BU40N (archgon) with libre will not rip No Time to Die and 1917
chuutlu
Post by chuutlu » Mon Dec 12, 2022 4:48 pm
So I started to put my Blu Rays on a jellyfin, which worked perfect for normal blu rays. Now I wanted to get a quality boost and tried two UHD Discs. No Time to Die and 1917. The blu ray versions of these worked fine.
Bot Fail with same error logic. Log see below.
Internet Access is active.
Power Issues for the drive unlikely. (I tried with USB C, Two USB A in different ports, even a 5V USB Power Supply)
Libre Drive is fully active with FW 1.04 MK for the BU40N Archgon (Flashed with the makemkv terminal tool)
I also send the dump files to svq@makemkv.com, as suggested, but after a week it still does not work.
Main Erros are:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
Drive:
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.04
Serial number: MODM2QI1158
Firmware date: 2120-05-06 11:42
Highest AACS version: 76
Firmware version: 1.04
Does anyone has a clue, what might be the problem here?
MakeMKV v1.17.2 linux(x64-release) started
Debug logging enabled, log will be saved as /home/XXXX/MakeMKV_log.txt
DEBUG: Code 4279398400 at IxU@3t^"4o~"=4U^x:121265039
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:0'
DEBUG: Code 0 at 3m66~*5(ghf\<1j\M:213130766
DEBUG: Code 0 at :38F0O1+zn5.R0D|U7:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:0'
DEBUG: Code 0 at :38F0O1+zn5.R0D|U7:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_21:0'
DEBUG: Code 1 at :38F0O1+zn5.R0D|U7:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:0'
DEBUG: Code 1 at :38F0O1+zn5.R0D|U7:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SG:dev_21:0'
DEBUG: Code 2 at :38F0O1+zn5.R0D|U7:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SG:dev_21:0'
DEBUG: Code 2 at :38F0O1+zn5.R0D|U7:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:0'
DEBUG: Code 3 at :38F0O1+zn5.R0D|U7:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_21:0'
DEBUG: Code 3 at :38F0O1+zn5.R0D|U7:213131686
DEBUG: Code 0 at :38F0O1+zn5.R0D|U7:213130789
Deleted some stuff, because Post was too long.
DEBUG: Code 3 at :38F0O1+zn5.R0D|U7:213130789
DEBUG: Code 4 at :38F0O1+zn5.R0D|U7:213130789
DEBUG: Code 0 at :38F0O1+zn5.R0D|U7:121264395
DEBUG: Code 1 at :38F0O1+zn5.R0D|U7:213130789
DEBUG: Code 2 at :38F0O1+zn5.R0D|U7:213130789
Saved AACS dump file as /home/XXXX/.MakeMKV/MKB20_v72_1917_83C7.tgz
DEBUG: Code 0 at zNpG$|#uAzJtHlDU:29396138
DEBUG: Code 0 at zNpG$|#uAzJtHlDU:121263153
Note that I also posted somwhere else:
viewtopic.php?f=12&p=130150#p130150
Re: BU40N (archgon) with libre will not rip No Time to Die and 1917
Post by Coopervid » Mon Dec 12, 2022 6:31 pm
Makemkv need Internet access to decrypt UHD files. Make sure you have that enabled.
chuutlu
Post by chuutlu » Tue Dec 13, 2022 8:05 am
Internet Access is enabled. I have read most topics regarding UHD Decrypt topics and the main causes seem to be:
Power Issue with drive (Tried everything to give the drive enough power, should not be the Problem)
Internet Access (Is active and also I do not get the error message for it.)
Libre Drive (I have a libre drive and it is active.)
No Key available. (I did sent both Dump Files to svq@makemkv.com which was 9 and 2 Days ago.)
To sure about the Dump File:
It is the file in the home/XXX/.makemkv directory (linux) on the first level. So the whole tgz e.g. MKB20_v72_1917_83C7.tgz, correct?
Post by Billycar11 » Tue Dec 13, 2022 8:19 am
chuutlu wrote: Tue Dec 13, 2022 8:05 am Internet Access is enabled. I have read most topics regarding UHD Decrypt topics and the main causes seem to be:
not a power issue in this case looks like a passthrough issue are you using a docker or vm if so stop and use it natively.
chuutlu
Post by chuutlu » Tue Dec 13, 2022 8:44 am
Nope, no VMs or anything like it.
But I just noticed, it does not say "using libre drive mode". It should say that in the log before "Using direct disc access mode", is that correct?
I have the feeling, MakeMKV does not try using libre Drive mode.
I also have another old Blu Ray Drive plugged in and there is a setting forcing single drive mode. I try playing with this.
BTW I wrote I have FW 1.03 but it is FW 1.04 MK From Mike.
Post by Billycar11 » Tue Dec 13, 2022 8:47 am
chuutlu wrote: Tue Dec 13, 2022 8:44 am Nope, no VMs or anything like it.
nah thats not an issue it always says using direct mode
flash to BU40N 1.00 from my de pack seen that fix this before
chuutlu
Post by chuutlu » Tue Dec 13, 2022 9:11 am
Ok, I will try. To be sure: DE_flash_HL-DT-ST_BD-RE_BU40N_BU10.bin That's the one you are referring to for the european version of the archgon BU40N Drive?
(Source https://drive.google.com/file/d/102V7DU ... sp=sharing )
chuutlu
Post by chuutlu » Tue Dec 13, 2022 10:06 am
So it worked with your FW.
So here a quick guide for Linux Users:
Use FW provided by Billycar11:
For me it was DE_flash_HL-DT-ST_BD-RE_BU40N_BU10.bin (Archgon BU40N)
Put it into /tmp/
Download sdf.bin ( https://makemkv.com/sdf.bin ) and also put in /tmp/
Find your drive with by typing in your terminal /usr/bin/makemkvcon f -l
Gives you something linke this:
00: dev_21:0, /dev/sr0, /dev/sr0
/dev/sr0 is your drive.
Then Type this in your terminal: (Obviously use the path to your /tmp/FW.bin)
/usr/bin/makemkvcon f -d '/dev/sr0' -f /tmp/sdf.bin rawflash main -i /tmp/FW.bin
Make sure, you have the correct FW for your drive. Otherwise it can destroy it. Then confirm by writing yes and enter.
Also see viewtopic.php?f=16&t=19634 for encrypted FW. Mine was not encrypted. For encrypted FW use /usr/bin/makemkvcon f -d '/dev/sr0' -f /tmp/sdf.bin rawflash enc -i /tmp/FW.bin
I actually got an error:
Program Flash NG 06/29/00
Command produced error code 0x82062900
It still worked though.
