Received copy of UHD disc, not working
goji1986
Post by goji1986 »
New to the forum but have been a longtime user. I recently was given a copy of a UHD disc, and upon trying to convert it to MKV I get this series of errors before the process fails:
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 61759488, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 120477696, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 162422784, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 61814784, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 61839360, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 61839360-61845504, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 61845504, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 162490368, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 162508800-162514944, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 162514944-162533376, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 162533376, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 162643968, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 162643968-162650112, attempting to work around
The source file '/BDMV/STREAM/00002.m2ts' is corrupt or invalid at offset 162650112-162656256, attempting to work around
Failed to save title 1 to file
The folder containing the BDMV package (I'm on a Mac) also has a MAKEMKV folder. The structure looks like this:
BDMV
/MakeMKV
-/AACS
/CMAP
discattd.dat
I've read elsewhere on here that you need the discattd.dat file but I'm not sure where it's supposed to go. Any assistance would be greatly appreciated!!!
jayper
Re: Received copy of UHD disc, not working
Post by jayper »
First step is to: clean the disc with a damp lint free microfiber cloth and dry with another. Try to dump it again.
If that doesn't work, you'll need to either replace the disc, or replace the drive you use. The most recommended drives on the forums are: BU40N or UHD pioneer.
goji1986
Post by goji1986 »
jayper wrote:
Wed Nov 09, 2022 11:04 pm
I thought I had clarified in the OP, but I see now my language was not clear. I do not have a physical copy of the disc. It is digital only. I take it I’m out of luck?
Your disk is being picked up because of discattd.dat, otherwise your system wouldn't have displayed all the "The source file ..." messages.
What it's saying is that the image itself has problems. The stream 00002.m2ts is not valid in many places. The copy didn't "do well" copying the file from the optical disk to the hard disk.
goji1986
Post by goji1986 »
Woodstock wrote:
Thu Nov 10, 2022 12:11 am
Darn. So I’ll have to see if I can get another backup of the disc done. Thanks for the info!
