illegal instruction in makemkv
feedc0de
Post by feedc0de »
I installed makemkv from the archlinux AUR on my raspberrypi3 (https://aur.archlinux.org/packages/makemkv), and I launched makemkv from the start menu.
I was greeted with a NO_ANSWER_FROM_MAKEMKVCON
So I tried the cmdline only tool instead, which works like a charm:
[feedc0de@raspberrypi3-00 ~]$ makemkvcon --help
makemkvcon: unrecognized option '--help'
Use: makemkvcon [switches] Command [Parameters]
Commands:
  info <source>
      prints info about disc
  mkv <source> <title id> <destination folder>
      saves a single title to mkv file
  backup <source> <destination folder>
      backs up disc to a hard drive
  f <args>
      run universal firmware tool
  reg <key string or file name>
      enter registration key into program
Source specification:
  iso:<FileName>    - open iso image <FileName>
  file:<FolderName> - open files in folder <FolderName>
  disc:<DiscId>     - open disc with id <DiscId> (see list Command)
  dev:<DeviceName>  - open disc with OS device name <DeviceName>
Switches:
  -r --robot        - turn on "robot" mode, see http://www.makemkv.com/developers
Then I tried reading in my ISO I want to convert:
[feedc0de@raspberrypi3-00 ~]$ makemkvcon info STAR_TREK_THE_MOTION_PICTURE.ISO
Ungültiger Maschinenbefehl (Speicherabzug geschrieben)
Which resulted in an illegal instruction?? What?
I try again with gdb attached:
$ gdb --args makemkvcon info STAR_TREK_THE_MOTION_PICTURE.ISO
GNU gdb (GDB) 12.1
Copyright (C) 2022 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "aarch64-unknown-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
    <http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from makemkvcon...
This GDB supports auto-downloading debuginfo from the following URLs:
https://debuginfod.archlinux.org
Enable debuginfod for this session? (y or [n]) y
Debuginfod has been enabled.
To make this setting permanent, add 'set debuginfod enabled on' to .gdbinit.
(No debugging symbols found in makemkvcon)
(gdb) r
Starting program: /usr/bin/makemkvcon info STAR_TREK_THE_MOTION_PICTURE.ISO
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
[New Thread 0xfffff15feba0 (LWP 120378)]
Thread 1 "makemkvcon" received signal SIGILL, Illegal instruction.
0x0000aaaaaaed908c in ?? ()
(gdb) bt
#0  0x0000aaaaaaed908c in  ()
#1  0x0000aaaaaaec4870 in  ()
#2  0x0000aaaaaaec4870 in  ()
#3  0x0000aaaaaac44a24 in  ()
#4  0x0000aaaaaac15440 in  ()
#5  0x0000fffff7d07b80 in  () at /usr/lib/libc.so.6
#6  0x0000fffff7d07c60 in __libc_start_main () at /usr/lib/libc.so.6
#7  0x0000aaaaaac15ef0 in  ()
(gdb)
Is makemkv broken at the moment? Is there anything else I could try?
wmcclain
Re: illegal instruction in makemkv
Post by wmcclain »
What does ldd on /usr/bin/makemkv show?
