So far LOTR series is the only 4k UHD disks I cannot rip using my BW-16D1HT drive (driver ver 10.0.19041.1266). They play just fine on my Blu-ray Player.
What is it with these LOTR disks?
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00073.m2ts' at offset '2975397888'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '2975397888'
Beat a dead Horse LOTR 4k UHD
Re: Beat a dead Horse LOTR 4k UHD
clean the disc with a damp lint free microfiber cloth and dry with another.
after that replace the discs if that still does not work get a BU40N or UHD pioneer
Tried wiping them. I have had them for a long time unfortunately I cannot return them.Billycar11 wrote: Mon Nov 07, 2022 12:02 am clean the disc with a damp lint free microfiber cloth and dry with another.
My BW-16D1HT is flaking. As suggest above, your best bet is to get a new drive. My BU40N is a tank.
I will check it out thanks.jayper wrote: Mon Nov 07, 2022 4:40 am My BW-16D1HT is flaking. As suggest above, your best bet is to get a new drive. My BU40N is a tank.
