Advice on Converting Rips to Playback ATMOS on AppleTV (Infuse)
shukla
#1 Post by shukla » Wed Nov 02, 2022 5:34 pm
Its my understanding that AppleTV cannot play TrueHD passthrough so the audio is converted down to PCM on playback which is limited to 5.1/7.1. I am curious if there is a way to convert my MKV rips to a format that will play the full atmos audio so I can take advantage of the heights in my 5.1.2 setup.
Any advice is much appreciated!
Re: Advice on Converting Rips to Playback ATMOS on AppleTV (Infuse)
#2 Post by dcoke22 » Wed Nov 02, 2022 11:37 pm
The AppleTV will do E-AC-3 + Dolby Atmos. Atmos on blu-rays is typically TrueHD + Atmos as I'm sure you're aware. I'm not aware of any tools available to regular people to transcode TrueHD + Atmos to E-AC-3 + Atmos.
Infuse's entry about AppleTV audio.
mattyj2001
#3 Post by mattyj2001 » Fri Nov 11, 2022 10:10 am
I got annoyed enough with Apple's lack of TrueHD + Atmos that I bought an Nvidia Shield. Slap Kodi on that bad boy and you got yourself some Atmos playback from all your Blu-ray/UHD rips.
I check back in once in a while in case Apple has started supporting other flavors of Atmos, I'd very much like to go back to an ATV, but for now I gotta deign to use this (admittedly pretty good, but not as good an an ATV) AndroidTV device.
Mouse
#4 Post by Mouse » Sat Nov 12, 2022 5:39 pm
What app is used on the Shield to play an MKV with THD Atmos??
mattyj2001
#5 Post by mattyj2001 » Sun Nov 13, 2022 7:12 am
Kodi. It's a little bloaty but seems pretty reliable. I routinely stream 4k uncompressed rips through it from a NAS and it rarely flails. I'm going through a Samsung soundbar and it recognizes Atmos in a THD wrapper, no problem.
