John Wick 3
DukeD
John Wick 3
Post by DukeD »
Anyone having a problem with this one? Here's my results:
MakeMKV v1.14.5 win(x64-release) started
Title #1 was added (21 cell(s), 2:12:05)
Title #2 was added (1 cell(s), 0:10:57)
Title #3 was added (1 cell(s), 0:09:44)
Title #4 was added (1 cell(s), 0:02:14)
Title #5 was added (1 cell(s), 0:02:27)
Title #6 has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 was added (1 cell(s), 0:06:53)
Title #33 has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #34 has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #36 has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37 was added (1 cell(s), 0:02:12)
Title #38 was added (1 cell(s), 0:02:12)
Title #39 was added (1 cell(s), 0:02:30)
Title #40 was added (1 cell(s), 0:02:30)
Title #41 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #42 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #46 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #47 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #48 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #52 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #53 was added (1 cell(s), 0:09:55)
Title #54 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #57 was added (21 cell(s), 2:12:05)
Cells 2-4 were skipped due to cell commands (structure protection?)
Title #58 was added (17 cell(s), 2:06:16)
Title #59 was added (17 cell(s), 2:07:02)
Title #60 was added (17 cell(s), 2:06:27)
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 19-19 were removed from title end
Title #61 was added (17 cell(s), 2:10:31)
Title #62/0/4 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #64 was added (17 cell(s), 2:10:31)
Title #65 was added (17 cell(s), 2:10:31)
Title #66 was added (17 cell(s), 2:10:31)
Title #67 was added (17 cell(s), 2:06:19)
Title #68 was added (17 cell(s), 2:10:31)
Title #69 was added (21 cell(s), 2:12:05)
Title #70 was added (21 cell(s), 2:12:05)
Title 1 in VTS 33 is equal to title 1 and was skipped
Title 2 in VTS 8 is equal to title 1 and was skipped
Title 2 in VTS 9 is equal to title 1 and was skipped
Title 1 in VTS 26 is equal to title 1 and was skipped
Saving 1 titles into directory N:/
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_33_1.VOB' at offset '19073024'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '19073024'
Failed to save title 0 to file N://title_t00.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 1 failed
Thanks for your time and advice!
Re: John Wick 3
Post by d00zah »
Did you happen to load the link provided & read the suggestions?
Std forum advice is typically to 'clean the disc', no matter how pristine it may appear to casual inspection. If that doesn't do it, the referenced 'manual mode' is worth a try.
cologuy
Re: John Wick 3
Post by cologuy »
I get similar message.
Source: DVD purchased from Amazon
MakeMKV version 1.14.5
Read that there may be a 'manual mode' to open the disk, but don't get that option.
I'm using the trail version of the software. If buying/registering would solve this problem would be happy to do so.
Re: John Wick 3
Post by d00zah »
http://www.makemkv.com/manualdvd/
File > 'Open DVD files manually'
cologuy
Re: John Wick 3
Post by cologuy »
As I indicated I read there is a manual mode, but don't get that option. The link/page also indicates a manual mode bit not how to access manual mode. I open the program but then what? Is it a DOS command line etc, other?
Re: John Wick 3
Post by d00zah »
Menu bar, top left...
select 'File' (left-most option) > 'Open DVD files manually' (2nd option in list)
This will produce a new selection dialog listing all detected titles (including anything MakeMKV may have erroneously excluded)...
ManualMode (Small).jpg (55.04 KiB) Viewed 67769 times
Provide the # of the title you want & 'OK'. It will appear in the main title/track selection pane.
Note: This is an over-simplified example, as I have no readily available candidates which actually require this process.
tk1970
Re: John Wick 3
Post by tk1970 »
You need to go into "Preferences" and click the box to enable "Expert Mode" to get the "Open DVD Files Manually" option.
I didn't have a problem ripping John Wick 3, but the resulting file had a 5 minute gap in it near the start (I reckon it's to do with those cells that were reported as being "skipped due to cell commands (structure protection?)"). So I played the DVD in VLC, checked to see what title was actually playing (#74, as it turned out), and then used manual mode to export that title directly. This seemed to have worked, in that the gap isn't there now, but I haven't watched it all the way through yet.
Hope that helps.
cologuy
Re: John Wick 3
Post by cologuy »
tk1970 wrote: Tue Sep 17, 2019 3:28 pm You need to go into "Preferences" and click the box to enable "Export Mode" to get the "Open DVD Files Manually" option.
I didn't have a problem ripping John Wick 3, but the resulting file had a 5 minute gap in it near the start (I reckon it's to do with those cells that were reported as being "skipped due to cell commands (structure protection?)"). So I played the DVD in VLC, checked to see what title was actually playing (#74, as it turned out), and then used manual mode to export that title directly. This seemed to have worked, in that the gap isn't there now, but I haven't watched it all he way through yet.
Hope that helps.
Thanks. I just checked the rip I did, and after about 5 min in it has audio tracks that overlay/play on the incorrect screens or visa versa. So not as simple as I wished. Will try your suggestions.
cologuy
Re: John Wick 3
Post by cologuy »
As a follow up. Success!
Per suggestions, used VLC to see what title was playing.
The using manual mode (after going into Preferences and Manual mode (this would be good to add to the Manual Mode link on the DVD documentation site), then in Manual mode used the title and it worked just fine.
Thanks all for the feedback and suggestions.
AJVal79
Re: John Wick 3
Post by AJVal79 »
I am having the same problem as the OP. I'm new to this so some direction towards what I need to do to get this to work would be great.
Re: John Wick 3
Post by d00zah »
AJVal79 wrote: Wed Oct 02, 2019 5:58 pm I am having the same problem as the OP. I'm new to this so some direction towards what I need to do to get this to work would be great.
Follow instructions in post #7 (in this thread) to enable 'manual mode', followed by post #6. Pictures/stories included.
Wasnotwas87
Re: John Wick 3
Post by Wasnotwas87 »
Thank you d00zah. The graphic showing the location of where to place title strings in manual mode helped a newcomer like me tremendously.
MickD
Re: John Wick 3
Post by MickD »
I am having fun with the John Wick 3 BluRay. it puts the chapters out of order. One minute John is holding up a crucifix to the glass of a gypsy movie house and the next Haille Berry is backwashing his water bottle in the desert.
This is coming from the 3-pack special edition with both blu ray and dvd of all three movies.
Re: John Wick 3
That's because you haven't found the "correct" title yet. The DVD has about a dozen (more on BD and UHD).
Only one of the titles is correct. A couple will be the right length, but the chapter order is screwed up on all but one.
MickD
Re: John Wick 3
Post by MickD »
Oh, great. Any idea which one it is? There's like 30 of them,;)
