No Longer Able to Rip after MacOS 13.0.1 Ventura
rwzmjl
Post by rwzmjl »
I keep getting this error:
Error 'OS error - (ipc/send) invalid destination port' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLHL2594405'
I've tried multiple discs, and everything worked perfectly before I updated to Ventura. What do I do? The disc shows up in Finder, then I start up MakeMKV, and the disc disappears.
Re: No Longer Able to Rip after MacOS 13.0.1 Ventura
Have you tried power cycling your optical drive? I'm not running Ventura, so this is just a guess.
rwzmjl
Post by rwzmjl »
As in turn it off and on? Definitely did a bunch of times. Using the same power supply as I did before.
rwzmjl
Post by rwzmjl »
Okay, it looks like the USB extension cord I've been using for the last year just decided to stop working at the exact time I upgraded to Ventura.