For example:
ldd /usr/bin/makemkv
linux-vdso.so.1 (0x00007fff869fa000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007f5972200000)
libQt5Widgets.so.5 => /usr/lib/libQt5Widgets.so.5 (0x00007f5971a00000)
libQt5Gui.so.5 => /usr/lib/libQt5Gui.so.5 (0x00007f5971200000)
libQt5DBus.so.5 => /usr/lib/libQt5DBus.so.5 (0x00007f5972553000)
libQt5Core.so.5 => /usr/lib/libQt5Core.so.5 (0x00007f5970c00000)
libz.so.1 => /usr/lib/libz.so.1 (0x00007f597433b000)
libc.so.6 => /usr/lib/libc.so.6 (0x00007f5970a19000)
libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0x00007f5972533000)
libm.so.6 => /usr/lib/libm.so.6 (0x00007f597244b000)
/lib64/ld-linux-x86-64.so.2 => /usr/lib64/ld-linux-x86-64.so.2 (0x00007f5974357000)
libGL.so.1 => /usr/lib/libGL.so.1 (0x00007f597217a000)
libpng16.so.16 => /usr/lib/libpng16.so.16 (0x00007f5972141000)
libharfbuzz.so.0 => /usr/lib/libharfbuzz.so.0 (0x00007f5971914000)
libmd4c.so.0 => /usr/lib/libmd4c.so.0 (0x00007f597212b000)
libdbus-1.so.3 => /usr/lib/libdbus-1.so.3 (0x00007f59720da000)
libsystemd.so.0 => /usr/lib/libsystemd.so.0 (0x00007f5971124000)
libdouble-conversion.so.3 => /usr/lib/libdouble-conversion.so.3 (0x00007f59720c4000)
libicui18n.so.72 => /usr/lib/libicui18n.so.72 (0x00007f5970600000)
libicuuc.so.72 => /usr/lib/libicuuc.so.72 (0x00007f5970200000)
libpcre2-16.so.0 => /usr/lib/libpcre2-16.so.0 (0x00007f5971886000)
libzstd.so.1 => /usr/lib/libzstd.so.1 (0x00007f5970970000)
libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0x00007f59704c1000)
libGLdispatch.so.0 => /usr/lib/libGLdispatch.so.0 (0x00007f5970409000)
libGLX.so.0 => /usr/lib/libGLX.so.0 (0x00007f597093e000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x00007f5970131000)
libgraphite2.so.3 => /usr/lib/libgraphite2.so.3 (0x00007f597010f000)
libcap.so.2 => /usr/lib/libcap.so.2 (0x00007f5972439000)
libgcrypt.so.20 => /usr/lib/libgcrypt.so.20 (0x00007f596ffc7000)
liblzma.so.5 => /usr/lib/liblzma.so.5 (0x00007f596ff9d000)
liblz4.so.1 => /usr/lib/liblz4.so.1 (0x00007f596ff7b000)
libicudata.so.72 => /usr/lib/libicudata.so.72 (0x00007f596e000000)
libpcre2-8.so.0 => /usr/lib/libpcre2-8.so.0 (0x00007f596fee0000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x00007f596debd000)
libbz2.so.1.0 => /usr/lib/libbz2.so.1.0 (0x00007f5971873000)
libbrotlidec.so.1 => /usr/lib/libbrotlidec.so.1 (0x00007f596fed2000)
libgpg-error.so.0 => /usr/lib/libgpg-error.so.0 (0x00007f596feac000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00007f596fe81000)
libbrotlicommon.so.1 => /usr/lib/libbrotlicommon.so.1 (0x00007f596fe5e000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x00007f59720bd000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00007f597186b000)
Ezatoka
Post by Ezatoka »
Didn't you forget something?
so shouldn't it be makemkvcon info iso:STAR_TREK_THE_MOTION_PICTURE.ISO?
feedc0de
Post by feedc0de »
Thanks for your replies!
ldd output as follows:
[feedc0de@raspberrypi3-00 ~]$ ldd /usr/bin/makemkv
	linux-vdso.so.1 (0x0000ffff8b205000)
	libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x0000ffff891f0000)
	libQt5Widgets.so.5 => /usr/lib/libQt5Widgets.so.5 (0x0000ffff88a80000)
