Latest version of MakeMKV does not work for me
George314
#1 Post by George314 » Sun Nov 13, 2022 1:08 am
I updated MakeMKV to the latest version and it simply does not open a DVD any more. It does nothing. Could I download the previous version?
Re: Latest version of MakeMKV does not work for me
#2 Post by Billycar11 » Sun Nov 13, 2022 1:27 am
https://www.makemkv.com/download/old/
but your issue is likely something else maybe after reinstall you need to redo permissions or something or you just need a reboot or change the dvd mode
George314
#3 Post by George314 » Sun Nov 13, 2022 3:10 am
Thanks! I will try an older version and then the other things if it does not work.
George314
#4 Post by George314 » Sun Nov 13, 2022 3:20 am
It worked right away with a slightly older version!
