mdeguzman
Post by mdeguzman »
does this mean that the following drives would not need to "Flashed"
drives that Currently work are:
BDR-XD07UHD Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XD06JUHD Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S12UHT Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XS07UHD Slim Slot load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-212UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-211UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-UD04 Slim 9.5mm tray load slim sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S13U-X Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S13UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
Please advicse.
Thanks.
Correct.
mdeguzman
Post by mdeguzman »
Thank you.
NESSNES404
Post by NESSNES404 »
I am looking into purchasing a Pioneer BDR-XS07UHD, and by the looks of this forum, I should have no issues. However, I was looking Pioneers product page and found that there was a firmware update (version 1.02) that was released on 12/21/2022. Should I be reluctant of updating the firmware? Could it possibly block access to rip DVDs and BDs? This forum has been a lot of help!
https://pioneer.jp/device_e/product-e/ibs/device_e/dev00001r_e.html#firmware1
https://pioneer.jp/device_e/product-e/ibs/device_e/dev00002r_e.html#BDR-XS06
Screenshot 2.png (73.73 KiB) Viewed 20578 times
Post by mike admin »
The SDF update time for new firmwares varies. In this particular case, all 8 Pioneer firmwares released yesterday are already integrated in latest SDF.bin and are supported. Sometimes it takes much longer, though...
NESSNES404
That's awesome! Thank you for the information :)
Jman5150
Post by Jman5150 »
Is there a reason i seem to be having a hard time finding these two BDR-XD07UHD and. BDR-XD06JUHD if i do the price is really high and its like one item. Were they discontinued? Im in the states is it a region thing?
JSD50
Post by JSD50 »
I am a bit overwhelmed. My BP50NB40 - SVC NB52 is supposed to work with Windows or Mac OS. These instructions relate to the SDFtool Flasher, which is an .exe. How do I flash to NB50 1.03-MK on my MacBook Pro? Is there a .dmg out there?
JSD50 wrote: Fri Dec 23, 2022 9:36 pm I am a bit overwhelmed. My BP50NB40 - SVC NB52 is supposed to work with Windows or Mac OS. These instructions relate to the SDFtool Flasher, which is an .exe. How do I flash to NB50 1.03-MK on my MacBook Pro? Is there a .dmg out there?
No dmg. You could create a VM with Windows 10 64 bit or Win 11 64 bit. Don't forget to add your physical drive before starting VM. See here: viewtopic.php?p=129979#p129979
Otherwise, ask a friend that has a windows PC to help you out.
If you're comfortable with the command line, you can flash your drive using Terminal in macOS. The instructions are near the bottom of the first post in this thread.
Going the route MartyMcNuts suggested is probably easier.
ImCoKeMaN
Post by ImCoKeMaN »
I just saw this one (BDR-XD08UMB-S) on the pioneer site, and it supports UHD, would it be libredrive compatible to rip UHD with makemkv? Also, is it still safe to update firmware on drives like this? Will there be MK firmwares like there were for other drives in the past?
D3F3ND3R16
Post by D3F3ND3R16 »
are the Pioneer drives US only? Can’t find any of them here in Germany available.
Want to get a second drive that’s no needed to be flashed.
No. You can find them in Germany but not the newest models. Full size "12" series and slim size "07" series. In the US they sell already "13" and "08" series.
Se also the PN that I have sent to you.
mnoah66
Post by mnoah66 »
Probably a silly question but if you flash for UHD ripping you’ll still be able to rip DVDS and BluRays, right? Or do you have to re-flash it to stock?
Yes.