	libQt5Gui.so.5 => /usr/lib/libQt5Gui.so.5 (0x0000ffff88380000)
	libQt5DBus.so.5 => /usr/lib/libQt5DBus.so.5 (0x0000ffff882c0000)
	libQt5Core.so.5 => /usr/lib/libQt5Core.so.5 (0x0000ffff87cf0000)
	libz.so.1 => /usr/lib/libz.so.1 (0x0000ffff87cc0000)
	libc.so.6 => /usr/lib/libc.so.6 (0x0000ffff87b00000)
	/lib/ld-linux-aarch64.so.1 => /usr/lib/ld-linux-aarch64.so.1 (0x0000ffff8b1cc000)
	libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0x0000ffff87ad0000)
	libm.so.6 => /usr/lib/libm.so.6 (0x0000ffff87a20000)
	libGL.so.1 => /usr/lib/libGL.so.1 (0x0000ffff87920000)
	libpng16.so.16 => /usr/lib/libpng16.so.16 (0x0000ffff878d0000)
	libharfbuzz.so.0 => /usr/lib/libharfbuzz.so.0 (0x0000ffff877b0000)
	libmd4c.so.0 => /usr/lib/libmd4c.so.0 (0x0000ffff87780000)
	libdbus-1.so.3 => /usr/lib/libdbus-1.so.3 (0x0000ffff87700000)
	libsystemd.so.0 => /usr/lib/libsystemd.so.0 (0x0000ffff875d0000)
	libdouble-conversion.so.3 => /usr/lib/libdouble-conversion.so.3 (0x0000ffff875a0000)
	libicui18n.so.72 => /usr/lib/libicui18n.so.72 (0x0000ffff87210000)
	libicuuc.so.72 => /usr/lib/libicuuc.so.72 (0x0000ffff86fe0000)
	libpcre2-16.so.0 => /usr/lib/libpcre2-16.so.0 (0x0000ffff86f50000)
	libzstd.so.1 => /usr/lib/libzstd.so.1 (0x0000ffff86eb0000)
	libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0x0000ffff86d30000)
	libGLdispatch.so.0 => /usr/lib/libGLdispatch.so.0 (0x0000ffff86ba0000)
	libGLX.so.0 => /usr/lib/libGLX.so.0 (0x0000ffff86b50000)
	libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x0000ffff86a60000)
	libgraphite2.so.3 => /usr/lib/libgraphite2.so.3 (0x0000ffff86a20000)
	libcap.so.2 => /usr/lib/libcap.so.2 (0x0000ffff86a00000)
	libgcrypt.so.20 => /usr/lib/libgcrypt.so.20 (0x0000ffff868f0000)
	liblzma.so.5 => /usr/lib/liblzma.so.5 (0x0000ffff868b0000)
	liblz4.so.1 => /usr/lib/liblz4.so.1 (0x0000ffff86870000)
	libicudata.so.72 => /usr/lib/libicudata.so.72 (0x0000ffff84a80000)
	libpcre2-8.so.0 => /usr/lib/libpcre2-8.so.0 (0x0000ffff849e0000)
	libX11.so.6 => /usr/lib/libX11.so.6 (0x0000ffff84880000)
	libbz2.so.1.0 => /usr/lib/libbz2.so.1.0 (0x0000ffff84850000)
	libbrotlidec.so.1 => /usr/lib/libbrotlidec.so.1 (0x0000ffff84830000)
	libgpg-error.so.0 => /usr/lib/libgpg-error.so.0 (0x0000ffff847f0000)
	libxcb.so.1 => /usr/lib/libxcb.so.1 (0x0000ffff847b0000)
	libbrotlicommon.so.1 => /usr/lib/libbrotlicommon.so.1 (0x0000ffff84770000)
	libXau.so.6 => /usr/lib/libXau.so.6 (0x0000ffff84750000)
	libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x0000ffff84730000)
[feedc0de@raspberrypi3-00 ~]$ ldd /usr/bin/makemkvcon
	linux-vdso.so.1 (0x0000ffff8e381000)
	libmakemkv.so.1 => /usr/lib/libmakemkv.so.1 (0x0000ffff8daa0000)
	libdriveio.so.0 => /usr/lib/libdriveio.so.0 (0x0000ffff8da80000)
	libpthread.so.0 => /usr/lib/libpthread.so.0 (0x0000ffff8da60000)
	libc.so.6 => /usr/lib/libc.so.6 (0x0000ffff8d8a0000)
	/lib/ld-linux-aarch64.so.1 => /usr/lib/ld-linux-aarch64.so.1 (0x0000ffff8e348000)
	libdl.so.2 => /usr/lib/libdl.so.2 (0x0000ffff8d880000)
	librt.so.1 => /usr/lib/librt.so.1 (0x0000ffff8d860000)
	libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x0000ffff8d600000)
