What kind of subtitles are invisible to MakeMKV?
moltikon
Post by moltikon »
I may have not noticed it before but I recently realized that not all subtitles are visible to MakeMKV.
What I am seeing are subtitles that I can select in VLC when I watch the DVD but when I try to create the MKV file that subtitle does not appear in the expanded tree and when I rip to MKV and play it back via VLC the subtitle is missing completely.
This is a real show stopper for me which means that for now I have to rip the complete DVD to make sure I am getting all the subtitles.
Any idea what may be the problem?
Re: What kind of subtitles are invisible to MakeMKV?
Post by mike admin »
MakeMKV should display all subtitles. The only subtitles not processed by MakeMKV are so-called "closed captions" or "line 21" data present on some discs.
moltikon
Post by moltikon »
Thanks Mike for your response. Any plans on adding Line 21 (aka CC) support?
moltikon wrote:Thanks Mike for your response. Any plans on adding Line 21 (aka CC) support?
Absolutely. Can't promise any specific time frame.
