MakeMKV see movie Robots in two pieces
NotMe
#1 Post by NotMe » Thu May 17, 2012 2:04 pm
Hi all,
Blu-Ray : Robots
MakeMKV (1.7.4).
MakeMkv see the movie Robots (1h29) in two pieces (1h23 + 6 min).
Then, i can't save it in one mkv.
NotMe
Re: MakeMKV see movie Robots in two pieces
#2 Post by NotMe » Thu May 17, 2012 2:06 pm
Here are clipinf, playlist and log file.
NotMe
#3 Post by NotMe » Thu Jun 21, 2012 3:51 am
Same poblem with MakeMKV 1.7.5.
I'm disappointed.
Can't MakeMKV handle this movie ?
Smithcraft
#4 Post by Smithcraft » Thu Jun 21, 2012 6:30 am
Maybe not. Can you mux the two parts together with mkvtoolnix?
SC
NotMe
#5 Post by NotMe » Thu Jun 21, 2012 6:45 pm
Smithcraft wrote:Maybe not. Can you mux the two parts together with mkvtoolnix?
SC
Well, I've bought MakeMKV to do the job, and not to have to install other tools to complete the backup.
I've already saved succesfully more than 200 BD with just MakeMKV.
This is the only one I can't. Sad...
paulster
#6 Post by paulster » Thu Jun 21, 2012 9:32 pm
Have you sent a testdump to Mike yet?
NotMe
#7 Post by NotMe » Fri Jun 22, 2012 6:20 pm
paulster wrote:Have you sent a testdump to Mike yet?
No because there is no crash.
paulster
#8 Post by paulster » Fri Jun 22, 2012 6:45 pm
You can still run a testdump and end up with a compressed file to send. Check the FAQ.
setarip_old
#9 Post by setarip_old » Fri Jun 22, 2012 9:43 pm
@NotMe
Hi!
It may be that your "Robots" disc contains "seamless branching" - and that MakeMKV is not handling it properly...
On the other hand, have you played either or both 26 chapter files to determine whether they may already include the "extra" 6 minute file (That is reflected as having NO chapters)?
NotMe
#10 Post by NotMe » Sat Jun 23, 2012 12:16 pm
setarip_old wrote:@NotMe
Hi!
In both angles, the movie stop brutally.
FYI it's a BD+ protected disk.
SonOfJacob
#11 Post by SonOfJacob » Wed Nov 30, 2022 3:53 am
10 years later and I experienced this same exact thing. On the bluray I own it's the 00850.mpls file (majority of the movie) and the 00820.m2ts file (credits only).
Notice that the 00820 file for the credits had the .m2ts extension - I believe that may be where the issue lies - in the authorship of the bluray itself.
For context, I've been using MakeMKV and MKVToolNix for over 7 years and have around 2100+ bluray discs and about 4500+ tv shows (bluray and dvd).
This scenario doesn't exist on any of them except this one. Not sure if Mike wants to make a thing out of this, but thought I'd try to bring closure to it.
There are other playlists for the credits, but the only difference I picked up were the songs playing during the credits - everything was in English.
I'll just mux them together using MKVToolNix and call it good. Watch your "Minimum title length" under the Preferences. The 00820 file is only 6 minutes and 8 seconds long.
jaysnuh
#12 Post by jaysnuh » Wed Feb 04, 2026 11:30 pm
Here we are in early 2026 and I've run into the same issue with the Blu-ray for Robots. The title that contains the feature is separate from the end credits file; I'll take your word for it that they can be successfully muxed together to make a single file that Handbrake can handle. I'll have to attempt that another time when I can figure out how to use the MKVToolnix app with the MakeMKV output to create a complete file to feed to Handbrake.