	libcrypto.so.3 => /usr/lib/libcrypto.so.3 (0x0000ffff8d180000)
	libz.so.1 => /usr/lib/libz.so.1 (0x0000ffff8d150000)
	libexpat.so.1 => /usr/lib/libexpat.so.1 (0x0000ffff8d110000)
	libavcodec.so.59 => /usr/lib/libavcodec.so.59 (0x0000ffff8bf90000)
	libavutil.so.57 => /usr/lib/libavutil.so.57 (0x0000ffff8bda0000)
	libm.so.6 => /usr/lib/libm.so.6 (0x0000ffff8bcf0000)
	libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0x0000ffff8bcc0000)
	libswresample.so.4 => /usr/lib/libswresample.so.4 (0x0000ffff8bc90000)
	libvpx.so.7 => /usr/lib/libvpx.so.7 (0x0000ffff8ba60000)
	libwebpmux.so.3 => /usr/lib/libwebpmux.so.3 (0x0000ffff8ba40000)
	libwebp.so.7 => /usr/lib/libwebp.so.7 (0x0000ffff8b9d0000)
	liblzma.so.5 => /usr/lib/liblzma.so.5 (0x0000ffff8b990000)
	libdav1d.so.6 => /usr/lib/libdav1d.so.6 (0x0000ffff8b880000)
	libopencore-amrwb.so.0 => /usr/lib/libopencore-amrwb.so.0 (0x0000ffff8b850000)
	librsvg-2.so.2 => /usr/lib/librsvg-2.so.2 (0x0000ffff8b070000)
	libgobject-2.0.so.0 => /usr/lib/libgobject-2.0.so.0 (0x0000ffff8aff0000)
	libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0x0000ffff8ae70000)
	libcairo.so.2 => /usr/lib/libcairo.so.2 (0x0000ffff8ad30000)
	libgsm.so.1 => /usr/lib/libgsm.so.1 (0x0000ffff8ad10000)
	libmp3lame.so.0 => /usr/lib/libmp3lame.so.0 (0x0000ffff8ac80000)
	libopencore-amrnb.so.0 => /usr/lib/libopencore-amrnb.so.0 (0x0000ffff8ac40000)
	libopenjp2.so.7 => /usr/lib/libopenjp2.so.7 (0x0000ffff8abc0000)
	libopus.so.0 => /usr/lib/libopus.so.0 (0x0000ffff8ab50000)
	libspeex.so.1 => /usr/lib/libspeex.so.1 (0x0000ffff8ab20000)
	libtheoraenc.so.1 => /usr/lib/libtheoraenc.so.1 (0x0000ffff8aad0000)
	libtheoradec.so.1 => /usr/lib/libtheoradec.so.1 (0x0000ffff8aaa0000)
	libvorbis.so.0 => /usr/lib/libvorbis.so.0 (0x0000ffff8aa60000)
	libvorbisenc.so.2 => /usr/lib/libvorbisenc.so.2 (0x0000ffff8a9a0000)
	libx264.so.164 => /usr/lib/libx264.so.164 (0x0000ffff8a740000)
	libx265.so.199 => /usr/lib/libx265.so.199 (0x0000ffff8a520000)
	libxvidcore.so.4 => /usr/lib/libxvidcore.so.4 (0x0000ffff8a420000)
	libva.so.2 => /usr/lib/libva.so.2 (0x0000ffff8a3d0000)
	libva-drm.so.2 => /usr/lib/libva-drm.so.2 (0x0000ffff8a3b0000)
	libva-x11.so.2 => /usr/lib/libva-x11.so.2 (0x0000ffff8a390000)
	libvdpau.so.1 => /usr/lib/libvdpau.so.1 (0x0000ffff8a370000)
	libX11.so.6 => /usr/lib/libX11.so.6 (0x0000ffff8a210000)
	libdrm.so.2 => /usr/lib/libdrm.so.2 (0x0000ffff8a1e0000)
	libOpenCL.so.1 => /usr/lib/libOpenCL.so.1 (0x0000ffff8a190000)
	libsoxr.so.0 => /usr/lib/libsoxr.so.0 (0x0000ffff8a110000)
	libcairo-gobject.so.2 => /usr/lib/libcairo-gobject.so.2 (0x0000ffff8a0f0000)
	libgdk_pixbuf-2.0.so.0 => /usr/lib/libgdk_pixbuf-2.0.so.0 (0x0000ffff8a090000)
	libgio-2.0.so.0 => /usr/lib/libgio-2.0.so.0 (0x0000ffff89e30000)
	libxml2.so.2 => /usr/lib/libxml2.so.2 (0x0000ffff89ca0000)
	libpangocairo-1.0.so.0 => /usr/lib/libpangocairo-1.0.so.0 (0x0000ffff89c80000)
	libpango-1.0.so.0 => /usr/lib/libpango-1.0.so.0 (0x0000ffff89bf0000)
	libffi.so.8 => /usr/lib/libffi.so.8 (0x0000ffff89bd0000)
	libpcre2-8.so.0 => /usr/lib/libpcre2-8.so.0 (0x0000ffff89b30000)
