I'm unable to rip "The Lost Boys" on 4K. If anyone has any suggestions, it would be much appreciated.
MakeMKV v1.17.2 win(x64-release) started
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Saved AACS dump file as C:\Users\toffe/.MakeMKV/MKB20_v76_The_Lost_Boys_6D95.tgz
Product: BD-RE BU40N
Revision: 1.03
Serial number: MO9M2QE2917
Highest AACS version: 77
Firmware version: 1.03
Disc Information
Label: THE_LOST_BOYS
Timestamp: 2022-07-19 14:05:46
Protection: AACS2.0/C v76
Data capacity: 56.86 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
The Lost Boys 4k Failed to Open Disc
Virtualfryngpan
- MKB20_v76_The_Lost_Boys_6D95.tgz
- (90.13 KiB) Downloaded 284 times
Re: The Lost Boys 4k Failed to Open Disc
UHD FAQ > Hashed Keys sectionVirtualfryngpan wrote: Sun Oct 30, 2022 7:09 pm I'm unable to rip "The Lost Boys" on 4K. If anyone has any suggestions, it would be much appreciated.
Revision: 1.03
Disc Information
Number of layers: 2
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
You could have a bad disc. I was able to rip mine (Amazon US) and here is how the discs mapped out: https://thediscdb.com/movie/the-lost-bo ... es/2022-4k
