Tron :Legacy
Tron :Legacy
Any one else had any issue converting Tron Legacy? It completes the process just fine but playback is loaded with partial screen rainbow effects/artifacts? tried a couple times and same result. Dont have this issue with any other blurays yet. Using 1.6.7
Re: Tron :Legacy
If MakeMKV got the video from the disc into an MKV file then it's done it's job.
Your issue is likely a decoder issue from whatever player you're using for playback. I watched it yesterday using MPC-HT with CoreAVC and didn't notice any issues.
Re: Tron :Legacy
@Toona79
Hi!
1) Have you made a full disc backup or a "movie only" .MKV?
2) Does your original, commercial Blu-ray disc play properly on the same system?
Hi!