	libpng16.so.16 => /usr/lib/libpng16.so.16 (0x0000ffff89ae0000)
	libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0x0000ffff89a70000)
	libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x0000ffff89980000)
	libXext.so.6 => /usr/lib/libXext.so.6 (0x0000ffff89950000)
	libXrender.so.1 => /usr/lib/libXrender.so.1 (0x0000ffff89930000)
	libxcb.so.1 => /usr/lib/libxcb.so.1 (0x0000ffff898f0000)
	libxcb-render.so.0 => /usr/lib/libxcb-render.so.0 (0x0000ffff898d0000)
	libxcb-shm.so.0 => /usr/lib/libxcb-shm.so.0 (0x0000ffff898b0000)
	libpixman-1.so.0 => /usr/lib/libpixman-1.so.0 (0x0000ffff89830000)
	libogg.so.0 => /usr/lib/libogg.so.0 (0x0000ffff89810000)
	libXfixes.so.3 => /usr/lib/libXfixes.so.3 (0x0000ffff897f0000)
	libgomp.so.1 => /usr/lib/libgomp.so.1 (0x0000ffff89790000)
	libgmodule-2.0.so.0 => /usr/lib/libgmodule-2.0.so.0 (0x0000ffff89770000)
	libjpeg.so.8 => /usr/lib/libjpeg.so.8 (0x0000ffff89700000)
	libtiff.so.5 => /usr/lib/libtiff.so.5 (0x0000ffff89660000)
	libmount.so.1 => /usr/lib/libmount.so.1 (0x0000ffff895d0000)
	libicuuc.so.72 => /usr/lib/libicuuc.so.72 (0x0000ffff893a0000)
	libpangoft2-1.0.so.0 => /usr/lib/libpangoft2-1.0.so.0 (0x0000ffff89370000)
	libharfbuzz.so.0 => /usr/lib/libharfbuzz.so.0 (0x0000ffff89250000)
	libfribidi.so.0 => /usr/lib/libfribidi.so.0 (0x0000ffff89220000)
	libthai.so.0 => /usr/lib/libthai.so.0 (0x0000ffff89200000)
	libbz2.so.1.0 => /usr/lib/libbz2.so.1.0 (0x0000ffff891d0000)
	libbrotlidec.so.1 => /usr/lib/libbrotlidec.so.1 (0x0000ffff891b0000)
	libXau.so.6 => /usr/lib/libXau.so.6 (0x0000ffff89190000)
	libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x0000ffff89170000)
	libzstd.so.1 => /usr/lib/libzstd.so.1 (0x0000ffff890d0000)
	libblkid.so.1 => /usr/lib/libblkid.so.1 (0x0000ffff89050000)
	libicudata.so.72 => /usr/lib/libicudata.so.72 (0x0000ffff87260000)
	libgraphite2.so.3 => /usr/lib/libgraphite2.so.3 (0x0000ffff87220000)
	libdatrie.so.1 => /usr/lib/libdatrie.so.1 (0x0000ffff87200000)
	libbrotlicommon.so.1 => /usr/lib/libbrotlicommon.so.1 (0x0000ffff871c0000)
Might be that I forgot the iso: prefix, thanks for pointing out, I get the same signal with iso: prefix:
[feedc0de@raspberrypi3-00 ~]$ gdb --args makemkvcon info iso:/mnt/komposthaufen/multimedia/Videos/Filme_deutsch/Star.Trek.The.Motion.Picture.The.Directors.Edition.1979.COMPLETE.UHD.BLURAY-SURCODE/STAR_TREK_THE_MOTION_PICTURE.ISO
GNU gdb (GDB) 12.1
(gdb) r
Starting program: /usr/bin/makemkvcon info iso:/mnt/komposthaufen/multimedia/Videos/Filme_deutsch/Star.Trek.The.Motion.Picture.The.Directors.Edition.1979.COMPLETE.UHD.BLURAY-SURCODE/STAR_TREK_THE_MOTION_PICTURE.ISO
[New Thread 0xfffff15feba0 (LWP 182321)]
(gdb) bt
(gdb)
Also my main goal here is to get the GUI working, I was just guessing that NO_ANSWER_FROM_MAKEMKVCON happens because of the sigill to the cmdline tool. Maybe another error like UNEXPECTED_EXIT_FROM_MAKEMKVCON would be more detailed on what the problem is in that case.
is makemkvcon open-source or compilable? I have not looked in the archlinux aur PKGBUILD yet, but if I compile it with debug info enabled we might get more insights, right?
