Makemkv successfully creates .iso, but can't save titles from it
dxrmkvun
Post by dxrmkvun »
I have successfully created mkv files from numerous discs, but I have found a TV series DVD set that makemkv (ver 1.17.2) has a problem with. Using the Backup function, Makemkv successfully creates .iso files from the discs. I can play those files, with no errors, using VLC. So the .iso files are good. However, makemkv is unable to create .mkv files from the titles in the .iso files that it created (or, for that matter, from the discs themselves). All I get is the following error, with no explanation:
Calculated BUP offset for VTS #0 does not match one in IFO header.
Title #1 was added (20 cell(s), 2:23:56)
Saving 1 titles into directory C:/Zappiti
Failed to save title 0 to file C:/Zappiti/A1_t00.mkv
0 titles saved, 1 failed
Can anyone provide a solution for this issue?
wmcclain
Re: Makemkv successfully creates .iso, but can't save titles from it
Post by wmcclain »
Have you tried the different DVD opening modes as detailed here? viewtopic.php?f=7&t=28541
Or, you might note the title numbers when playing with vlc and use manual opening mode in makemkv.
