Dolby Vision in UHD Backup?
eecho
Post by eecho »
If i take a full backup of a UHD Blu-Ray disc will it contain Dolby Vision?
bill_w
Re: Dolby Vision in UHD Backup?
Post by bill_w »
It will if the disc contains DV. A full backup just copies the disc.
eecho
Post by eecho »
Thanks for the info. :)
ben_uk
Post by ben_uk »
What if you just select one of the titles when you do open disc? I just open disc > choose film title > remove non English language tracks > start rip.
Does that copy DV too?
Dolby Vision is part of the video, so if it is part of the video on the disc, then it'll be in the resulting .mkv.
If you use a recent version of the utility MediaInfo on your .mkv files, it'll tell you if they have DV in them.
demon
Post by demon »
If you use a suitably new MediaInfo, you should see something like this for the video stream:
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Duration                                 : 1 h 40 min
Bit rate                                 : 69.8 Mb/s
Bits/(Pixel*Frame)                       : 0.351
Stream size                              : 49.2 GiB (94%)
Edit: Or maybe this, if your disc has DV and HDR10+:
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Duration                                 : 1 h 56 min
Bit rate                                 : 78.4 Mb/s
Bits/(Pixel*Frame)                       : 0.394
Stream size                              : 63.6 GiB (94%)
Maximum Frame-Average Light Level        : 755 cd/m2