Post by mike admin »
Please do collect the core dump and send to support@makemkv.com . Thanks!
darkblade
Post by darkblade »
I think I have the same issue. I am on a raspberry 4 and I dont have a GUI but on cli I get the same error. I couldnt firgure out how to collect the dump but I can add that I've also got a copy of version 1.16.7 and it looks like it doesnt suffer the same issue.
I hope this little bit of information helps on firguring the issue!
Version 1.17.2
makemkvcon -r info disc:999
Illegal instruction (core dumped)
Version 1.16.7:
MSG:1005,0,1,"MakeMKV v1.16.7 linux(arm64-release) started","%1 started","MakeMKV v1.16.7 linux(arm64-release)"
MSG:5075,131072,2,"The new version 1.17.2 is available for download at http://www.makemkv.com/download/","The new version %1 is available for download at %2","1.17.2","http://www.makemkv.com/download/"                                       DRV:0,1,999,0,"BD-RE PIONEER BD-RW   BDR-UD04 1.14 ALDL094451WL","","/dev/sr0"                  DRV:1,256,999,0,"","",""
DRV:2,256,999,0,"","",""                        DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""                        DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""                        DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""                       DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""                       DRV:15,256,999,0,"","",""
MSG:5021,131332,1,"This application version is too old.  Please download the latest version at http://www.makemkv.com/ or enter a registration key to continue using the current version.","This application version is too old.  Please download the latest version at %1 or enter a registration key to continue using the current version.","http://www.makemkv.com/"
Prototype8588
Post by Prototype8588 »
I have the same issue on a Raspberry Pi 4 as well.
Version 1.17.2:
#> makemkvcon list
Version 1.17.1:
#> makemkvcon list
MakeMKV v1.17.1 linux(arm64-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
The program can't find any usable optical drives.
Therefore this appears to me as being a regression in the latest version.
alexindigo
Post by alexindigo »
Seeing the same issue with 1.17.3.
$ makemkvcon list
MakeMKV v1.17.3 linux(arm64-release) started
Illegal instruction
alexindigo wrote: Sat Feb 04, 2023 6:41 am Seeing the same issue with 1.17.3.
It was explicitly fixed :((((
Please send the dump again then. Is there any simple way to emulate RPI3 environment with qemu or something similar?
Prototype8588
$ makemkvcon list
Illegal instruction
I think it is more of a similar issue. Note that now the 'Illegal Instruction' is not printed immediately but after the version header. This leads me to the assumption that fixing the issue in v1.17.2 was successful and revealed a different issue with the same error message.
alexindigo
How do I get dump and send it to you?
Thanks.
PS. For RPI, not sure how to emulate it.
Also, I kind of managed to run it on Synology, via docker.
Funky
Post by Funky »
Exactly the same thing happening here. RPi4 (4GB), 1.17.3 and same error message. 1.17.2 also did not work - as noted above, may well have been a different error.
This is all after the fix in this post incidentally: viewtopic.php?f=3&t=30396
Happy to send a coredump file if it helps - how do I do that for linux (found instructions on the site but for Windows and OSX)
sfatula
Post by sfatula »
Same problem here on a Rpi4 using flathub. Not sure what computer admin is using, but, here's how on linux to emulate:
https://gist.github.com/plembo/c4920016 ... 5cb9a3a25e
deinvater
Post by deinvater »
Having the same issue on my Pi4 running Debian.
