BU40N (archgon) with libre will not rip No Time to Die and 1917
chuutlu
Post by chuutlu »
So I started to put my Blu Rays on a jellyfin, which worked perfect for normal blu rays. Now I wanted to get a quality boost and tried two UHD Discs. No Time to Die and 1917. The blu ray versions of these worked fine.
Bot Fail with same error logic. Log see below.
Internet Access is active.
Power Issues for the drive unlikely. (I tried with USB C, Two USB A in different ports, even a 5V USB Power Supply)
Libre Drive is fully active with FW 1.03 for the BU40N Archgon (Flashed with the makemkv terminal tool)
I also send the dump files to svq@makemkv.com, as suggested, but after a week it still does not work.
Main Erros are:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
Does anyone has a clue, what might be the problem here?
MakeMKV v1.17.2 linux(x64-release) started
Debug logging enabled, log will be saved as /home/XXXX/MakeMKV_log.txt
DEBUG: Code 4279398400 at IxU@3t^"4o~"=4U^x:121265039
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:0'
DEBUG: Code 0 at 3m66~*5(ghf\<1j\M:213130766
DEBUG: Code 0 at :38F0O1+zn5.R0D|U7:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:0'
DEBUG: Code 0 at :38F0O1+zn5.R0D|U7:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_21:0'
DEBUG: Code 1 at :38F0O1+zn5.R0D|U7:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:0'
DEBUG: Code 1 at :38F0O1+zn5.R0D|U7:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SG:dev_21:0'
DEBUG: Code 2 at :38F0O1+zn5.R0D|U7:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SG:dev_21:0'
DEBUG: Code 2 at :38F0O1+zn5.R0D|U7:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:0'
DEBUG: Code 3 at :38F0O1+zn5.R0D|U7:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_21:0'
DEBUG: Code 3 at :38F0O1+zn5.R0D|U7:213131686
DEBUG: Code 0 at :38F0O1+zn5.R0D|U7:213130789
Deleted some stuff, because Post was too long.
DEBUG: Code 3 at :38F0O1+zn5.R0D|U7:213130789
DEBUG: Code 4 at :38F0O1+zn5.R0D|U7:213130789
DEBUG: Code 0 at :38F0O1+zn5.R0D|U7:121264395
DEBUG: Code 1 at :38F0O1+zn5.R0D|U7:213130789
DEBUG: Code 2 at :38F0O1+zn5.R0D|U7:213130789
Saved AACS dump file as /home/XXXX/.MakeMKV/MKB20_v72_1917_83C7.tgz
DEBUG: Code 0 at zNpG$|#uAzJtHlDU:29396138
DEBUG: Code 0 at zNpG$|#uAzJtHlDU:121263153
jayper
Re: BU40N (archgon) with libre will not rip No Time to Die and 1917
Post by jayper »
Sorry, I can't assist with your problem.
One suggestion for faster support: you should try posting in the 'UHD Drives' section of the Forums, for better visibility. The drive exports are often quite active there. This section is specific to UHD discs.
viewforum.php?f=16&sid=5ab2eda461549acfcbf2d22daf8c40e8
chuutlu
Post by chuutlu »
Ok, I posted there. Thanks.
viewtopic.php?f=16&t=29761
