Error 0x80070021
Fiskn_
Error 0x80070021
#1 Post by Fiskn_ » Sat Nov 05, 2022 10:27 am
Hi!
I ripped my first movie yesterday and it all went well with both makemkv and handbrake. I saved the file on my local computer. And when I went to mount up my NFS to it and where to transfer the file to my NAS I got an error message.
Pointing to Error Code 0x80070021 and that part of the file is in use. I have googled alote and havent been so lucky.
Is there anybody else who have had any problem with this?
Re: Error 0x80070021
#2 Post by Woodstock » Sat Nov 05, 2022 2:38 pm
0x80070021 is usually an error having to do with Outlook, not copying files. Did you originally pull something off your NAS with Outlook?
Nothing related to MakeMKV could cause this.
Fiskn_
#3 Post by Fiskn_ » Sun Nov 06, 2022 6:21 pm
Woodstock wrote: Sat Nov 05, 2022 2:38 pm 0x80070021 is usually an error having to do with Outlook, not copying files. Did you originally pull something off your NAS with Outlook?
Thats usually the solution I found also, but I dont have Outlook installed on my computer. And I dont understand the link between the problem that points to Outlook and copying files from my local computer to my NAS :)
But like you said, it is not related to MakeMKV but I had to check.
Thanks for the reply.
