Casino Royale causes fatal error in MakeMKV
TheFopp
#1 Post by TheFopp » Sat Apr 23, 2011 11:40 am
Casino Royale DVD (from 2 disc collectors edition) causes MakeMKV to Fatal Error when it tries to read the disc.
Here's the log file:
Debug log started at Sat Apr 23 11:34:07 2011 , written by MakeMKV v1.6.7 darwin(x86-release)
Using 458880KB for read cache.
001005:0000 MakeMKV v1.6.7 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/MediaServer/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI v1.2 mode.
001003:0020 DEBUG: Code 2 at 39c]U=R!S2$5#W}<:121268719
001003:0020 DEBUG: Code 10551308 at rsGnyNbbE'sVz`=s:29400094
001003:0020 DEBUG: Code 0 at rsGnyNbbE'sVz`=s:29401267
001003:0020 DEBUG: Code 0 at "9'P>+WAy(t'Q&;5e^:213130582
003035:0000 CellWallk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
003037:0000 Cells 1-25 were removed from title start
003038:0000 Cells 73-73 were removed from title end
003028:0000 Title #0 was added (47 cell(s), 2:18:07)
003028:0000 Title #1 was added (2 cell(s), 0:02:27)
003028:0000 Title #2 was added (2 cell(s), 0:02:05)
003025:0000 Title #3 has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Re: Casino Royale causes fatal error in MakeMKV
#2 Post by mike admin » Mon Apr 25, 2011 9:50 am
Please update to 1.6.8 and if it crashes too, send IFO files per instructions at http://www.makemkv.com/faq/item/8/catid/6
