Its my understanding that AppleTV cannot play TrueHD passthrough so the audio is converted down to PCM on playback which is limited to 5.1/7.1. I am curious if there is a way to convert my MKV rips to a format that will play the full atmos audio so I can take advantage of the heights in my 5.1.2 setup.
Any advice is much appreciated!
Advice on Converting Rips to Playback ATMOS on AppleTV (Infuse)
Re: Advice on Converting Rips to Playback ATMOS on AppleTV (Infuse)
The AppleTV will do E-AC-3 + Dolby Atmos. Atmos on blu-rays is typically TrueHD + Atmos as I'm sure you're aware. I'm not aware of any tools available to regular people to transcode TrueHD + Atmos to E-AC-3 + Atmos.
Infuse's entry about AppleTV audio.
mattyj2001
I got annoyed enough with Apple's lack of TrueHD + Atmos that I bought an Nvidia Shield. Slap Kodi on that bad boy and you got yourself some Atmos playback from all your Blu-ray/UHD rips.
I check back in once in a while in case Apple has started supporting other flavors of Atmos, I'd very much like to go back to an ATV, but for now I gotta deign to use this (admittedly pretty good, but not as good an an ATV) AndroidTV device.
What app is used on the Shield to play an MKV with THD Atmos??
mattyj2001
Kodi. It's a little bloaty but seems pretty reliable. I routinely stream 4k uncompressed rips through it from a NAS and it rarely flails. I'm going through a Samsung soundbar and it recognizes Atmos in a THD wrapper, no problem.
