LG WH16NS40 firmware flash?
herrste3
#1 Post by herrste3 » Sun Nov 06, 2022 2:47 am
Hi guys im new to blu rays i purchased the 16NS40 from amazon all ok it came with firm1.05. I was reading different posts recommending different files.Tried MK 16n60 1.02 but gave me issues so I came across this firmware file, on another post. The process settings in image below with SDFTool. I went with the default settings and did not check the encrypted tick. It seems to have done the job. Do not have 4k disc yet but will have coming days to test. 1080 discs work fine so far. Was my process correct did i need to tick the encrypted button or ? Alot of questions i know.
Thanks pictures included
Settings used for sdftool
firmware now
firmware now
Re: LG WH16NS40 firmware flash?
#2 Post by Coopervid » Mon Nov 07, 2022 10:31 am
viewtopic.php?f=16&t=19634
Personally I think WH60NS60 1.03 reads 3-layer discs the best.
#3 Post by Billycar11 » Mon Nov 07, 2022 12:50 pm
Wh16ns40 1.05 is a downgrade in performance In everyway
Over wh16ns60 1.02
Not talking bad about 1.03 but I just don't test it as I don't touch lg or asus desktop drives anymore
#4 Post by SamuriHL » Mon Nov 07, 2022 12:54 pm
I tested 1.03 and found it made zero difference in reading discs over other firmware. These drives still suck for triple layer discs regardless of what magical firmware people think are going to solve all the problems.
#5 Post by Coopervid » Mon Nov 07, 2022 1:25 pm
Agreed. I also stick with my Pioneer drives instead of the LGs. They just read and don't show any hiccups.
CrackerBagger
#6 Post by CrackerBagger » Tue Nov 08, 2022 6:34 pm
Product: BD-RE WH16NS40
Revision: 1.00
Serial number: K96F6NG4821
Firmware date: 2113-04-04 14:41
Highest AACS version: 78
Drive platform: MT1939
Firmware version: 1.00
BD raw metadata read: Partial
Do I need to upgrade to 1.02 for UHD read?
#7 Post by Billycar11 » Tue Nov 08, 2022 9:15 pm
CrackerBagger wrote: Tue Nov 08, 2022 6:34 pm Drive Information
Revision: 1.00
No don't touch your firmware you will brick it
#8 Post by MartyMcNuts » Tue Nov 08, 2022 10:07 pm
Revision: 1.00
Your drive is too old and will never be able to read UHD. Time for a new drive!!
herrste3
#9 Post by herrste3 » Thu Nov 10, 2022 7:35 pm
thanks for all the replies i changed out the firmware -> HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936
and all working with uhd no probs. tested flashing also with amazon
FIDECO IDE and SATA Adapter, USB 3.0 Hard Drive Adapter and works good too no issues.
