Inspector General/The Pied Piper of Hamelin Failure
jimwelchok
Post by jimwelchok »
I Have 2 copies, they both fail the same. Tried both CellWalk and Celltrim. 2 laptops.
Protection Error?
Title #1 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/1 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/2 was added (7 cell(s), 1:41:43)
Title #1/3 was added (6 cell(s), 1:26:54)
Saving 2 titles into directory /home/jim/Videos/Movies
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1430784000'
Error 'Posix error - Input/output error' occurred while reading '/dev/sr0' at offset '1430784000'
Failed to save title 0 to file /home/jim/Videos/Movies/title_t00.mkv
Re: Inspector General/The Pied Piper of Hamelin Failure
Not according to your drive, it's not. Usually, this means the disk isn't clean. Did BOTH fail at the SAME point?
Another possibility is that the drive spins up faster than it can sustain on the available power. Laptop drives (internal) are supposed to be "fully powered" to go their top speeds, but that's not a given with a LOT of laptops.
