I try the UHD of Back to the Future Part III. Part I & II without problems.
In the last ten minutes breakers, see logfile. Any idea? Thank you
The_FireBird
- MakeMKV_log.txt
- (88.01 KiB) Downloaded 306 times
Re: Back to the Future Part III
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00294.m2ts' bei Offset '76500172800'
001003:0020 DEBUG: Code 3221225628 at `6CF;l<+`$x9]D6No(y!wmrg:121262371
001003:0020 DEBUG: Code 3221225628 at ze@?D]{aalB&'!=Y:213130559
002003:0000 Fehler 'Betriebssystemfehler - STATUS_DEVICE_DATA_ERROR' trat auf während des Auslesens von '\Device\CdRom1' bei Offset '76500172800'
DEBUG: Code 3221225628 at 7\p$41hKadpJ}AJisc:29394896
001003:0020 DEBUG: Code 3221225628 at 7\p$41hKadpJ}AJisc:213131502
001003:0020 DEBUG: Code 3221225628 at ze@?D]{aalB&'!=Y:213130559If you're experiencing rip errors, please read here first!
UHD FAQ
The_FireBird
Thank you, the disc is brand new. So I guess I need to replace it... thank you
On occasion I've had to gently clean a brand new disc to get it to rip.The_FireBird wrote: Sun Dec 11, 2022 8:17 pm Thank you, the disc is brand new. So I guess I need to replace it... thank you
