Rabbit Hole fails
Rabbit Hole fails
The blu-ray fails on both backup and main movie. Rips fine with DVDfab. debug log attached
Re: Rabbit Hole fails
Rabbit Hole also fails for me with Registered version. I emailed log to svq@makemkv.com yesterday. Hoping for a fix.
I also have AnyDVD as a backup to MakeMKV and they are having problems with this movie also.
setarip_old
From the DVDFab Forum:
BTW - "Rovi" was formerly known as "Macrovision".
I'm sure "mike admin" will have this resolved shortly...
BD+ Generation 10 is out...:
- starts with "Rabbit Hole" on 28feb2011
- first BD+ title from Lionsgate
- the code is still made by ROVI
- Contact:
Yes, it's a new version of BD+ . The new MakeMKV version with updated BD+ engine will be available in a few days.
Is it possible to rip the encrypted movie to an .iso file and then decrypt the .iso file later
when the fix comes out for makemkv.
setarip_old
@jakeBray
Hi!
Hi!
Why would you waste your time doing that?Just wait until the fix is available - and then use MakeMKV ONCE...Is it possible to rip the encrypted movie to an .iso file and then decrypt the .iso file later
You can use the "backup" button on MakeMKV to make an encrypted copy on your hard drive. You can then use MakeMKV on the folder once MakeMKV has been updated.jakeBray wrote:Is it possible to rip the encrypted movie to an .iso file and then decrypt the .iso file later
Could it be a rental?setarip_old wrote:@jakeBray
Hi!Why would you waste your time doing that?Just wait until the fix is available - and then use MakeMKV ONCE...Is it possible to rip the encrypted movie to an .iso file and then decrypt the .iso file later
setarip_old
@Mondays
Hi!
Why speculate? Let "jakeBray" answer the question I asked him...
Hi!
NOW i guess we just all wiat 'till mike fixes this movie, hoping for a fix. emailed log to svq@makemkv.com alsoMondays wrote:Rabbit Hole also fails for me with Registered version. I emailed log to svq@makemkv.com yesterday. Hoping for a fix.
been trying 2 copy Rabbit Hole movie for a month same result & cannot get a clean rip. AnyDVD same ; fails also!
- Contact:
Should work now with new version, 1.6.8 .
Yep, it's working now. Thanks!
- Contact:
Hi. Out of curiosity, how did you get this movie a month before its official release?pigStix wrote:NOW i guess we just all wiat 'till mike fixes this movie, hoping for a fix. emailed log to svq@makemkv.com alsoMondays wrote:Rabbit Hole also fails for me with Registered version. I emailed log to svq@makemkv.com yesterday. Hoping for a fix.
TheAristocrat0
*edit*
Last edited by TheAristocrat0 on Tue Jul 05, 2016 4:04 am, edited 1 time in total.
TheAristocrat0
*edit*
Last edited by TheAristocrat0 on Tue Jul 05, 2016 4:06 am, edited 1 time in total.
