Back to the Future Part III
The_FireBird
Post by The_FireBird »
I try the UHD of Back to the Future Part III. Part I & II without problems.
In the last ten minutes breakers, see logfile. Any idea? Thank you
MakeMKV_log.txt
(88.01 KiB) Downloaded 346 times
Re: Back to the Future Part III
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00294.m2ts' bei Offset '76500172800'
001003:0020 DEBUG: Code 3221225628 at `6CF;l<+`$x9]D6No(y!wmrg:121262371
001003:0020 DEBUG: Code 3221225628 at ze@?D]{aalB&'!=Y:213130559
002003:0000 Fehler 'Betriebssystemfehler - STATUS_DEVICE_DATA_ERROR' trat auf während des Auslesens von '\Device\CdRom1' bei Offset '76500172800'
DEBUG: Code 3221225628 at 7\p$41hKadpJ}AJisc:29394896
001003:0020 DEBUG: Code 3221225628 at 7\p$41hKadpJ}AJisc:213131502
The disc probably needs to be cleaned. Those errors indicate the optical drive was unable to correctly read the disc.
If you're experiencing rip errors, please read here first!
UHD FAQ
The_FireBird
Thank you, the disc is brand new. So I guess I need to replace it... thank you
The_FireBird wrote: Sun Dec 11, 2022 8:17 pm Thank you, the disc is brand new. So I guess I need to replace it... thank you
On occasion I've had to gently clean a brand new disc to get it to rip.
