Flashing ASUS BW-16D1H-U PRO on Linux
reifenkauer
Post by reifenkauer »
I bought an ASUS BW-16D1H-U PRO external BluRay drive to rip a 4K UHD Bluray.
The store where I bought it from lists it as BDXL compatible and this page also lists it as UHD friendly.
So I don't quite understand why, when entering "BW-16D1H-U" into the search bar, only posts come up that claim the contrary?
When inserting the UHD disc, this is what makemkv tells me:
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: BADL077655WL
Firmware date: 2020-07-21
Firmware version: ID71
Is it expected behaviour that the disc is not recognized at all? Or is this drive actually mistakenly labelled as UHD friendly or is that a remnant of past revisions? Or is the disc broken?
Nevertheless, I tried to flash the firmware, but apparently sdftool does not support the flash command for this drive:
$ sdftool -d /dev/sr0 help all
Pioneer firmware module v1.20
Commands:
  dump [auto|full] dumps firmware image
    dump full      - dumps full rom image (if not disabled in firmware)
    dump auto      - dumps full image if possible, info data otherwise
    speed get      - prints current speed mode setting
    speed set MODE - writes new default speed mode to EEPROM
$ sdftool -d /dev/sr0 -f ./sdf_00000093.bin flash -i ./ASUS-BW-16D1H-U-A204-WM01001-211901041044.bin
Unknown command
Command produced error code 0xffffffff
This seems to be a common problem on Linux according to this thread
So I even tried out the other tool linked in the thread which only gives me the following:
$ sudo ./flasher -d /dev/cdrom --flash ./ASUS-BW-16D1H-U-A204-WM01001-211901041044.bin
Devilsclaw's LG Renesas Drive Utility
cmd_drive: Opening Drive: /dev/cdrom.
cmd_flashfirm: Flashing process started
firm_flasher: Drive should be flashing its light.
firm_flasher: This indicates its flashing its self.
firm_flasher: This can take a while, Please be patiant.
firm_flasher: Failed to write at 0x00000000
firm_flasher: your drive should still be fine.
cmd_flashfirm: Flashing process failed
So what exactly are my options here?
Re: Flashing ASUS BW-16D1H-U PRO on Linux
thats a pioneer drive flashing instructions are not public for that yet
