Delete Profiles?
dickwrigley
Delete Profiles?
Post by dickwrigley » Sun Nov 27, 2022 1:54 am
I've managed to create custome profiles, but how do I delete pre-existing ones? WDTV and AAC specifically. I will never use them.
Re: Delete Profiles?
Post by Woodstock » Mon Nov 28, 2022 4:55 am
It IS possible to delete some of the "default profiles", but they will return at the next update. They're part of one of the default files loaded by MakeMKV when it starts.
Additional files, such as "FLACustom" in your example, are NOT automatically overwritten, as they are not stored in the archive that is part of the download. They're stored in the "MakeMKV data directory" you designate, and you could delete them from there, if you want.
