Drive crashes with new BDs
redtomcat
Post by redtomcat »
I have a strange issue when trying to RIP the just on BD released 4th season of Discovery.
When trying to rip (most of) the episodes my drive suddenly seems to reset after some time (before one track is complete) and therefore MakeMKV cannot access the files any more and fails with several "Posix-Error - No such device ..." And "Posix-Error Input/output error"
The drive is not usable any more until the device is powered off and on again.
The drive is connected via USB, but the external chaises has its own power supply and worked fine for ages. Just tested it again with a few different BDs without issues.
Funny thing is, on the last disc of the 4 I did not have issues ripping the two episodes on them.
MakeMKV also reports that the disc uses a new(er) version of the AACS protection (on all of the disks)
A backup without decryption flag set also does not work and has the same effect.
Simple dd doesn't work either.
Can this strange behaviour be related to/caused by the new version of the AACS protection? Would upgrade to MK Firmware 1.05 (from currently 1.04) make a difference?
MakeMKV v1.17.2 linux(x64-release)
Using LibreDrive mode (v06.3 ...)
Drive:
Product: BD-RE BH16NS55
Revision: 1.04
Firmware-Date: 2119-01-04 13:42
Highest AACS version: 78
Firmware version: 1.04
Disc-Information
Protecion: AACS v78
dmesg from moment of issues:
usb 3-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
usb 3-2: device firmware changed
usb 3-2: USB disconnect, device number 2
scsi 5:0:0:0: rejecting I/O to dead device
blk_update_request: I/O error, dev sr0, sector 74932736 op 0x0:(READ) flags 0x0 phys_seg 7 prio class 0
usb 3-2: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
usb 3-2: language id specifier not provided by device, defaulting to English
usb 3-2: New USB device found, idVendor=067b, idProduct=2773, bcdDevice= 1.00
usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 3-2: Set SEL for device-initiated U1 failed.
usb 3-2: Set SEL for device-initiated U2 failed.
usb-storage 3-2:1.0: USB Mass Storage device detected
scsi host6: usb-storage 3-2:1.0
usb-storage 3-2:1.0: Max LUN 126 is not valid, using 0 instead
usb 3-2: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
scsi 6:0:0:0: CD-ROM HL-DT-ST BD-RE BH16NS55 1.04 PQ: 0 ANSI: 0
ictbydesign
Re: Drive crashes with new BDs
Post by ictbydesign »
@redtomcat I have recently ripped this with no problems.
I did see the message about AACS protection.
I too have ripped these discs without issue. I also saw the message about AACS (and I submitted the AACS data as the program requests).
ictbydesign
Just realised, mine is the windows based program and it looks like you are on the Linux version.
redtomcat
Post by redtomcat »
Yes, I am on Linux.
Tied yesterday the same again, directly on a SATA port and also with older versions of Makemkv. Different Linux distributions, all no change.
There is also no big change for me with firmware 1.05
There must be something new to these disks. Maybe something special on the German market. Other disks still don't make issues. Even UHD, all works perfectly.
