docnoir
Post by docnoir »
can someone share the most updated dovi devices playback spreadsheet? thank you
NiCE77
Post by NiCE77 »
DonaldFaQ wrote: Mon Oct 31, 2022 1:59 pm FEL playback works only with 2 players, the OPPO and his Clone. And FEL will be only triggered if the Source is an ISO file or in the m2ts container.
There is no chance fpr playback FEL within mkv or mp4 container.
You're wrong, the Chromecast with Google TV 4K, TiVo Stream 4K and the Ugoos AM6B Plus supports FEL playback.
Gatorman
Post by Gatorman »
docnoir wrote: Fri Nov 11, 2022 11:18 am can someone share the most updated dovi devices playback spreadsheet? thank you
Just find the latest post from Reset_9999. The link is in his signature.
mad83
Post by mad83 »
Hi @RESET_9999,
I have DV 4K profile 5 mkv with top and bottom black bars. I would like to compress it with resolution change to 1080p with DV.
What should i do with extracted RPU before and after re-encodes ?
ArArdin
Post by ArArdin »
Interesting post. I have no experience with DV @ 1080p.
I would like to know how downscaling a DV P5 baselayer can be achieved in the first place. Given Dolby proprietary IPTPQc2 color space that's used by P5, I can imagine issues rising.
As an educated guess concerning RPU, if the letterbox bars are kept during re-encode, you'd have to adjust top & bottom L5 values to the actual amount of vertical pixels that the bars occupy in the re-encoded 1080p video.
Should you crop the black bars out before re-encoding, the values have to be set to zero.
Post by Manixx2020beyound »
For those using resolve 18.1 update can now decode profile 5 clips on the time line.
https://professionalsupport.dolby.com/s ... ntent_type
L11 metadata specs
sw5163
Post by sw5163 »
Hi guys, I read something about the new Apple TV 2022 outputs HDR10+ for DV content streaming on Samsung TV (S95B).
Does anyone know if it converts DV->HDR10+ on the fly or they just provide HDR10+ source?
Test file:
https://drive.google.com/drive/folders/ ... Ps8NfU53Ee
uhdiznotenough4mee
Post by uhdiznotenough4mee »
sw5163 wrote: Wed Nov 16, 2022 5:03 pm Hi guys, I read something about the new Apple TV 2022 outputs HDR10+ for DV content streaming on Samsung TV (S95B).
Test file:
https://www.whathifi.com/news/hdr10-sup ... ple-tv-app
I don't think that What Hifi? article really answers the OP's question. Yes, the 2022 AppleTV 4K supports HDR10+. Will it convert Dolby Vision to HDR10+ on the fly? I think that's unlikely, although I have not read an answer to that question.
uhdiznotenough4mee
dcoke22 wrote: Wed Nov 16, 2022 9:01 pm
Why would it need to convert anything when you can have both HDR10+ and DoVi in one HEVC streamed file and the right one is chosen for you device accordingly?
Last edited by uhdiznotenough4mee on Wed Nov 16, 2022 11:37 pm, edited 1 time in total.
ArArdin
Post by ArArdin »
uhdiznotenough4mee wrote: Wed Nov 16, 2022 10:29 pmWhy would it need to convert anything when you can have both HDR10+ and DoVi in one HEVC streamed file and the reight one is chosen for you device accordingly?
Well, as a first and most basal of thoughts, maybe because then you don't have to convert the file yourself?
bobbymkV
Post by bobbymkV »
Test file:
HDR10+ source is the correct answer.
General
Unique ID                                : 66233975591032682789646524526102530206 (0x31D4331F0EDCB2A1BED79B2B025F489E)
Complete name                            : Circuit.Breakers.S01E07.No.Place.LIke.Home.2160p.ATVP.WEB-DL.DDP5.1.Atmos.HDR10+.H.265-SMURF.mkv
File size                                : 5.38 GiB
Duration                                 : 31 min 8 s
Overall bit rate                         : 24.7 Mb/s
Writing application                      : mkvmerge v71.1.0 ('Fortitude') 64-bit
Writing library                          : libebml v1.4.4 + libmatroska v1.7.1
Video
Format profile                           : Main 10@L5@High
HDR format                               : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
General
Unique ID                                : 234858304283524647418137905566376502389 (0xB0B01068409B4803F858B4D8C413A475)
Complete name                            : Circuit.Breakers.S01E01.Test.Subject.13.2160p.ATVP.WEB-DL.DDP5.1.Atmos.HDR.H.265-FLUX.mkv
File size                                : 4.04 GiB
Duration                                 : 23 min 20 s
Overall bit rate                         : 24.8 Mb/s
Video
sw5163
Post by sw5163 »
bobbymkV wrote: Thu Nov 17, 2022 2:27 pm HDR10+ source is the correct answer.
legosoff
Post by legosoff »
Hi! Crop RPU which mode? Thank you in advance.
sergonnn111
Post by sergonnn111 »
i want to buy DUNE HD REAL VISION 4K , do i get dolby vision from mkv 7profile dolby vision BL+EL+RPU, is it real dolby vision on dune hd real vision 4k, please guys i need your advice ?
