Newbie hitting a snag on DVD
gowmydvds
#1 Post by gowmydvds » Thu Dec 08, 2022 11:19 pm
I've been importing our DVD collection to PLEX via handbreak and makemkv and i've got 2 disks that I cannot figure out, they don't appear damaged but give read errors when opening them automatically.
I tried opening the disks manually and specifying the scene I want(#1) and it errors out saying skipped due to navigation error, can anyone advise if this is due to some sort of protection or could it be a damaged disk?
The second disk I can pull individual scenes in manual mode(1:1, 1:2, 1:3, ect) into small files and it does read/write to the mkv files but it would be 34 individual files(34 scenes), is there a simple way to grab the scenes besides running them all manually and is there a good way to combine them after? I tried running manual mode with just "1:" for all of scene one but it errors out as shown below.
Open DVD manually : "1:"
DEBUG: Code 2612742 at OldCY@V<RSIC_?:29396184
DEBUG: Code 2681936 at OldCY@V<RSIC_?:29396184
DEBUG: Code 0 at Olth@hz`IUo(oSgN@K:121273641
DEBUG: Code 0 at Olth@hz`IUo(oSgN@K:121274699
Title #1 (2:01:59) was skipped due to navigation error
I've tried doing a bunch of googling but either i'm just not searching correctly or i'm using the wrong key words to figure this out.
Here is the log from the non manual run using makemkv
Title #1 was added (31 cell(s), 1:56:11)
Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 263428 at 4.-:!ZP"+\~BWK:29401497
Title #5 was added (1 cell(s), 0:06:40)
Title #6 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 394500 at 4.-:!ZP"+\~BWK:29401497
Cells 7-7 were removed from title end
Title #7 was added (6 cell(s), 0:08:34)
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '65536'
DEBUG: Code 100941314 at 7\p$41hKadpJ}AJisc:213131502
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '65536'
DEBUG: Code 100864261 at 7\p$41hKadpJ}AJisc:213131502
DEBUG: Code 1 at []FT^0o 9ptqu*vu:121262578
DEBUG: Code 0 at D/Yd;xQJz x=B>=:213138494
DEBUG: Code 0 at 4.-:!ZP"+\~BWK:213134676
Audio stream #4 looks empty and was skipped
Encountered 36 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
jimwelchok
Re: Newbie hitting a snag on DVD
#2 Post by jimwelchok » Mon Dec 12, 2022 2:13 am
I am getting the same error on 2 DVDs. I've tried both scan techniques: Cell Walk and Cell Trim. No Luck!
I am beginning to think its either a bug or a form of copy protection. It is making my debugging powers, itch to solve the problem.
Current DVD problem: Dennis The Menace, and That Touch of Mink, Mink was fixed with using cell trim.
#3 Post by Woodstock » Mon Dec 12, 2022 2:01 pm
If you're both getting media errors, that normally indicate the disk was bad. Cleaning the disk is the first thing to try in those cases.
gowmydvds
#4 Post by gowmydvds » Sun Dec 18, 2022 1:28 pm
I was able to narrow it down after some more experimenting, Woodstock was correct, in my case these two dvd's are damaged.
