Top Gun: Maverick
aerandir92
Re: Top Gun: Maverick
Post by aerandir92 »
Coopervid wrote: Thu Nov 03, 2022 7:21 pm
aerandir92 wrote: Thu Nov 03, 2022 7:13 pm My ASUS drive just won't read any discs anymore after the first attempt of reading Maverick failed at around 70%. I've powercycled it, let it be unplugged from power for a while, rebooted the PC etc. The drive shows up in Windows, MakeMKV sees it, but when I enter a disc it just makes a few noises and never spins up properly :(
The blue laser might have failed. Try first a CD. Then a DVD. And at last a regular BD. If all still work all the lasers are still OK. Which leads to subsequent tests / measures.
Think you might be on to something there, DVD worked just find, BD does not. The unit is 4-5 years old, or something like that, so not that surprised if it failed now.
Most likely the blue laser died. These drives don't last very long.
thirdgen89gta
Post by thirdgen89gta »
Getting a ton of AV Sync issues. More than I'm comfortable letting it finish ripping and hoping for a valid movie. First disc had tons of similar errors, ended up returning it as a non-working disc.
Only had the drive for less than a year now. Rather frustrating. I don't know if its copy protection stuff, or just a crap drive.
I've had issues with discs before, usually 4K, and I usually just cleaned them, and then did a return saying it wouldn't play the disc, and the replacement is usually fine.
But even the 2nd replacement disc is doing the same stuff.
Other 4K discs rip fine.
First tried ripping just the MKV itself, then tried backing up the disc, and going to rip it from the decrypted backup.
I've got 3 other 4K's that do the same sorts of things, but I've successfully ripped many other 4K's, and even went back and tested a 4K I had ripped previously, and that ripped just fine. Example, ripped Hunger Games quadrilogy last month after repurchasing in 4K. I went back after Top Gun failed, as well as the other 3 discs, and I was able to successfully re-rip Mocking Jay part 1 without issue.
MakeMKV v1.17.2 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M00L8J85112d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Backing up disc into folder "/Users/User/Movies/backup/HUNGER_GAMES_MOCKINGJAY_2"
Backup done
Saving 1 titles into directory /Users/User/Movies/Top Gun- Maverick
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798327296, attempting to work around
Hash check failed for file 00294.m2ts at offset 31798388736, file is corrupt.
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798327296-31798333440, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798333440, attempting to work around
Hash check failed for file 00294.m2ts at offset 31798585344, file is corrupt.
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798333440-31798339584, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798339584, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798339584-31798345728, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798345728, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798358016, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798358016-31798364160, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798364160, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798376448, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798388736, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00294.m2ts' (title #-) , future messages will be printed only to log file
Hash check failed for file 00294.m2ts at offset 31798781952, file is corrupt.
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798364160-31798376448, attempting to work around
AV synchronization issues were found in file '/Users/User/Movies/Top Gun- Maverick/Top Gun- Maverick-FPL_MainFeature_t10.mkv' (title #11)
AV sync issue in stream 0 at 0:49:59.830 : video frame timecode differs by -41.711ms
AV sync issue in stream 0 at 0:49:59.871 : video frame timecode differs by -41.708ms
AV sync issue in stream 0 at 0:49:59.892 : video frame timecode differs by -20.862ms
AV sync issue in stream 0 at 0:49:59.892 : secondary stream video frame timecode differs by -20.862ms
AV sync issue in stream 0 at 0:49:59.913 : secondary stream video frame timecode differs by -41.716ms
AV sync issue in stream 1 at 0:49:59.200 with duration of 0.833ms : broken timecode, apparent audio skew is -96.666ms
AV sync issue in stream 1 at 0:49:59.233 with duration of 0.833ms : broken timecode, apparent audio skew is -24.166ms
AV sync issue in stream 1 at 0:49:59.234 with duration of 0.833ms : broken timecode, apparent audio skew is -21.666ms
AV sync issue in stream 1 at 0:49:59.235 with duration of 0.833ms : broken timecode, apparent audio skew is -12.5ms
AV sync issue in stream 1 at 0:49:59.236 with duration of 0.833ms : broken timecode, apparent audio skew is -2.5ms
AV sync issue in stream 1 at 0:49:59.247 with duration of 14.166ms : audio gap - 17 missing frame(s)
