Dolby Vision in UHD Backup?
eecho
If i take a full backup of a UHD Blu-Ray disc will it contain Dolby Vision?
bill_w
Re: Dolby Vision in UHD Backup?
It will if the disc contains DV. A full backup just copies the disc.
eecho
Thanks for the info.
ben_uk
What if you just select one of the titles when you do open disc? I just open disc > choose film title > remove non English language tracks > start rip.
Does that copy DV too?
Dolby Vision is part of the video, so if it is part of the video on the disc, then it'll be in the resulting .mkv.
If you use a recent version of the utility MediaInfo on your .mkv files, it'll tell you if they have DV in them.
demon
If you use a suitably new MediaInfo, you should see something like this for the video stream:
Edit: Or maybe this, if your disc has DV and HDR10+:
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 40 min
Bit rate : 69.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.351
Stream size : 49.2 GiB (94%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Original source medium : Blu-rayCode: Select all
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Duration : 1 h 56 min
Bit rate : 78.4 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.394
Stream size : 63.6 GiB (94%)
Language : English
Default : No
Forced : No
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 755 cd/m2
