Will my drive lock again when inserting a disk with recent AACS version?
b1n0ry
#1 Post by b1n0ry » Wed Nov 02, 2022 6:08 pm
Hi all, I'm new to the forum and hoping for some help.
First of all, to avoid confusion I want to make clear that everything that follows in this post is related to "standard" HD BluRay - no UHD involved.
Earlier today, I attempted to rip Top Gun: Maverick (sourced from Amazon Germany) which releases tomorrow with my Asus BC-12D2HT. When inserting the disk and trying to back up, I got this error:
Saved AACS dump file as C:\........\MKB_v68_TOP_GUN_MAVERICK_4770.tgz
Backup failed
Furthermore, the drive seems to have locked. It now refuses to decrypt even disks that worked before. Researching the problem afterwards, I found that this apparently can happen. I have since driven to a local electronics shop and got myself an Asus BW-16D1HT. I have flashed the new drive to firmware version 3.10 following the guide viewtopic.php?f=16&t=19634. This is what MakeMKV shows now:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLNL8IB0318
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 3.10
I verified that I can now rip my old disks again. But I'm a bit afraid to put the new Top Gun disk in the new drive. I worry it will lock up again. Therefore, this is my question:
Will the custom firmware that I flashed prevent the drive from revoking host certificates? The old drive had LibreDrive enabled, too, btw.
Thanks for your help.
Re: Will my drive lock again when inserting a disk with recent AACS version?
#2 Post by d00zah » Wed Nov 02, 2022 7:02 pm
While this topic is about the benefits of LibreDrive, it also does a good job explaining what you ran into...
LibreDrive and AACS
FW update for ASUS-BC-12D2HT available...
Ultimate UHD Drives Flashing Guide Updated 2022
b1n0ry
#3 Post by b1n0ry » Wed Nov 02, 2022 10:01 pm
Thanks for your reply, d00zah.
The first post you linked is actually the one where I got the information that a drive can "lock" itself. It says:
In LibreDrive mode you always would be able to use this drive with MakeMKV or any other software that uses (open source) LibDriveIo library. No AACS revocation or other update would affect usability of your drive in LibreDrive mode.
This to me reads as if I can safely insert the new disk into the drive without fear of it blocking my host / my MakeMKV instance because my drive is in LibreDrive mode. However, my old drive was also in LibreDrive mode according to MakeMKV and it did become unusable. Do you have any insights on that?
#4 Post by d00zah » Thu Nov 03, 2022 1:38 pm
b1n0ry wrote: Wed Nov 02, 2022 10:01 pm Thanks for your reply, d00zah.
Only speculative, but occasionally a user will report a "lock-up/hang/etc" which requires a device power-cycle (not just a reboot) to resolve. Some sort of rare, unhandled event in the "LibreDrive magic" running in device RAM? Had you power-cycled the drive before retry? Maybe just a drive at the end of "its time"?
Beyond that, I think only Mike would know enough to theorize?
b1n0ry
#5 Post by b1n0ry » Thu Nov 03, 2022 9:06 pm
It may very well have been a fluke due the age of the 12D2HT, label says it's from 2014. But I tested it again today and it successfully backed up old disks as well as the new Top Gun.
Next for me will be trying out UHD. If that works consistently with the old drive, I'll probably return the new one.
Thanks again for your time!
#6 Post by d00zah » Thu Nov 03, 2022 9:33 pm
b1n0ry wrote: Thu Nov 03, 2022 9:06 pm ... label says it's from 2014...
2014 HW is too old for UHD. Observe what MakeMKV reports for 'Drive platform':
Drive platform: MT1959 = UHD capable
- vs -
Drive platform: MT1939 = pre-dates UHD. Flash wrong FW & brick it!
#7 Post by Coopervid » Thu Nov 03, 2022 9:35 pm
I also just wanted to warn him. You were first!
#8 Post by d00zah » Thu Nov 03, 2022 9:37 pm
Coopervid wrote: Thu Nov 03, 2022 9:35 pm I also just wanted to warn him. You were first!
As often as it's been discussed, it pains me each time it happens. :o
#9 Post by Coopervid » Thu Nov 03, 2022 9:44 pm
I write a PM to Billy. He should put the MT1959 check as a pre-requisite before someone even thinks about flashing a LG drive.
b1n0ry
#10 Post by b1n0ry » Thu Nov 03, 2022 10:29 pm
Thanks for the warnings :) MakeMKV does indeed report the drive platform to be MT1939.
The reason I haven't flashed the Asus BC-12D2HT already is because I couldn't find any instructions for it. I may be new to BluRays, but I have bricked other hardware in the past to know not to use any old firmware image and hope for the best... I tried using the SDFtool Flasher, but it said that the drive is not supported. Now I know why.
d00zah wrote: Thu Nov 03, 2022 9:33 pm 2014 HW is too old for UHD.
That I did not know. Is this a hardware limitation?
#11 Post by Coopervid » Thu Nov 03, 2022 10:33 pm
b1n0ry wrote: Thu Nov 03, 2022 10:29 pm Thanks for the warnings :) MakeMKV does indeed report the drive platform to be MT1939.
Yes.
