Full house season 1 problems
ilikemen15
So im ripping full house on dvd and i noticed that on season 1 episode 21 and 22 are completely missing from makemkv but when i play this disc on vlc those 2 episodes are there so whats the deal? I have my skip seconds to 1000 so it shouldn't be having a problem with that. Any help would be much appreciated
- Screenshot 2022-12-17 210207.png (60.95 KiB) Viewed 5773 times
Re: Full house season 1 problems
Recent versions of MakeMKV have different ways of scanning DVDs. Perhaps try a different DVD opening mode.
DVD opening modes - CellWalk, CellTrim, CellFull
As a side note, setting the minimum title length to 1000 seconds, or 16 minutes 40 seconds, is kinda big. Is it possible these episodes are just short?
tim6321
Did you have any luck with the rest of the season?
I'm trying to backup this season and it's totally confounding me. With 4 brand new disks:
* Disk 1 I can only get 3/6 episodes
* Disk 2 is like completely unreadable
* Disk 3 I can only get 3/6 episodes
* Disk 4 interestingly was the only one that worked fine for me, which you are claiming it has problems. I think there are only 4 episodes, and you seem to have 4 files there at ~1GB, so what is the issue exactly?
Hoping the other seasons work better or I got this big box set for nothin :\
