Problem with external LG WP50NB40
scarpogre
Post by scarpogre » Fri Dec 02, 2022 2:34 am
Hello everyone.
I have an external lg drive WP50NB40 svc Code NB40. I made a big mistake flashing it with the MK firmware pack for UHD. I flashed it with the MK Firmware WP50NB40-NB50. Now the drive is a brick I cannot find the original firmware to get make my drive work again. Can anyone share a link to the original firmware or is there another way to get this drive to work again?
Thanks for any help
scarpogre
Re: Problem with external LG WP50NB40
Post by scarpogre » Fri Dec 02, 2022 5:36 pm
I just re-read the Red Lettered "STOP Read Before Flashing" and see the info on the SVC number for LG drives. Looks like my choice to flash the drive is unfixable.
Post by dcoke22 » Sat Dec 03, 2022 3:20 am
Scroll down on that post until you see the section titled:
only use the recovery steps for older NS40 drives!!:
You might be able to recover.
Post by Billycar11 » Sat Dec 03, 2022 6:02 am
never have been able to recover them its possible but we need the find the right path
we also need the NB 40 firmware extracted out of the flasher
Post by MartyMcNuts » Sat Dec 03, 2022 7:19 am
scarpogre wrote: Fri Dec 02, 2022 2:34 am Hello everyone.
Thanks for any help
Can you try this and let us know if it works. Please download the attached firmware file.
1. Using SDFtool Flasher, select your drive
2. Select RECOVERY mode
3. In the popup window select the current firmware that is on the drive (whatever you flashed it to)
4. In the firmware drop down box select the attached firmware (which is the original BP50NB40 (NB40) 1.00 firmware)
5. Press START.
Let us know what happens.
BP50NB40-NB40-1.00-Clean.bin.zip
(1.3 MiB) Downloaded 3472 times
scarpogre
Post by scarpogre » Sat Dec 03, 2022 3:59 pm
Thanks for the help, will give it a try.
The firmware I flashed it with was the WP50NB40-NB50-1.03.
I'll let you know how it turns out
scarpogre
Post by scarpogre » Sat Dec 03, 2022 5:28 pm
Screen Shot 2022-12-03 at 12.21.36 PM.png (41.46 KiB) Viewed 50074 times
It worked!
Thanks again for helping me restore my drive.
I tried forcing the drive to read UHD discs when it was too old to do so. Oh well another backup DVD, BluRay drive.
Thanks again
Post by MartyMcNuts » Sat Dec 03, 2022 11:10 pm
scarpogre wrote: Sat Dec 03, 2022 5:28 pm Screen Shot 2022-12-03 at 12.21.36 PM.png
It worked!
Thanks again
Ok, can you test a blu-ray or DVD to make sure it works?
scarpogre
Post by scarpogre » Sun Dec 04, 2022 1:56 am
Will do
scarpogre
Post by scarpogre » Sun Dec 04, 2022 3:01 am
To test the drive, I ripped Batman Begins (BluRay) for a test and it is working OK.
Thanks again for the help
Screen Shot 2022-12-03 at 9.08.38 PM.png (289.71 KiB) Viewed 50050 times
Screen Shot 2022-12-03 at 9.33.34 PM.png (337.78 KiB) Viewed 50050 times
Screen Shot 2022-12-03 at 9.44.02 PM.png (2.26 MiB) Viewed 50050 times
Post by MartyMcNuts » Sun Dec 04, 2022 4:46 am
scarpogre wrote: Sun Dec 04, 2022 3:01 am To test the drive, I ripped Batman Begins (BluRay) for a test and it is working OK.
Awesome!! Thanks for letting us know!
Troubadour
Post by Troubadour » Fri Apr 28, 2023 9:46 pm
MartyMcNuts wrote: Sat Dec 03, 2022 7:19 am
5. Press START.
Thank you very much for this instruction, you have helped me with a similar problem.
I have a LG Slim Portable Blu-ray/DVD Writer labeld with "Model: BP55EB40 SVC Code: EB40"
So I flashed it like it was dicribed here viewtopic.php?p=130958#p130958
After that, the tray could no longer be opened.
So I did like you wrote above and use your BP50NB40-NB40-1.00-Clean.bin
Now the drive works again, and it is a LibreDrive too! :D
minkiz88
Post by minkiz88 » Thu Nov 23, 2023 3:10 pm
Thanks a bunch. Same thing happened to me, I didn't realize the SVC BP40 thing.
So question, what are the options for this drive? It's late 2016, but because of the SVC BP40, does that mean it's too old? When I bought the drive, I made sure to ask the seller for the manufacture date, but didn't ask about the SVC.
I ask because the drive was okay for a few weeks (I didn't get around to flashing it, yet), and all of a sudden I'm getting a bunch of scsi errors, Illegal Request, MEDIUM ERROR:L-EC UNCORRECTABLE ERROR, and others. I can open discs fine, and even rip most or all of the special features and stuff, but it's crashing halfway through ripping the actual movie. *shrug*
rnranimal
Post by rnranimal » Fri Feb 14, 2025 12:42 am
Thanks for any help
5. Press START.
Thank you! I just followed these directions and it worked. I have two of these LG drives- a 2016 and 2018 so I flashed both. 2018 worked perfectly and rips UHD, but the 2016 wouldn't even open anymore. Then I saw the NB40 I overlooked. I was about to thrash it when I found this post. I borrowed a PC laptop (I use Mac) and the instructions worked perfectly. It now is back to functioning as a DVD/blu-ray drive which is nice to have so that I can use the other exclusively for UHD.
AlbinoKiwi
Post by AlbinoKiwi » Sun Jul 06, 2025 2:49 am
Thanks for any help
5. Press START.
Sorry for yet another necro on this, but I wanted to thank y'all again because this saved another drive!
I had bought a drive forgetting about the manufacturing dates. I hooked it up and verified the platform, tried to use it on the stock firmware and it gave me the following error: "Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION" and would not work with even normal blu-rays.
After that I had managed to write all of the firmwares as I (wasn't) was supposed to, and the drive bricked (button didn't do anything but it still showed up in windows.
I did the recover looping and was eventually able to get your specific FW to write and bring the drive back. I had even made a backup of the original firmware of the drive but, strangely, it wasn't working for recovery purposes.
I went back into MakeMKV and it's suddenly working with regular blu-rays now. I went from having a non-functional (in MakeMKV) drive, to a bricked drive, to a functional in MakeMKV drive.
Thank y'all SO much :)
