sw5163
Post by sw5163 »
bobbymkV wrote: Thu Nov 17, 2022 2:27 pm HDR10+ source is the correct answer.
legosoff
Post by legosoff »
Hi! Crop RPU which mode? Thank you in advance.
sergonnn111
Post by sergonnn111 »
i want to buy DUNE HD REAL VISION 4K , do i get dolby vision from mkv 7profile dolby vision BL+EL+RPU, is it real dolby vision on dune hd real vision 4k, please guys i need your advice ?
ArArdin
Post by ArArdin »
Yes, you'll get Dolby Vision with P7 mkv. However in case of FEL, this layer is disregarded and only BL and RPU will be processed.
RTD1619DR based players simply lack a second HEVC decoder.
Post by Manixx2020beyound »
Resolve 18.1
To import profile 5 dv clips into resolve they must have dvh1 flag not dvhe flag, tested this on windows platform, test file glass blowing original iOS p5 4K 59.974.
Converted on resolve timeline then export to yuv 422 10bit, along with a new dv analysis xml.
U can then encode in staxrip to a new 8.1(almost no quality loss ) or encode a 8.1/8.4 in resolve it self.
U can also down convert to 1080p if that’s your desire.
Resolve also decoded any p5 encoded from resolve, testing some dv demos and p5 real mov which has mostly dvhe
Will not work on window unless u have a dv license
daddy
Post by daddy »
ArArdin wrote: Tue Nov 22, 2022 9:28 am Yes, you'll get Dolby Vision with P7 mkv. However in case of FEL, this layer is disregarded and only BL and RPU will be processed.
So this is not real Dolby Vision profile 7.
ArArdin
Post by ArArdin »
daddy wrote: Tue Nov 22, 2022 5:33 pmSo this is not real Dolby Vision profile 7.
Here, "this" is a bit tricky as I don't know if you mean the playback or the sourcefile. To start with P7 mkv as source, it is "real" as it does carry all video- and metadata that is on disc.
If you mean "DV FEL playback" on RTD1619DR players, then no, it isn't "real" Dolby Vision. It is noticeable whether FEL is being processed or not. Certainly in A-B comparison.
There are some mediaplayers (and tv's built-in players) that do process FEL. I wouldn't call it "real" Dolby Vision though. Nowadays tv's lack native 12 bit panels and couldn't produce enough nits for even 10 bit colors. So do realise that, after the initial processes which produce a full-blown Dolby Vision image, color depths and brightness dynamics have to be significantly downscaled to meet the display's physical capabilities.
sergonnn111
ArArdin wrote: Wed Nov 23, 2022 1:29 pm
So you don t advice DUNE HD REAL VISION 4K for P7 MKV dolby vision to buy ?
staknhalo
Post by staknhalo »
Gotta be honest, I make/keep 7 FEL and 8 for storage reasons + non-DV playback devices and only keep 5 (and then HDR10 version also) if I have to, but as long as you can watch 5 that's good enough. Of course I'm saying this because I can play and compare all of them to decide myself. But I only do all this for archive stuff, when watching brand new stuff for the first time I often just watch the dv5 file.
Gatorman
Post by Gatorman »
legosoff wrote: Sat Nov 19, 2022 5:48 am Hi! Crop RPU which mode? Thank you in advance.
You can crop them manually with the dovi_tool itself (CMD). However there is an option to crop RPU's during the inject workflows (Mode.I).
ArArdin
Post by ArArdin »
sergonnn111 wrote: Wed Nov 23, 2022 9:02 pmSo you don t advice DUNE HD REAL VISION 4K for P7 MKV dolby vision to buy ?
I can't help keeping to remind that not every P7 carries FEL. It can have MEL instead, which is equivalent to P8.1.
That having said, I couldn't advice on whether to buy or not. In my viewing environment, the additional impact varies per title. During regular playback sometimes it's even hard to notice. Where you could only tell by scrutaneous A-B comparison on still images. To my eyes screen calibration brought more joy than additional FEL enhancement. It comes with a pricetag though.
Among my players is a RTD1619 based Zidoo Z9X. When viewing a FEL movie, I have no urge to switch to UHDBD player because I'd miss out on something. There is a lot to be enjoyed on DV even if FEL is ignored. IMO, the main awe of Dolby Vision (and HDR10+ for that matter) lies in the applyance of dynamical metadata.
Everybody should decide for himself. Go compare players that do and don't support FEL processing. Where you also may want to compare tv-led to lldv. Imagine a lower-end tv displaying a better picture when tonemapping is performed by a higher-end player. And vice-versa.
staknhalo wrote: Wed Nov 23, 2022 10:10 pm...as long as you can watch 5 that's good enough.
I'm definitely keeping an eye on P5. When these streams became available I did have problems with the "quality".
Which overall has significantly improved though, and seems to keep improving.
Was able to decode all the p5’s I tested,doblyvision demos as well as including full p5 real web dl rips!
Both clips on the time line are p5 only converted to p8
Mac users are having more fun smh.
Bc the option is free on the mac.
Gatorman
Post by Gatorman »
Manixx2020beyound wrote: Thu Nov 24, 2022 7:58 pm Was able to decode all the p5’s I tested,doblyvision demos as well as including full p5 real web dl rips!
What steps did you take to decode P5? Should it happen automatically?
Gatorman wrote: Fri Nov 25, 2022 6:14 pm
Are u using a Mac ?
If so did u try Glass blowing??
It should happen automatically but it does not for 99% of the demos & p5 web dl I tested at 1st.
But they do now.
I did not update my mac yet just been testing on windows but I am curious about the mac as well.
Gatorman
Post by Gatorman »
Manixx2020beyound wrote: Fri Nov 25, 2022 7:05 pm Are u using a Mac ?
But they do now.
I'm running Windows.