AV sync issue in stream 1 at 0:49:59.264 with duration of 19.166ms : audio gap - 23 missing frame(s)
AV sync issue in stream 1 at 0:49:59.289 with duration of 17.5ms : audio gap - 21 missing frame(s)
AV sync issue in stream 1 at 0:49:59.295 with duration of 12.5ms : audio gap - 15 missing frame(s)
AV sync issue in stream 1 at 0:49:59.319 with duration of 16.666ms : audio gap - 20 missing frame(s)
AV sync issue in stream 1 at 0:49:59.334 with duration of 16.666ms : audio gap - 20 missing frame(s)
AV sync issue in stream 1 at 0:49:59.348 with duration of 13.333ms : audio gap - 16 missing frame(s)
AV sync issue in stream 1 at 0:49:59.374 with duration of 15ms : audio gap - 18 missing frame(s)
AV sync issue in stream 1 at 0:49:59.391 with duration of 15.833ms : audio gap - 19 missing frame(s)
AV sync issue in stream 1 at 0:49:59.397 with duration of 12.5ms : audio gap - 15 missing frame(s)
AV sync issue in stream 1 at 0:49:59.410 with duration of 12.5ms : audio gap - 15 missing frame(s)
AV sync issue in stream 1 at 0:49:59.436 with duration of 15.833ms : audio gap - 19 missing frame(s)
AV sync issue in stream 1 at 0:49:59.450 with duration of 12.5ms : audio gap - 15 missing frame(s)
AV sync issue in stream 1 at 0:49:59.464 with duration of 12.5ms : audio gap - 15 missing frame(s)
AV sync issue in stream 1 at 0:49:59.484 with duration of 15.833ms : audio gap - 19 missing frame(s)
AV sync issue in stream 1 at 0:49:59.499 with duration of 12.5ms : audio gap - 15 missing frame(s)
AV sync issue in stream 1 at 0:49:59.513 with duration of 13.333ms : audio gap - 16 missing frame(s)
AV sync issue in stream 1 at 0:49:59.523 with duration of 12.5ms : audio gap - 15 missing frame(s)
AV sync issue in stream 1 at 0:49:59.546 with duration of 16.666ms : audio gap - 20 missing frame(s)
AV sync issue in stream 1 at 0:49:59.561 with duration of 13.333ms : audio gap - 16 missing frame(s)
AV sync issue in stream 1 at 0:49:59.584 with duration of 23.333ms : audio gap - 28 missing frame(s)
AV sync issue in stream 1 at 0:49:59.609 with duration of 13.333ms : audio gap - 16 missing frame(s)
AV sync issue in stream 1 at 0:49:59.624 with duration of 14.166ms : audio gap - 17 missing frame(s)
AV sync issue in stream 1 at 0:49:59.637 with duration of 20.833ms : audio gap - 25 missing frame(s)
AV sync issue in stream 1 at 0:49:59.664 with duration of 14.166ms : audio gap - 17 missing frame(s)
AV sync issue in stream 1 at 0:49:59.679 with duration of 15ms : audio gap - 18 missing frame(s)
AV sync issue in stream 1 at 0:49:59.693 with duration of 12.5ms : audio gap - 15 missing frame(s)
AV sync issue in stream 1 at 0:49:59.709 with duration of 20.833ms : audio gap - 25 missing frame(s)
AV sync issue in stream 1 at 0:49:59.730 with duration of 14.166ms : audio gap - 17 missing frame(s)
AV sync issue in stream 1 at 0:49:59.738 with duration of 13.333ms : audio gap - 16 missing frame(s)
AV sync issue in stream 1 at 0:49:59.752 with duration of 12.5ms : audio gap - 15 missing frame(s)
AV sync issue in stream 1 at 0:49:59.773 with duration of 18.333ms : audio gap - 22 missing frame(s)
AV sync issue in stream 1 at 0:49:59.788 with duration of 14.166ms : audio gap - 17 missing frame(s)
AV sync issue in stream 1 at 0:49:59.812 with duration of 19.166ms : audio gap - 23 missing frame(s)
AV sync issue in stream 1 at 0:49:59.833 with duration of 16.666ms : audio gap - 20 missing frame(s)
AV sync issue in stream 1 at 0:49:59.854 with duration of 22.5ms : audio gap - 27 missing frame(s)
AV sync issue in stream 1 at 0:49:59.879 with duration of 12.5ms : audio gap - 15 missing frame(s)
AV sync issue in stream 1 at 0:49:59.889 with duration of 20.833ms : audio gap - 25 missing frame(s)
AV sync issue in stream 1 at 0:49:59.907 with duration of 15ms : audio gap - 18 missing frame(s)
AV sync issue in stream 1 at 0:49:59.919 with duration of 13.333ms : audio gap - 16 missing frame(s)
AV sync issue in stream 1 at 0:49:59.939 with duration of 15.833ms : audio gap - 19 missing frame(s)
AV sync issue in stream 1 at 0:49:59.961 with duration of 19.166ms : audio gap - 23 missing frame(s)
Failed to save title 10 to file /Users/User/Movies/Top Gun- Maverick/Top Gun- Maverick-FPL_MainFeature_t10.mkv
Encountered 3 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
Try WH16NS60 1.03 but I'm not confident. It should read with a Pioneer UHD drive. Let me know by PM if you want to consider tht route.
thirdgen89gta
Coopervid wrote: Fri Nov 04, 2022 9:29 pm Try WH16NS60 1.03 but I'm not confident. It should read with a Pioneer UHD drive. Let me know by PM if you want to consider tht route.
The 2nd disc did eventually rip via Backup > then Rip individual MKV out of the backup. But still a bunch of AV sync errors on the same m2ts's. Haven't watched the output yet, so don't know if its actually good.
I originally had a ASUS drive, but that died, and I replaced it with this WH16NS60. I tried to look for the most current MK firmware, but found 1.02 in one of the packs on this forum.
