Hello all and Mike! I have a new firmware revision for this great slim drive. It was manufactured late May 2021, and is the first drive I have come across with this new revision. When you are able to Mike, could you please work your magic, and release a new update for this specific model. I will link what I hope is a dump you can use, never dumped fw before. Your BN12 firmware has served me so well. I was saddened to see a new revision.
Thank you so much for your great work and efforts!
Also if this isn't a proper dump please inform me and I will try again.
Buffalo MediaStation BRXL-PT6U2VB New firmware revision BN13
- dump_user_BUFFALO_Optical_Drive_BN13_212009251104_MO5L3BI2243.tar
- (70.5 KiB) Downloaded 1001 times
Re: Buffalo MediaStation BRXL-PT6U2VB New firmware revision BN13
Probably just flash 1.03 with enc then if you want cross flash back to bn12 mk i used a different firmware for those but use what you like
I had no idea that was an option. I shall try it tomorrow when I get a chance. Thanks for oyu input Billycar11, appreciate greatly.Billycar11 wrote: Sat Aug 28, 2021 4:07 am Probably just flash 1.03 with enc then if you want cross flash back to bn12 mk i used a different firmware for those but use what you like
i should be more specific for people not like us i mean 1.03mk for the BU40NBluntman wrote: Sat Aug 28, 2021 4:26 amI had no idea that was an option. I shall try it tomorrow when I get a chance. Thanks for oyu input Billycar11, appreciate greatly.Billycar11 wrote: Sat Aug 28, 2021 4:07 am Probably just flash 1.03 with enc then if you want cross flash back to bn12 mk i used a different firmware for those but use what you like
BillyCar11, you sir are a scholar and a gentleman. Worked perfectly. I would have never figured that out on my own. Thank you. I and a happy customer owe you a debt of thanks. Thank you, Thank you, Thank you. Sincerely.Billycar11 wrote: Sat Aug 28, 2021 6:03 ami should be more specific for people not like us i mean 1.03mk for the BU40NBluntman wrote: Sat Aug 28, 2021 4:26 amI had no idea that was an option. I shall try it tomorrow when I get a chance. Thanks for oyu input Billycar11, appreciate greatly.Billycar11 wrote: Sat Aug 28, 2021 4:07 am Probably just flash 1.03 with enc then if you want cross flash back to bn12 mk i used a different firmware for those but use what you like
no problem glad to help just to confirm you do need to use enc on this firmware correct me and Marty are wondering so we can add it to the official encrypted firmware listBluntman wrote: Sat Aug 28, 2021 9:51 pm
Holy Crap, I apologize for the delay in the response. Sincerely. Yes all you have to do is hit the enc check mark.Billycar11 wrote: Thu Sep 30, 2021 8:21 amno problem glad to help just to confirm you do need to use enc on this firmware correct me and Marty are wondering so we can add it to the official encrypted firmware listBluntman wrote: Sat Aug 28, 2021 9:51 pm
ok thanks ill add it to the guide and your nameBluntman wrote: Wed Oct 13, 2021 6:36 am
What was the max speed you were able to rip at?
I'm trying to see how it compares to the Buffalo 16x External BRXL-16U3
It's a BU40N see guide for speed test it's one of the faster drivesmakerbot2 wrote: Sun Nov 06, 2022 1:10 am What was the max speed you were able to rip at?
