
Bump.