Backing up disc into folder "/Volumes/RipStorage/TOP_GUN_MAVERICK"
File "/dummy_f.dat" was skipped
Hash check failed for file 00294.m2ts at offset 31799175168, file is corrupt.
Hash check failed for file 00294.m2ts at offset 31799371776, file is corrupt.
Hash check failed for file 00294.m2ts at offset 31799764992, file is corrupt.
Too many hash check errors in file 00294.m2ts.
Hash check for /BDMV/STREAM/00294.m2ts : 0.00% corrupt, 99.99% correct, 99.99% checked.
Encountered 5 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Backup done but 1 files failed hash check
Opening files on harddrive at /Volumes/RipStorage/TOP_GUN_MAVERICK
Using Java runtime from /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
Title #00596.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Saving 1 titles into directory /Users/william/Movies/Top Gun- Maverick
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798198272, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798198272-31798204416, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798204416, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798204416-31798210560, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798210560, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798210560-31798216704, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31798216704, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 31799574528, attempting to work around
....[cut lots of work around messages here]
AV sync issue in stream 3 at 0:00:00 : Forced subtitles track #3 turned out to be empty and was removed from output file
AV sync issue in stream 5 at 0:00:00 : Forced subtitles track #5 turned out to be empty and was removed from output file
1 titles saved
tron21net
Post by tron21net »
Successfully ripped the 4K disc bought from Amazon US (surprised to find was only the 4K disc was in the case, assumed it would be Blu-ray + Blu-ray 4K) couple days after submitting a MKB20_v76_Top_Gun-_Maverick_A7D8.tgz dump. Just one attempt and no read errors reported using MakeMKV v1.17.2 on Windows.
I did have to clean the disc with isopropyl alcohol (only had 91% on hand) with Q-tips, rinse off with cold tap water, and wipe off with a good microfiber cloth because it did have some glob streaks of gunk on the disc that I noticed before putting it into the disc drive. Not the first blu-ray media I've had to clean before as the complete series of Star Trek Enterprise had random discs that wouldn't read at first cause they were filthy.
Info:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: <removed>
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 3.10
Disc Information
Label: TOP_GUN_MAVERICK
Timestamp: 2022-08-18 10:22:47
Protection: AACS2.0/C v76
Data capacity: 90.20 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
thirdgen89gta wrote: Fri Nov 04, 2022 11:10 pm
1 titles saved
Look for WH16NS60 1.03, not BH16NS60 1.03. There is only a 1.03 for WH.
thirdgen89gta
Top Gun ended up ripping fine, despite the messages. Though afterwords I did upgrade to the 1.03MK firmware, didn't help.
But now I"ve got the same type of crap on a new 4k disc. and considering the number of discs throwing errors like this, I can only assume I've got a crappy drive, which is frustrating because the WH16NS60 is one of the most expensive drives out there, its disappointing to have so many read errors.
I've got 4 discs I can't rip at all, and just opened up Star Trek TMP 4K box set and first disc out of the box has issues too.
thirdgen89gta wrote: Tue Nov 08, 2022 11:30 pm Top Gun ended up ripping fine, despite the messages. Though afterwords I did upgrade to the 1.03MK firmware, didn't help.
Try cleaning your discs (use soapy water and dry with a microfibre cloth) before trying again.
golobulus
Post by golobulus »
MartyMcNuts wrote: Wed Nov 09, 2022 2:08 am
I can +1 the disk cleaning recommendation. My disk was not recognized. I cleaned it with dish soap and low and behold it's recognized now after multiple failed read attempts. It looks clean out of the box.
bsather
Post by bsather »
Had to clean my brand new disc several times with 91% isopropyl alcohol then it worked with my Asus BW-16D1HT 3.02 in Vantec Nexstar DX USB 3.0 external.
richpanda
Post by richpanda »
Screenshot 2022-11-16 at 11.05.14 PM.png (307.93 KiB) Viewed 20404 times
Been trying to rip the Maverick 4kUHD and disk cannot be loaded each time with different computers. Get this error each time. Using flashed LG BP50NB40, and had never had any issues with 4k blu-rays in the past. Any help? Disk has been cleaned multiple times.
richpanda wrote: Thu Nov 17, 2022 7:13 am Screenshot 2022-11-16 at 11.05.14 PM.png
Exchange the disc
cyanpelican
Post by cyanpelican »
I had read issues even after several attempts at cleaning. I exchanged through the retailer for a fresh disk (stating that the original was having errors partway through the movie) and it read correctly straight out of the box, no cleaning needed.
notes386
Post by notes386 »
I have been using this for several years with no issues. I just got the new UHD of both Top Guns (Top Gun and Maverick) from Amazon.
Neither work.
Top Gun-
Automatic SDF downloading is disabled for failed.
Error 'Scsi error - Medium Error....'
udf: node fe/efe failed!
Maverick-
Mucho Error 'Scsi error - ILLEGAL REQUEST...' errors
I don't see these on the spreadsheet. Does that mean they aren't ready? I'm using MakeMKV v1.17.2 on a new Mac Studio.
What is the process for new movies? Will a new version of MakeMKV be required to process these 2 movies?
Any ideas on when/if they will be available?
Thanks for all!
