Transformers: Revenge of the Fallen
mattxlau
Post by mattxlau »
I purchased Bumblebee & Transformers Ultimate 6-Movie Collection [Blu-ray + Digital] (https://a.co/d/hybzJMe) and was able to successfully rip all discs except for Transformers: Revenge of the Fallen.
This was the second of 6 discs attempted, and I attempted to run MakeMKV multiple times, encountering the same error. Subsequent discs in this collection were ripped without error.
Here's the log readout:
MakeMKV v1.17.2 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/mattxlau/MakeMKV_log.txt
Optical drive "BD-RE PIONEER BD-RW BDR-XS07U 1.01 BBDL005766UCd" opened in OS access mode.
Using LibreDrive mode (v01.0 id=1534D764B687)
Evaluation version, 26 day(s) out of 30 remaining
File 00003.mpls was added as title #0
Title #00005.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.mpls has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00998.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00999.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01015.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01016.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/mattxlau/Movies/Transformers- Revenge of the Fallen Disc 1
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '19638122496'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '19638386688'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '26107969536'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '26107969536'
DEBUG: Code 1073741829 at LHLd>,:XQ hoYXW(uJ:213131502
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '26108295168'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '26108295168'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '26108559360'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '26108559360'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '26108755968'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '26108884992'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '26109210624'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '26109474816'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '26109474816'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '26109542400'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '26109800448'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '26109800448'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '26110132224'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '26110132224'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '26110390272'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '26110390272'
DEBUG: Code 100864261 at LHLd>,:XQ hoYXW(uJ:213131502
DEBUG: Code 0 at :zy)vX(2=j>']7Kt}D6U:29395471
DEBUG: Code 0 at ;"=1\`' uS~i@zE2o8.q:29394068
DEBUG: Code 0 at :zy)vX(2=j>']7Kt}D6U:213131157
DEBUG: Code 0 at :zy)vX(2=j>']7Kt}D6U:121262647
DEBUG: Code 12749214 at :zy)vX(2=j>']7Kt}D6U:121261773
DEBUG: Code 0 at _HPM-}&q%}(q`f$pJk'=A:213137068
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file /Users/mattxlau/Movies/Transformers- Revenge of the Fallen Disc 1/Transformers- Revenge of the Fallen Disc 1_t00.mkv
Encountered 43 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
GnomeFondler
Re: Transformers: Revenge of the Fallen
Post by GnomeFondler »
That error is pretty much always a small scratch, a tiny streak of machine oil, or even a hair on the disk in my experience. I always check the disks before I put them in even if they're new, but there are lots of little flecks of stuff that can get on the disk at the factory that will prevent ripping. Get a lens cleaning cloth and look at it at odd angles under light, I guarantee you'll find some spot or little streak that looks like a scratch but isn't, and it's been about 90% for me that it could just be wiped off and the disk was fine. I don't know why the newer disks are so flakey with this unless they moved to some cheaper production method for dual layer disks that isn't as tolerant of surface contamination.