My ldd shows:
        linux-vdso.so.1 (0x0000007fafc09000)
        libstdc++.so.6 => /lib/aarch64-linux-gnu/libstdc++.so.6 (0x0000007fadcb9000)
        libQt5Widgets.so.5 => /lib/aarch64-linux-gnu/libQt5Widgets.so.5 (0x0000007fad5f7000)
        libQt5Gui.so.5 => /lib/aarch64-linux-gnu/libQt5Gui.so.5 (0x0000007facf68000)
        libQt5DBus.so.5 => /lib/aarch64-linux-gnu/libQt5DBus.so.5 (0x0000007facecd000)
        libQt5Core.so.5 => /lib/aarch64-linux-gnu/libQt5Core.so.5 (0x0000007fac965000)
        libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0 (0x0000007fac934000)
        libz.so.1 => /lib/aarch64-linux-gnu/libz.so.1 (0x0000007fac90a000)
        librt.so.1 => /lib/aarch64-linux-gnu/librt.so.1 (0x0000007fac8f2000)
        libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000007fac77d000)
        libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1 (0x0000007fac759000)
        libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000007fac6ae000)
        /lib/ld-linux-aarch64.so.1 (0x0000007fafbd9000)
        libGL.so.1 => /lib/aarch64-linux-gnu/libGL.so.1 (0x0000007fac5b7000)
        libpng16.so.16 => /lib/aarch64-linux-gnu/libpng16.so.16 (0x0000007fac570000)
        libharfbuzz.so.0 => /lib/aarch64-linux-gnu/libharfbuzz.so.0 (0x0000007fac480000)
        libmd4c.so.0 => /lib/aarch64-linux-gnu/libmd4c.so.0 (0x0000007fac461000)
        libdbus-1.so.3 => /lib/aarch64-linux-gnu/libdbus-1.so.3 (0x0000007fac3fb000)
        libdouble-conversion.so.3 => /lib/aarch64-linux-gnu/libdouble-conversion.so.3 (0x0000007fac3d7000)
        libicui18n.so.67 => /lib/aarch64-linux-gnu/libicui18n.so.67 (0x0000007fac0cd000)
        libicuuc.so.67 => /lib/aarch64-linux-gnu/libicuuc.so.67 (0x0000007fabed5000)
        libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2 (0x0000007fabec1000)
        libpcre2-16.so.0 => /lib/aarch64-linux-gnu/libpcre2-16.so.0 (0x0000007fabe39000)
        libzstd.so.1 => /lib/aarch64-linux-gnu/libzstd.so.1 (0x0000007fabd6d000)
        libglib-2.0.so.0 => /lib/aarch64-linux-gnu/libglib-2.0.so.0 (0x0000007fabc2a000)
        libGLdispatch.so.0 => /lib/aarch64-linux-gnu/libGLdispatch.so.0 (0x0000007faba9f000)
        libGLX.so.0 => /lib/aarch64-linux-gnu/libGLX.so.0 (0x0000007faba5c000)
        libfreetype.so.6 => /lib/aarch64-linux-gnu/libfreetype.so.6 (0x0000007fab997000)
        libgraphite2.so.3 => /lib/aarch64-linux-gnu/libgraphite2.so.3 (0x0000007fab965000)
        libsystemd.so.0 => /lib/aarch64-linux-gnu/libsystemd.so.0 (0x0000007fab89f000)
        libicudata.so.67 => /lib/aarch64-linux-gnu/libicudata.so.67 (0x0000007fa9d78000)
        libpcre.so.3 => /lib/aarch64-linux-gnu/libpcre.so.3 (0x0000007fa9d06000)
        libX11.so.6 => /lib/aarch64-linux-gnu/libX11.so.6 (0x0000007fa9bb9000)
        libbrotlidec.so.1 => /lib/aarch64-linux-gnu/libbrotlidec.so.1 (0x0000007fa9b9e000)
        liblzma.so.5 => /lib/aarch64-linux-gnu/liblzma.so.5 (0x0000007fa9b66000)
        liblz4.so.1 => /lib/aarch64-linux-gnu/liblz4.so.1 (0x0000007fa9b37000)
        libgcrypt.so.20 => /lib/aarch64-linux-gnu/libgcrypt.so.20 (0x0000007fa9a67000)
        libxcb.so.1 => /lib/aarch64-linux-gnu/libxcb.so.1 (0x0000007fa9a2f000)
        libbrotlicommon.so.1 => /lib/aarch64-linux-gnu/libbrotlicommon.so.1 (0x0000007fa99fe000)
        libgpg-error.so.0 => /lib/aarch64-linux-gnu/libgpg-error.so.0 (0x0000007fa99c9000)
        libXau.so.6 => /lib/aarch64-linux-gnu/libXau.so.6 (0x0000007fa99b5000)
        libXdmcp.so.6 => /lib/aarch64-linux-gnu/libXdmcp.so.6 (0x0000007fa999f000)
        libbsd.so.0 => /lib/aarch64-linux-gnu/libbsd.so.0 (0x0000007fa997a000)
        libmd.so.0 => /lib/aarch64-linux-gnu/libmd.so.0 (0x0000007fa995e000)
itsjado
Post by itsjado »
Same deal here with a Pi4 running Arch.
