Recommended Libre drives usb 2 or 3 ?
JacobHeldt
#1 Post by JacobHeldt » Mon Oct 31, 2022 9:01 am
Hello there
i have been Reading through a lot of the forum trying to find the best drive to rip blu-ray and maybe 4K's aswell - and its seems like a jungle....so any suggestions ?
hope you can help me. thanks
Re: Recommended Libre drives usb 2 or 3 ?
#2 Post by Billycar11 » Mon Oct 31, 2022 10:01 am
BU40N or UHD pioneer is what i recommend
#3 Post by Coopervid » Mon Oct 31, 2022 10:15 am
If you want to use the drive via USB you should get an USB 3 enclosure. USB 2 would still be fast enough for optical drives but you could run into problems with lacking power. USB 3 will be the safer choice. However, there are rare reports of lacking power with USB 3 but then you can use an active USB 3 hub in between the enclosure and the PC.
JacobHeldt
#4 Post by JacobHeldt » Mon Oct 31, 2022 10:52 am
Thanks for the feedback - if there is specific Pioneer Drives or other drives please write the Model number - thanx a bunch !!!
#5 Post by Billycar11 » Mon Oct 31, 2022 11:20 am
JacobHeldt wrote: Mon Oct 31, 2022 10:52 am Thanks for the feedback - if there is specific Pioneer Drives or other drives please write the Model number - thanx a bunch !!!
see guide below
