You can flash it on Mac see guide belowSamicidal wrote: Wed Nov 02, 2022 8:17 pm I have the same drive - did you end up flashing it on the Mac or did you have to do it in WIndows? (I have a Mac)
Asus BW-16D1X-U
Re: Asus BW-16D1X-U
Re: Asus BW-16D1X-U
Thanks, I'm going to email you
Re: Asus BW-16D1X-U
I have one of these as well, I had to check encrypted on the SD Flasher to make it flash(Change it from Red X to green checkmark), I have the newer A105 firmware.
Ripping my first UHD right now, thanks all for sharing your knowledge!
Re: Asus BW-16D1X-U
I myself have just gotten my hands on this drive (Manufacture date of Sept 2022, came with original firmware of A105) and flashed the ASUS-BW-16D1HT-3.10-WM01601-211901041014 firmware onto the drive using the SDF GUI Tool; but I am unable to open my 4K UHD drive. Anyone able to assist?
From reading around it seems like I should just return this and purchase something specifically supported =D, which I'll probably do if I don't figure this out in the next week or so and return it to Amazon.
Re: Asus BW-16D1X-U
No your issue is automatic sdf download is disabled or failed.VeniVV wrote: Mon Jan 30, 2023 1:32 am I myself have just gotten my hands on this drive (Manufacture date of Sept 2022, came with original firmware of A105) and flashed the ASUS-BW-16D1HT-3.10-WM01601-211901041014 firmware onto the drive using the SDF GUI Tool; but I am unable to open my 4K UHD drive. Anyone able to assist?
Any UHD drive is going to do this fro you either enable it or disable your firewall or geofilters for Russia
Re: Asus BW-16D1X-U
Ok, I do have "Enable Internet Access" checked in Preferences -> General. Is that what you mean by enable? Is there an IP I could allow or anything on where it gets the SDF from? It's working though! Thank you! Sorry, brand new to this.Billycar11 wrote: Mon Jan 30, 2023 2:26 amNo your issue is automatic sdf download is disabled or failed.VeniVV wrote: Mon Jan 30, 2023 1:32 am I myself have just gotten my hands on this drive (Manufacture date of Sept 2022, came with original firmware of A105) and flashed the ASUS-BW-16D1HT-3.10-WM01601-211901041014 firmware onto the drive using the SDF GUI Tool; but I am unable to open my 4K UHD drive. Anyone able to assist?
Turns out it was definitely my geo-filtering on my Unifi Dream Machine. On the controller you want to go to settings (go to old settings view), Routing & Firewall -> GEOIP Filtering.
Re: Asus BW-16D1X-U
I have this exact drive, manufactured Sept 2022, and only have Mac (no access to Windows machine).
Anyone who successfully flashed theirs, on Mac, care to post the exact commands that need to be run to get this to work?
Thanks in advance.
Thanks in advance.
Re: Asus BW-16D1X-U
Flashing firmware on a Mac for LibreDrive?jase52476 wrote: Fri Feb 03, 2023 3:19 am I have this exact drive, manufactured Sept 2022, and only have Mac (no access to Windows machine).
Thanks in advance.
Re: Asus BW-16D1X-U
email me about the pioneer autoflasher to see if it can be flashed. $25 USDThereIs_No_Spoon wrote: Tue Feb 07, 2023 10:43 pm
I've had one of these drives for a while, and I was considering getting a new UHD drive but, of course, I'd love it if this drive ends up working with UHD discs. I've read the forums and I'm quite confused about what can and can't be flashed when it comes to this specific drive...here's a screenshot of my info..a bit of help, please?
Re: Asus BW-16D1X-U
I'm a newbie. I just installed the latest MakeMKV and this is the info it gave me. Is my firmware flashable for 4k UHD? My drive info below:Billycar11 wrote: Mon Apr 05, 2021 10:39 pm Looks like it's probably a BH16NS40 same as the asus desktop drive.
Weird that they changed the drive have it labeled as bh50n
I would probably flash it with asus 3.10 or WH16NS60 1.02.
UHD is probably possible on it but really no one has tried with that exact setup hopefully it's just a sticker change
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: xxxxxxxxxxxxx
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Highest AACS version: 10
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
Thanks.
Re: Asus BW-16D1X-U
yeah it can do UHD if flashedRebo0ot wrote: Tue Mar 21, 2023 11:24 pmI'm a newbie. I just installed the latest MakeMKV and this is the info it gave me. Is my firmware flashable for 4k UHD? My drive info below:Billycar11 wrote: Mon Apr 05, 2021 10:39 pm Looks like it's probably a BH16NS40 same as the asus desktop drive.
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Thanks.
email me or Marty for an automated flasher if you don't want to flash it yourself
Re: Asus BW-16D1X-U
Thanks for the quick response. I'd like to try it myself. I've downloaded the SDFtool Flasher (v1.3.5) but I'm not sure what firmware I should flash it to. Any recommendations are appreciated.
Re: Asus BW-16D1X-U
if it were mine i would go to wh16ns60Rebo0ot wrote: Wed Mar 22, 2023 1:53 am Thanks for the quick response. I'd like to try it myself. I've downloaded the SDFtool Flasher (v1.3.5) but I'm not sure what firmware I should flash it to. Any recommendations are appreciated.
Re: Asus BW-16D1X-U
Thanks Billy - Is there much a performance difference between let say the ASUS-BW-16D1H-U-A204 and HL-DT-ST-BD-RE_WH16NS60-1.03? Just wondering if these options are similar to preferences in choosing a car like someone preferring a GM product over a Chrysler product? There appears to be a few choices available and I appreciated your input.
Re: Asus BW-16D1X-U
the WH16NS60 firmware has no sleep bug thats the main difference.Rebo0ot wrote: Thu Mar 23, 2023 11:57 pm Thanks Billy - Is there much a performance difference between let say the ASUS-BW-16D1H-U-A204 and HL-DT-ST-BD-RE_WH16NS60-1.03? Just wondering if these options are similar to preferences in choosing a car like someone preferring a GM product over a Chrysler product? There appears to be a few choices available and I appreciated your input.
and asus firmware is way more inconsistent it could reach 8x speed or it may decide 2.2x is good.