 	linux-vdso.so.1 (0x0000007fb0169000)
        libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x0000007fae170000)
        libQt5Widgets.so.5 => /usr/lib/libQt5Widgets.so.5 (0x0000007fada00000)
        libQt5Gui.so.5 => /usr/lib/libQt5Gui.so.5 (0x0000007fad2f0000)
        libQt5DBus.so.5 => /usr/lib/libQt5DBus.so.5 (0x0000007fad230000)
        libQt5Core.so.5 => /usr/lib/libQt5Core.so.5 (0x0000007facc60000)
        libz.so.1 => /usr/lib/libz.so.1 (0x0000007facc30000)
        libc.so.6 => /usr/lib/libc.so.6 (0x0000007faca70000)
        /lib/ld-linux-aarch64.so.1 => /usr/lib/ld-linux-aarch64.so.1 (0x0000007fb0130000)
        libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0x0000007faca40000)
        libm.so.6 => /usr/lib/libm.so.6 (0x0000007fac990000)
        libGL.so.1 => /usr/lib/libGL.so.1 (0x0000007fac890000)
        libpng16.so.16 => /usr/lib/libpng16.so.16 (0x0000007fac840000)
        libharfbuzz.so.0 => /usr/lib/libharfbuzz.so.0 (0x0000007fac700000)
        libmd4c.so.0 => /usr/lib/libmd4c.so.0 (0x0000007fac6d0000)
        libdbus-1.so.3 => /usr/lib/libdbus-1.so.3 (0x0000007fac650000)
        libsystemd.so.0 => /usr/lib/libsystemd.so.0 (0x0000007fac520000)
        libdouble-conversion.so.3 => /usr/lib/libdouble-conversion.so.3 (0x0000007fac4f0000)
        libicui18n.so.73 => /usr/lib/libicui18n.so.73 (0x0000007fac160000)
        libicuuc.so.73 => /usr/lib/libicuuc.so.73 (0x0000007fabf20000)
        libpcre2-16.so.0 => /usr/lib/libpcre2-16.so.0 (0x0000007fabe80000)
        libzstd.so.1 => /usr/lib/libzstd.so.1 (0x0000007fabdb0000)
        libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0x0000007fabc30000)
        libGLdispatch.so.0 => /usr/lib/libGLdispatch.so.0 (0x0000007fabaa0000)
        libGLX.so.0 => /usr/lib/libGLX.so.0 (0x0000007faba50000)
        libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x0000007fab970000)
        libgraphite2.so.3 => /usr/lib/libgraphite2.so.3 (0x0000007fab930000)
        libcap.so.2 => /usr/lib/libcap.so.2 (0x0000007fab910000)
        libgcrypt.so.20 => /usr/lib/libgcrypt.so.20 (0x0000007fab800000)
        liblzma.so.5 => /usr/lib/liblzma.so.5 (0x0000007fab7c0000)
        liblz4.so.1 => /usr/lib/liblz4.so.1 (0x0000007fab780000)
        libicudata.so.73 => /usr/lib/libicudata.so.73 (0x0000007fa98e0000)
        libpcre2-8.so.0 => /usr/lib/libpcre2-8.so.0 (0x0000007fa9840000)
        libX11.so.6 => /usr/lib/libX11.so.6 (0x0000007fa96e0000)
        libbz2.so.1.0 => /usr/lib/libbz2.so.1.0 (0x0000007fa96b0000)
        libbrotlidec.so.1 => /usr/lib/libbrotlidec.so.1 (0x0000007fa9690000)
        libgpg-error.so.0 => /usr/lib/libgpg-error.so.0 (0x0000007fa9650000)
        libxcb.so.1 => /usr/lib/libxcb.so.1 (0x0000007fa9610000)
        libbrotlicommon.so.1 => /usr/lib/libbrotlicommon.so.1 (0x0000007fa95d0000)
        libXau.so.6 => /usr/lib/libXau.so.6 (0x0000007fa95b0000)
        libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x0000007fa9590000)
