BTW, you guys recommend a great alternative too VLC?
VLC has being a nightmare as of late...
paid or free doesnt really matter to me
rosavanwinkle
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Dv web dl’s movies in resolve.
Testing all export options to see which 1 produces the best or identical reproduction, same file size as well, even tested hevc 444 main 10 which no device can decode yet, but plays well on the pc,
Guardians of the galaxy holiday special (kbacon) dv/WB/dl
Here is a small test sample of the conversion.
Mdl on the encode is incorrect on purpose.
There are a few things i see in some of the results
I’m getting, both negative & positive feedback is welcomed.
Color range from Full to Limited plus yuv is tricky
I’ve seen banding in some scenes on 10bit yuv on some of the tests. No banding on raw exports samples. EDIT: banding solved.
In my opinion results are promising and looks better than the hdr10 version my sample is 4000nits colors are on point with the exception of the brightness shift,rpu is original p5 to p8.1 Looks more like a natural p5.
https://drive.google.com/file/d/1WlHhYU ... p=drivesdk
624DE1466D77.jpeg[/attachment]
Last edited by Manixx2020beyound on Tue Dec 13, 2022 9:24 pm, edited 2 times in total.
Hoosier205
This is an old post, but the answer to your question is the 2019 Shield TV Pro. The "red push" being claimed is utter nonsense. Simply put, it is something concocted by just a few members of this forum.sofakng wrote: Fri Sep 09, 2022 5:24 pmThanks for the information. I should have mentioned I was asking about FEL playback which the LG C1 cannot play.RESET_9999 wrote: Fri Sep 09, 2022 5:15 pmI will compare more movies this weekend, but I'm 99% sure that using the internal player renders better quality (regarless of FEL and lossless audio).
I've placed an order (but cancelled) an order for the Oppo-203 clone and also returned the Sony x800m2 because of that bug and I was wondering if any playback method existed w/o any bugs (for the LG C1).
ArArdin
Disregarding red push, the 2019 Shield TV Pro can process FEL?
NuadaXXX
hi I have a CX
back in the day, the tv was running DV7 with mel, but now it plays only HDR over USB, but when i mux it to P8 it works again, is this normal ?
i think a new FW update from the TV is the problem.
whatsmyname
It will play it but the enhancement layer will be ignored.ArArdin wrote: Tue Dec 13, 2022 12:28 pm Disregarding red push, the 2019 Shield TV Pro can process FEL?
ragico
@quietvoid
Please can you post your latest Kodi build Nexus RC1?
Many thanks.
Many thanks.
quietvoid
https://mega.nz/file/tF0AxZTS#xoylPrjah ... 2mqoIw12MEragico wrote: Fri Dec 16, 2022 10:09 pm @quietvoid
Many thanks.
thetoad
Has the firetv cube gen 3 now surpassed the Shield as the best player for DV MKVs as it now supports bitstreaming? It has better DV support, right? (does it use the EL? or also just the RPUs, but better color accuracy?) It doesn't have gigabit ethernet, but the wifi 6E could conceptually compensate for that. I'm wondering what others think.
ragico
Thank you.quietvoid wrote: Sat Dec 17, 2022 1:27 amhttps://mega.nz/file/tF0AxZTS#xoylPrjah ... 2mqoIw12MEragico wrote: Fri Dec 16, 2022 10:09 pm @quietvoid
Many thanks.
ArArdin
If I'm not mistaken the latest Cube does not process FEL. There seem to be some audio problems too. I haven't read the whole thread yet, but at AVSforum issues are mentioned about Dolby MAT not always being output and DTS-HD throughput not working.thetoad wrote: Sat Dec 17, 2022 10:26 am Has the firetv cube gen 3 now surpassed the Shield as the best player for DV MKVs as it now supports bitstreaming? It has better DV support, right? (does it use the EL? or also just the RPUs, but better color accuracy?) It doesn't have gigabit ethernet, but the wifi 6E could conceptually compensate for that. I'm wondering what others think.
https://www.avsforum.com/threads/gen-3- ... e.3255950/
Draco1544
Hi ! Is it possible to use the dovi_script tool of @RESET_9999 to create a Dolby vision profile 8 mkv and not a ts file ?
Gatorman
Draco1544 wrote: Sun Dec 18, 2022 1:17 am Hi ! Is it possible to use the dovi_script tool of @RESET_9999 to create a Dolby vision profile 8 mkv and not a ts file ?
Certainly, you just need to modify the script by setting the "Choose a muxer" option for tsmuxer.popup to "NO" and mkvtoolnix.popup to "YES". You can set any other ts options to "NO" as well.
Hoosier205
There is nothing wrong with the Shield. It is still the best option.thetoad wrote: Sat Dec 17, 2022 10:26 am Has the firetv cube gen 3 now surpassed the Shield as the best player for DV MKVs as it now supports bitstreaming? It has better DV support, right? (does it use the EL? or also just the RPUs, but better color accuracy?) It doesn't have gigabit ethernet, but the wifi 6E could conceptually compensate for that. I'm wondering what others think.
Trees
I'm trying to hybrid a HDR10 DCP Rip and a DV RPU. Problem is, they're of by a few frames. Is it true I don't need to calculate the frame difference anymore and align the two? That's not quite clear to me.
Edit: The HDR10 DCP Rip is 1 frame behind the DV RPU. Do I need to duplicate or remove 1 frame?
